Question about Saws
D28770 blade keeps derailing - Saws
  • amh447 Mar 18, 2009
    I have a model 113248322 bandsaw . when I turn it on the blade derails and the rubber on the top wheel comes out of the groove at least half it's width. It seems to still have elasticity and fits well in the wheel goooves. it will derail in 3 seconds
Uncle Vic says " If you want your 16" --3 wheel Delta saw { Cat # 28-560} to work, you must have patience.
It's old and has a bad reputation. They don't make it any more, and haven't in many years. The 2 wheel saws are better, but you don't have one; right?
If you want production from this saw, forget it. It must be coddled. If you haven't patience, just sell it quick and buy a better one.
I'm old and the saw and I can produce some good work if you are patient with us.
Here's what I did. I replaced the rubber drive-wheel covers- Lubricated all bearings-installed new blade guide blocks and CAREFULLY adjusted everything to it's centered position.
You cannot " Horse" this saw. If you are careful, you can get it to cut whatever you have the proper blades for. The cut radius is limited to the blade installed. Good luck
Posted on Mar 12, 2009
I need to order a new tire for 12 in. jet bandsaw but i can,t find a place to order one
Posted on Jan 26, 2009
3 Suggested Answers
SOURCE: blade keeps derailing
I am not sure why you took the guides off in the first place,   That is definitely related to the problem but is it possible that taking those guides off created a deeper problem?
Posted on Feb 19, 2009
  • 7 Answers
SOURCE: d28770 dewalt bandsaw derails blade
Over-tensioning the blade can and does cause the blade to "crawl" off.
Posted on May 04, 2009
Windshield wipers do not shut off on my mercury grand marquis 2006
Could be the wiper stalk. Also could be the wiper motor derailer. The derailer shifts the internals of the motor to a last cycle so the wiper finishes the stroke cycle and parks the blades.
The problem is you need a signal from the wiper stalk to make the derailer work. You would need to read a wiring diagram and find out if the signal to the derailer is reaching the connector for the wiper motor. If the signal is coming from the wiper stalk, then the wiper motor is not responding when it gets the signal. Then the wiper motor is bad.
Nov 10, 2017 | Mercury Cars & Trucks
I need to replace the gear oil in a Dewalt D28770 portable band saw. what type of oil do I use
I suggest you buy the gear oil from Enco. And buy blades on sawblade.com
May 25, 2014 | Saws
Roper snowblower drive chain keeps coming off
sounds like you have either stretched chains or worn sprockets. Also check the outer bearing that the shafts fit into for wear. If they wear then the chain can't retain it's tension properly, get sloppy and then derail itself. Most likely your bearings is the problem.
Dec 02, 2013 | Craftsman 16" High Garden Tractor Snow and...
Blade walks off the drive wheels
If the blade is walking off the wheels, the wheels are out of alignment with each other. This can be caused by loose screws that hold wheels on their pulley shaft, a worn or lose pulley shaft, worn or broken bearings, ect. Anything that holds or supports the wheels can be lose or worn to the point the wheels are out of alignment which affects the tracking of the blade.
Jan 24, 2013 | Dewalt D28770 Hd Deep Cut Variable Speed...
Chain ****
Scott, this sounds like maybe the derailler is not taking up the slack in the chain. You might not be threading the chain through the derailer correctly, or the spring in the derailer is not working. Maybe if you could post a picture of the folded chain and a picture of how the chain is threaded through the derailer I could help you further
Apr 03, 2012 | Norco Six SE
D28770 dewalt does not turn the blade. Light works and switch works but not even a hum from the motor.
Check the brushes, if they are worn down to where they are not making good contact with the armature, the motor won't work.
If the brushes are OK you may have to have the armature tested to make sure it doesn't have a short in it.
Mar 05, 2012 | Dewalt Saws
Both of my derailers seem to be frozen. I have already tried spraying them with a lubricant & nothing. It is no longer under warranty & am looking to fix it my self before taking it to a shop.
first disconect cable from derailer and determin if its the derailer or the cable. if its the cable take it off coil it up put it in a can with wd40 or other penatrating oil . if its the derailer take the chain off and work it free by hand keep putting oil on it while you work it back and forth
Jul 08, 2011 | Diamondback Response Sport Mountain Bike...
D28770 dewalt bandsaw derails blade
Jan 26, 2009 | Saws
Blade keeps derailing
Jan 26, 2009 | Dewalt Saws
Saws Logo
289 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
