Question about Coffee Makers & Espresso Machines
Replacement blade for breville coffee and spice grinder Cg2b
SOURCE: Coffee will no longer grind.
ONE COMMON PROBLEM IN THIS MACHINES, SINCE THEY ARE MADE IN CHINA, THE QUALITY OF THE BEARINGS DETERIORATE IN ABOUT EXACTLY ONE YEAR. AND THE GRINDER NO LONGER WORKS. THE BEARING BUSHING ITS MADE OF BRASS, AND THE LOAD OF THE COFFEE BEANS OVER KILL THE BEARING. ITS A RIP-OFF....
Posted on Aug 24, 2007
SOURCE: Cuisinart DCC490SA 10-Cup Coffee Maker
Does the black plastic thing not lift out of the coffee maker? I just scrub the black bottom and clear top in the sink or run it in the dishwasher. HTH-
Posted on Jun 26, 2008
SOURCE: Breville cafe roma
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Posted on Jan 07, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: need new grinder
Cuisinart has the part directly- you can order from their website or over the phone.
Posted on Mar 08, 2009
  • 58 Answers
SOURCE: My Breville Keurig won't brew the coffee
Contact Keurig customer service at 1-866-901-BREW (2739) -- everyone i have spoken to was very kind and helpful
Posted on Jun 24, 2010
Change or sharpen blade on cuisinart spice and nut grinder
you can replace it by contacting cuisineart on line and or their toll free number provide the part # and they will send you another one it will cost you though
Sep 30, 2014 | Cuisinart Spice/Nut Grinder
Blade sharpening
you most likely cant sharpen them but replacing them is a better option. As for how, google your model # that you forgot to give us and you might find out how !!!
Dec 29, 2013 | Breville Coffee Makers & Espresso Machines
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
How do I clean the Black 3-oz. Coffee Grinder by Krups? Remnants of all the spices I used are stuck in the blade.
The best idea is to grind some rice to remove the spice pieces that are stuck. After doing this, wipe it clean with a paper towel or a cloth towel. Try not to get it wet, this makes all the spices get clumpy and it will be even harder to clean.
Jan 24, 2013 | Kitchen Appliances - Others
What is a good spice grinder?
I have had a few different spice grinders over the years and this one is my favourite by far. Just don't use it for both coffee and spices. If you want to also grind coffee beans, i would recommend buying a second one.http://www.cooking.com/black-3-oz-coffee-grinder-by-krups_111215_11/?ccaid=AFFL1&&/
Blade will not spin
While I don't have this brand or model of grinder, (coffee beans, spices?), I use a small elec. grinder for grinding coffee beans and unless the grinder and cover or perfectly lined up and locked in place, it willnot grind, a safety feature. Check and make sure everything is lined up so it closed with all the lines in place and the grinder is also put into the lock position.
Aug 21, 2011 | Cuisinart Grind Central DCG-20N Electric...
Severe clogging
Try using long grain white rice works better than minute rise, if that does not help, then the burrs need to be replaced on grinder.
May 12, 2009 | Breville Conical Burr Coffee Grinder -...
Breville cafe roma
Nov 14, 2007 | Breville ESP8XL Espresso Machine
Coffee Makers & Espresso Machines Logo
61 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
