Question about Whirlpool ET1FHTXM Top Freezer Refrigerator
Drainhole location on my Whirlpool 2004 freezer top frig?
I've got some pooling of water inside the frig and I'm thinking the drainhole might be plugged, but I can't find the hole. Help, anyone? Or is there some other solution?
  • MMQC Jan 24, 2009
    Thanks, Guru Man, for your timely suggestion. It was just the ticket and we're on our way!
  • 198 Answers
This will happen again, you need to install a heat probe to the defrost heater and have it protrude into the drain hole, You can get this probe at any appliance repair parts outlet, or use a piece of aluminum wire
Posted on Jan 24, 2009
    President:
  • Whirlpool Master
  • 2,651 Answers
Common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Jan 23, 2009
Water leaking inside my vegetable drawer
Just above the drawers is a drain hole on the back wall. Push a drinking straw or very thin brush down to unblock the drainhole and the water will drain away outside the rear into a pan on top of the compressor
Apr 30, 2014 | Kenmore 20.6 cu. ft. Top Freezer...
Drainhole gets blocked with ice proline fridge freezer
Sounds like the defrost cycle is too short! What is the make and model number?
Jul 10, 2013 | Refrigerators
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
I have an Electrolux Refrigerator FRT18B4AWA and it is leaking all over the floor. Temp holds good but the leaking won't stop. How to I fix it.
The most common cause is ice built up and plugged the drainhole as not defrosting Auto in time. Unplug the power de-ice. Locate the drain hole. Insert soft wire or cordto clear drain Open back of fridge. Locate drain tube and pan. And checkinserted wire or cord is coming out. Gently shake wires and pull out. That'sall. Now Drain tube is cleared. And also empty the drain pan, if water is huge to condensate.
Jan 28, 2011 | Frigidaire FRT18B4A Top Freezer...
There is ice built up on the freezer side. The ice is on the floor of the unit. How can I prevent this?
Behind the back wall of the freezer there is a defrost drainhole that is clogged. You will need to clear this drain so water from cols during defrost can drain to the pan by the compressor. Use a hair dryer and finish off with 1 cup very very very hot water to open completly . Hope this helps.
Feb 13, 2010 | Refrigerators
Water leaks inside,cant seem to locate drain. Water freezes in bottom of freezer,then runs down to the bottom of frig. I SEE a drain in the back right of bottom of frig but it sits up like a knob with...
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freezer
Nov 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Every few weeks the ice in my freezer melts. It
You will need to remove the bottom freezer crisper and check the defrost drain , to see if it is iced over . If so , then use a hairdryer to melt the ice ( hot water also helps ) . When you see the drain , ( could be obvious obstruction from plastic ) , use a small hose inserted into the hole , to blow thru , to remove any unseen debris blockage .
You may have to remove the rear inside freezer panel to access this drain , depending on your model number . So make sure the drainhole is open. When it happened to mine this was the problem.
Oct 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dripping from bottom of freezer casing
Your drain line is frozen. Ice thawed by the heater in the freezer normally drains down a tube into a pan on top of the compressor, where it evaporates from compressor heat. If the drain freezes the water runs into the freezer bottom instead of the tube then into your fridge. To solve this remove everything from your freezer and remove the access panel in the back or bottom depending on your model of fridge. Turn off or unplug the appliance. Upon removing the panel(s). you will likely see that the bottom of the freezer is full of ice. Use a hair dryer or heat gun to thaw ice and remove. In the very back bottom you will uncover the drainhole. I usually use very hot water and a shop vac to thaw the drain hole. When you finally clear it you will hear water running into the pan on top of the compressor. Somethimes it takes a lot of hot water to clear the drain. Hope this helps!
Jul 08, 2009 | GE Refrigerators
Water inside bottom of freezer after defrost cycle
Oct 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool ET1FHTXM Top Freezer Refrigerator Logo
300 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
