Question about Intel Computers & Internet
How to reset password e210882
When i clear bios password, i remove battry an unplug cable. It does not work. how can i reset pass.
migregorio
  • 42 Answers
SOURCE: Advent 7110 bios password hell
ftp://ftp.sabioproducts.com/pub/Notebook/EF6C/EF6C_Service_Manual
I believe this is the manual associated with this Advent laptop. Select "disassembly instructions". Item is a viewable PDF document.
Posted on Apr 13, 2008
mewms_14904
  • 1027 Answers
SOURCE: bios password loocked my sys
ftp site for manuals
c= chinese
e= english
g= german
j= japanese
s= spanish
This will clear the bios.
Posted on Jun 04, 2008
  • 4 Answers
SOURCE: clear power on password
Removing the Time of Year battery will clear the BIOS password. It is located on the underside of the n610c behind the panel covered by the Microsoft COA label. A small phillips screwdriver is required to remove the two screws on the panel. Carefully lift the BR1225 battery with a small flat blade screw driver.
After 10 minutes re-insert the battery. The BIOS Password should now be cleared, as well as other BIOS settings, the time and date.
Posted on Jan 12, 2009
SOURCE: Reset bios on Toshiba A215
This should be able to be solved by opening the Ram bay and shorting out two solder points. Usually marked with a "xxx". The notebook should be started with these solder points shorted. Once the pc is on, it should go through the normal process without asking for a bios password. Once the pc is restarted, the CMOS password should disappear.
Cheers.
DOC
Posted on Jan 16, 2009
  • 7 Answers
SOURCE: will removing the cmos battery help remove bios password
Yes, if you remove the cmos battery and have your PC unpluged wait 2-3 mins before reseting battery it should reset the bio's.
Posted on Feb 24, 2009
Bios password Dell XPS M170 how do you unlock it ???
How to use the jumper to reset the BIOS password on your Dell desktop computer
Summary: If you're prompted for the Basic Input/Output System (BIOS) password at startup (before the operating system loads) or the BIOS or CMOS setup is locked, and you don't know or have forgotten the password, you won't be able to use your computer or change BIOS settings. Use these instructions to reset the BIOS password manually using the jumper.
NOTE: This process will not clear a Windows Operating System password, nor will it clear passwords on a Dell portable computer. This is only to clear System BIOS passwords on Dell Desktop and Mini-Tower systems.
Desktop system BIOS password reset.
NOTE: The BIOS is the program that activates the hardware required to start your computer. The jumper is a small plastic covering found inside your computer.
Before you begin
Perform the safety steps in the order below.
WARNING: These steps are for your personal safety and the protection of the equipment.
  1. Turn off the computer and unplug the power cable.
  2. Wait 5 seconds.
  3. Disconnect all external devices.
  4. Disconnect any telephone or network cables from your computer.
  5. Press and hold thePowerbutton for 10 seconds while your computer is unplugged to release static electricity from the system.
  6. Before touching anything inside your computer, ground yourself with a wrist-grounding strap or by touching an unpainted metal surface, such as the metal at the back of your computer. While you work, periodically touch an unpainted metal surface to dissipate static electricity.
To use the jumper to reset the BIOS password
NOTE: On the DellManualsweb page, download the Setup Guide or Service Manual for your computer. Then refer to the System Board Components section for a labeled illustration of the jumpers on the system board.
  1. Ensure that your work surface is flat and clean to prevent scratching your computer's cover.
  2. With your computer still turned off and unplugged, remove your computer's cover.
  3. To locate the password jumper on the motherboard, look for the letters PWD, PSWD or PSWDCLR.
  4. Choose an option:
If there are 2 metals pins under the jumper
  1. Remove the jumper from the pins, replace the computer cover, reconnect the power cable and monitor and turn on the computer.
  2. After the Windows logon screen appears, turn off the computer.
  3. Again, disconnect the power cable and monitor. Press and hold the power button for 10 seconds to release static electricity from the system.
  4. Remove your computer cover.
  5. Replace the jumper in its original position covering the 2 pins. This will re-enable password feature.
  6. Replace the computer cover.
  7. Reconnect the power cable and other connections and turn on the computer.
If there are 3 pins under the jumper (See figure 1. below.)
Figure 1. Generic motherboard illustration showing a 3 pin password jumper, you motherboard may vary, see the owners manual for you system for specific instructions.
  1. Remembering which two pins are covered, remove the jumper from those pins.
  2. Reinstall the jumper in a different position. For example, if you removed the jumper from pins 2 and 3, reinstall the jumper over pins 1 and 2.
  3. Replace the computer cover and reconnect the power cable and monitor.
  4. Turn on the computer and wait 5 seconds. Then press and hold thePowerbutton until the computer turns off again.
  5. Disconnect the power cable and monitor again. Press and hold thePowerbutton for 10 seconds to release static electricity from the system.
  6. Replace the jumper over the original 2 pins.
  7. Replace the computer cover.
  8. Reconnect the power cable and other connections and turn on the computer.
May 06, 2017 | Dell Computers & Internet
Clear bios pass
Hello Seb, try removing the toshiba motherboard battery run the PC and it will ask for a new password (sort of) or try cmos jumper. If you can provide more info on the unit better. try google search for clearing bios password.
Jan 02, 2014 | Toshiba Computers & Internet
My laptop is not booting. its showing enter passward in blue screen.
somebody set the bios password to reset the bios password open the back cover of ram u see a small battry like a coin remove it fo10 to 20 second and remove laptop battry at same time then plug the adapter u will see baios was reset if u have any qury plz tell me the laptop model no and manufacturer
Sep 15, 2011 | Computers & Internet
Li m runing window 7 operating system i forget my bios password so help me to install window in my system
First you have to reset your bios password relax , you can do it. It just take time.There are two ways to approach forcing the Bios/CMOS to be reset to its default values: Option #1: Mechanically, by removing all power to the Bios/CMOS thereby forcing it to reset itself to its stored defaults, which include no password or the default password employed by the Bios manufacturer, and Option #2: Using a program to either locate and identify the password and reveal it to you or erasing the password entirely. These are referred to as password by-pass utilities or cracks. Let's look at Option #1 first, and then move on to Option #2 if necessary.Most motherboards manufactured over the last decade or more use a battery to sustain the dynamic Bios/CMOS settings for the motherboards PROM chip. These dynamic settings are those manually set by either the computers manufacturer or you, the user. There are two ways to erase these dynamic settings, by either resetting a jumper on the motherboard itself (referred to as a "clear CMOS" jumper), or by physically remove the power from the computer (disconnecting the power plug) and then removing a battery (used to maintain power to the PROM chip that contains the Bios/CMOS information) from the motherboard.Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.But do not forget to put it back at its same pin as before.
Aug 19, 2011 | Computers & Internet
I have bought the used hp sp323071-001 ,I want to boot by DVD-rom but it doesn't boot and the bios has got a password which I don't know what it is , I tried to reset the password by removing the...
you could try Compaq as the bios password some manufacturers place this password on there computers for maintanance reasons
or you might
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove. If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password. If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard. If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (integrated circuit) on your motherboard. Many RTC's require an external battery. If your RTC is one of this type, you can clear the BIOS password just by unsocketing the RTC and reseating it. RTC's which require external batteries hope this helps
May 29, 2011 | HP Compaq Motherboard
Dell inspiron 1545 has authentication system password ..tried removing battery cannot get pass it
The aim is to reset the BIOS so that data concerning passwords are cleared out. This is done by moving a jumper on the motherboard.( The biggest challenge is to find it).
Note that: This procedure also resets the BIOS settings. If you have made changes, this manipulation will reset these features to default.
  • Step 1: Turn off your PC and unplug the power cable and open your system unit. Touch the chassis of the casing with a metallic object to discharge static electricity.
  • Step 2: Check the documentation for your motherboard to locate the position of the jumper, that reset the BIOS. If you don't have any manual, look on your motherboard one of the following tag: CLR BIOS, CLEAR BIOS, CLR CMOS, CLEAR CMOS, RESET BIOS or RESET CMOS. It is usually near the CMOS battery on the motherboard.
  • Step 3: Find the jumper on your motherboard reset it. It is usually close to the battery.
If the jumper is on 3-connector pins, place it on the middle and the initially uncovered pins.
Wait for some time and put the jumper in its original position (PIN1-PIN2).
If the jumper is on a 2-connector pins and that it holds on a single pin, place it on both, wait one second and then return it to its original position.
  • Step 4: Power up and start your PC: the password has disappeared.
Dec 04, 2010 | Dell Inspiron 1545 Notebook
Pc has locked itself and i do not have the defaault hp pass word to log in
bios password ? or windows password ?
if its the bios password just clear the cmos or remove the bios battrie for few mins and disconnect all power and turn the pc on it will start for a realy short second its just to clear all the power wait 10-15 mins put back in bios battrie or put cmos jumper back in defult poz and plug it back in and away u go
Jan 27, 2010 | HP Compaq Evo W6000 PC Desktop
How to remove cmos/bios password ?
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
Bios password
The master password for Compaq is "compaq"
If that doesn't work you need to use a jumpe on the motherboard:
This Jumper is often named like: "RTC_CLEAR" , "CLEAR CMOS" , "CLRCMOS" , "CLRCMS". His position is often near by the motherboard battery. You will need to reconfigure any BIOS changes that you have done.
Mar 17, 2009 | HP Compaq Presario V3000T Notebook
Can't get pass the blackscreen password
That is the BIOS password
Using the Motherboard "Clear CMOS" Jumper or Dipswitch settings
Many motherboards feature a set of jumpers or dipswitches that will clear the CMOS and wipe all of the custom settings including BIOS passwords. The locations of these jumpers / dipswitches will vary depending on the motherboard manufacturer and ideally you should always refer to the motherboard or computer manufacturers documentation. If the documentation is unavailable, the jumpers/dipswitches can sometimes be found along the edge of the motherboard, next to the CMOS battery, or near the processor. Some manufacturers may label the jumper / dipswitch CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD. On laptop computers, the dipswitches are usually found under the keyboard or within a compartment at the bottom of the laptop. Please remember to unplug your PC and use a grounding strip before reaching into your PC and touching the motherboard. Once you locate and rest the jumper switches, turn the computer on and check if the password has been cleared. If it has, turn the computer off and return the jumpers or dipswitches to its original position.
Removing the CMOS Battery
The CMOS settings on most systems are buffered by a small battery that is attached to the motherboard. (It looks like a small watch battery). If you unplug the PC and remove the battery for 10-15 minutes, the CMOS may reset itself and the password should be blank. (Along with any other machine specific settings, so be sure you are familiar with manually reconfiguring the BIOS settings before you do this.) Some manufacturers backup the power to the CMOS chipset by using a capacitor, so if your first attempt fails, leave the battery out (with the system unplugged) for at least 24 hours. Some batteries are actually soldered onto the motherboard making this task more difficult. Unsoldering the battery incorrectly may damage your motherboard and other components, so please don't attempt this if you are inexperienced. Another option may be to remove the CMOS chip from the motherboard for a period of time. Note: Removing the battery to reset the CMOS will not work for all PC's, and almost all of the newer laptops store their BIOS passwords in a manner which does not require continuous power, so removing the CMOS battery may not work at all. IBM Thinkpad laptops lock the hard drive as well as the BIOS when the supervisor password is set. If you reset the BIOS password, but cannot reset the hard drive password, you may not be able to access the drive and it will remain locked, even if you place it in a new laptop. IBM Thinkpads have special jumper switches on the motherboard, and these should be used to reset the system
Aug 15, 2008 | Computers & Internet
Computers & Internet Logo
190 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
