Question about GE Washing Machines
How to open washer model ewa5600k2ww - GE Washing Machines
Is 10194450 the model # of my whirlpool washer
Hi Adrian, no this number is not a model number for a Whirlpool Washer. If you have a top loading Washer, you can locate the model/serial number by looking just under the lid around the tubs rim. If you have a front loading Washer, the model/serial number can be found by opening the door and looking around the opening of the Washer. The model number will begin with letters, usually with the letter W. We hope this helps.
Apr 05, 2017 | Whirlpool Washing Machines
Water leak from model 110 washer
Good Afternoon Doris, thank you for your post!
I understand your washer model 110 is leaking. However, it appears above-listed model number is invalid. The serial tag, which lists your model number, is typically located on the upper front, as you open the door.
Is your washer leaking through the back, from the side, underneath? With this information I can better address the issue at hand. Thank you!
Nov 25, 2013 | Frigidaire ATF6000ES Front Load Washer
May tag washer Neptune door won't open
what is your model number is then we can get started then
Oct 25, 2012 | Maytag Clothes Washer Dispenser Bezel...
I have a leak somewhere. How do I get the cabinet open and run the washer to see where it is coming from?
Below is a video to show you how to open the cabinet. The washer is a different model but it opens the same way.
Dec 31, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
With my old washer I was able to open the lid and it continued agitating. My new one does not allow me to open the lid while it is agitating. Is there a locking mechanism?
Whirlpool / Kenmore washers use a "Lid Switch" as a safety device.
On older models the switch would stop the spin cycle when the lid is raised.
Newer models stop both the Agitate and Spin cycles.
If this is a Sears washer see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
Oct 21, 2010 | Kenmore Washing Machines
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
Is door reversible on duet model GHW9100LW1
The technician informed that we cannot reverse the door on the washer.
Apr 09, 2009 | Whirlpool Washing Machines
Whirlpool Top loader
Open the lid and the model and serial tag is on the washer itself in the middle under lid in back. Open lid and look at area where lid and washer top come together between hinges.
Nov 05, 2007 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
