Question about Electrical Supplies
Removeing invertor from powermate 1500 generator
How to remove to replace rod and crank
  • hoopiecar10 Jan 29, 2009
    how do i get the gen off the crank to repair thee engine
    Scholar:
  • 149 Answers
To get the rotor off the crank.
Lossen the through bolt a few turns...
Get some one to pull on the rotor and give the bolt a sharp hard hit.. The bolt can buckle some times but still be ok..
90% of the small gensets just use a tapper shaft.
Posted on Jan 30, 2009
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
How do I split the DC head from the engine?
I am assuming that you mean the generator head from the engine. If this is so, 1st remove the end cover from the gen. head. You will see a bolt that goes through the rotor shaft to the engine shaft. The engine his a tapered shaft, that the gen head bolts to. 2) Remove the long bolt from the rotor shaft. 3) Remove the 4 long bolts that hold the housing ends together. 4) cut a length of rod that is smaller in diameter than the rotor shaft bolt and about 1/2 inch shorter. This will be used as a push rod to separate the engine shaft from the rotor shaft. 5) There are threads at the beginning(inside) of the rotor shaft. Most likely metric. Find the right size bolt, approx. 1" long. Screw in until contact with the push rod. (If possible, use an impact wrench to make it easy.) Tighten til the shafts "pop loose." One suggestion to keep the engine from rotating while doing this is to remove the spark plug, stick a length of small rope down the hole, leaving some hanging out, rotate engine until piston packs against the rope and stops the rotation. 6)now that the gen head is removed, the engine mounting end can be removed. Good luck.
Big Daddy
Jul 15, 2011 | Coleman Powermate Powermate 5000W...
How do you remove the rotor from the engine shaft. I need to replace the engine oil seal.
Unbolt and slide the stator over the rotor exposing it. Then simply unscrew the one bolt holding it to the crank. In my experience you need an impact to get the bolt out with spinning the engine and the rotor may need some negotiation to get off. Try a rubber mallet or a sledge with a block of wood, also may need to use a puller as well. Some come off easy but remember you can only hit a magnet so many times before it begins to lose magnetism.
Jul 05, 2011 | Coleman Powermate Powermate 5000W...
I have a powermate 5000 (about 10 years old). I have installed a Reliance Transfer switch. Should I ground the frame to a grounding rod when plugged in. I obtained the manual(on the powermate) and the...
In any power generator installation it is always advisable to have a ground/earth rod (minimum 3 ft/1 metre long) attached to the frame of the generator, especially when connecting ancilliaries such as yuor transfer switch. The Earth and Neutral pins of the output sockets on the generator should also be interconnected. They are usually linked at the factory on assembly.
Dec 22, 2010 | Coleman Powermate Subaru 5000W Portable...
Remove motor from generator
aramature must be removed to get to the mounting plate it will slide out off case loosen long bolt in center of armature hold armature and hit bolt briskley will pop off be careful putting arm back may be 2 brushes inside have a helper hold brushes back
Jul 30, 2010 | Briggs & Stratton Briggs and Stratton...
The recoil turns but the crank wont turn at all. is it ceased up?
if you can pull the recoil full out then the fault is with the recoil remove recoil and try to turn crank by hand
Mar 15, 2010 | Coleman Powermate Premium Plus 6250W...
I have a coleman powermate 6250 I need to remove the armature so I can change the oil seal on the crank. How do you remove this
Here is how I did it. First unscrew the bolt holding the armature to the crank. Measure the bolt length and thread sizing(mine was 5/16-24) Go to menard's or any hardware store and buy a piece of un-threaded rod the same diameter. Buy a die so you can thread the end of the rod. cut the rod one inch shorter than the bolt length and make a kerf in the end for a screw driver blade. Now measure the inside diameter of the armeture hole( mine was 3/8) I then took a 7/16 tap and threaded the end of the armeture. Now screw in the rod you made, then screw a bolt into the end of the armeture and this will push the armeture off the crank without damaging it.
Dec 06, 2009 | Coleman Powermate Premium Plus 6250W...
Colman powermate PM 1500
You could have a shorted diode in the full wave brige for the DC charge circuit, test it with the diade scale on a DMM.
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
