Question about Horizon Safety Magnet Key, Rope/beltclip-
Proform crosswalk 380 safety key
I want to order the safety key. thank you
I lost my safety key for crosswalk advanced 525x. How can I turn it on without the key?
1) I do not recommend to do this. because you must bypass the electronic circuit and you can damage many ICS. if you do not have knowledge in electronic digital. Remember the treadmill fitness is very High Tech machine delicated.
2) will be better go to www. proform.com go to customer service and then parts & manual and order the parts, the best solution.
sincerely.
Jul 12, 2011 | Proform Crosswalk 500 Treadmill
My Proform 380 treadmill will not run the incline goes up and down but the motor/ belt does not move
ADJUST 1) Reed swithc and optic disk.11_15_2011_9_21_16_am.gifIf after you did these adjustments Not work, replace the sensors.11_15_2011_9_21_36_am.gif
May 31, 2011 | Proform Crosswalk 500 Treadmill
I need a guide on how to change the belt on the crosswalk GT model no. 297390. Do you have a guide or manual that would help. thank you.
This is not a specific guide but a general tutorial for adjusting your treadbelt that may be helpful:
The same website also sells an owner's manual for the Proform 831.297390 crosswalk GT if you need to purchase a new one.
Alternatively, you can try Icon's service website and look for the manual for a free download.
Dec 24, 2010 | Proform 380 Treadmill Walking Belt
Proform crosswalk has no lights on the top panel. What can be wrong. There is light on the control board.
If you know how to use a multi-meter you will need to do the following:
Will need to disassemble upper console to 1.Check ribbon connection and continuity from upper to lower board 2. Check continuity of safety key switch 3. check dc voltage from lower to upper boards.
If ribbon is defective replace it. If safety switch is defective replace it. If lower board is defective get pricing for component If upper board is defective get pricing for component
go to icofitness.com
Feb 27, 2010 | Proform Crosswalk 500 Treadmill
The belt seems to slide to one side on my Proform Crosswalk 380. How do I fix it?
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Feb 27, 2010 | Proform 380 CS Treadmill !
Need replacement key
I ordered a key from the treadmill doctor site. It cost me 9.99 free shipping. I ordered the 1" Safety key for Proform & Weslo Treadmills 119038. It was a little thick so I sanded the rails on the bottom with a soft Kiss lady's nail sander. I only left a small smidgen of the rails on the key. Now it works just fine. The clothing clip is not as nice as the orginal, but is sufficient.
Jul 15, 2009 | Proform Crosswalk 500 Treadmill
Horizon Safety Magnet Key, Rope/beltclip-  Logo
35 people viewed this question
Top Horizon Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Trevor Turner
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
