Question about Mitsubishi WD-62531 Projection Television
New lamp, now color variation, dull picture and overheating
We just replaced the lamp on a Mitsubishi WD-62531 and when we turn the TV on, the screen shows red tones on half and green tones on the other half. The picture is also very dull. Also, TV started to smell hot. Help, please!! Thx
  • 59 Answers
It sounds like if your tv is a dlp the colorwhele is stuck
probibly because a after market or faulty bulb has melted it
get serviced imedietly
Posted on Jan 23, 2009
I have a Mitsubishi WD-73835 and just replaced the lamp with a Mitsubishi OEM replacement lamp w/housing. The picture is not nearly as bright as it was with the original lamp, as a matter of fact it is...
Yes,it is the projection lamp.Recheck ur installation of the projection lamp and wires input connections again.If still have the same problems,the projection lamp have bad radiation fillerments inside.U got a projection lamp that was not in wright temp. in the warehouse storage it to hot or to cold,that why causing this damages to the radiation fillerments to the projection lamp.
Nov 17, 2010 | Mitsubishi WD-62531 Projection Television
Were is the lamp cover of the mitsubishi WD-62531 at so i can change the lamp
It's on the back of the tv, located on the left while facing the back. There are 2 screws holding the lamp cover and 2 more holding the lamp.
Sep 14, 2010 | Mitsubishi WD-62531 Projection Television
I have a 62 inch mitsuibishi dlp you hear the sound but the picture is off were can i buy a wd-62531 lamp cartridge
Hi
Thanks for using FixYa. You can buy the lamp from this link:
Mitsubishi wd-62531 Parts
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Mitsubishi WD-62531 Projection Television
The picture is dull, what i have to do for the TV?
The usual cause of the DLP's geeting dull is the front small projection mirror gets dusty and needs cleaning. The mirror is located dead center in the front after removing the screen assembly. Its a small mirror directly in front of the lens assembly of the light engine.
May 10, 2010 | Mitsubishi WD-62531 Projection Television
Screen discoloration
try going to this link - http://www.retrevo.com/support/Mitsubishi-WD-62531-TVs-manual/id/564ag724/t/2/ all tips and tricks in troubleshooting your HDTV you may find it here. Hope this Helps...
Nov 03, 2009 | Televison & Video
Mitsubishi WD-62531 Replaced lamp 2 weeks ago. Red light flashing again. Same problem but the lamp is fine. Sound but no picture.
You have either a bad ballast (it powers the lamp) or a bad DMD board. Either one of those will result in a no lamp fire issue. Have a technician look at it...
Oct 17, 2009 | Mitsubishi WD-62531 Projection Television
Color
If the tv looks now dark this is the first symptom of a lamp replacement (refer to the user's manual to do this job) and get a Mitsubishi original replacement.
the best picture setting (when the lamp is back of course) depends in the light of the room.
Now if after replacing de lamp and playing with the settings and the screen still pale, dimm, not enought color. a cleanning in the reflexion area is needed. (technican job)
Apr 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green Blinking Light plus Red Lamp Light
You lamp bubl has burned out. You need to replace the bulb. you can order a new bulb on line by searching the web using your model number bulbs are about $110 if you reuse the cartridge and replace the bulb only. replacing the whole cartridge and bulb is around $ 200
Nov 27, 2008 | Mitsubishi WD-62531 Projection Television
Mitsubishi WD-62531 Projection Television Logo
418 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
