Question about Linksys Computers & Internet
The HNAP call failed because HTTP connection was broken.
When setting up router following CD instructions. Message suggested we check connection to computer but the cable connecting computer to router is connected. What is the remedy to enable internet connection?
roadhawk
  • 25 Answers
SOURCE: Internet connection fails very frequently!
I will try to see if I can Be of some help...But first I need to know who your ISP is. Also I note that you indicated that you try to renew and release you do not show DHCP connected. You should be doing release and then renew, I believe that's what you meant to say? Also please describe to me how you attempted to set up static IP.
Awaiting your info...!
Posted on Jan 04, 2008
  • 12 Answers
SOURCE: no internet connection on web browser
The problem may be in the router itself, prehaps a faulty product. But I am more inclined to think it is the outdated copy of windows 2000 which you use. In my view 2000 was second to Windows ME in terms of faults, errors, recoginizing hardware, and what have you. I would take the router back to walmart and test with a new one, but if that does not help, then it may be time for you to upgrade. Have you tried getting the ps3 online even without the computer having an active connection? Give that a shot and if for some reason the ps3 grabs the signal then it is time to give in for sure man. And watch the router when you try to connect the ps3 to see if it even attempts to grab the wireless connection, the wireless light will start blinking rapidly if it does.
Posted on Jan 25, 2008
  • 1214 Answers
SOURCE: Connection Failed
First, have you done a master hard reset of the router by depressing the hidden button on the back of the router?
2nd, what Operating System are you running?
Reply back and I can give you more information/instruction.
Posted on Feb 16, 2009
  • 20 Answers
SOURCE: Problem between my Qwest actiontec modem and D-link router
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
Tip
Solved Problem on Limited Or No Connectivity error message
Solving Limited Or No Connectivity error message
On setting up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
Here's How:
Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. If your network access is non-functional. continue to the following steps.
If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
If your connection remains non-functional, run the Windows Network Repair utility on your computer.
If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
www.temabcomputerssolution.blogspot.com
on May 20, 2010 | Computers & Internet
Error code 80001000A, ZyXEL 660 router. PS can find ip address and connect to internet but as soon as i do anything internet based the connection drops and i get this error code among others but this is...
Go over the instructions at this link carefully http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
If the connection still fails after following these instructions, follow the on-screen instructions to check your settings. You may have to get some info from your ISP and refer to the instructions supplied with your router.
afor more help visit CBR Tech Solutions
Jul 26, 2011 | Sony PlayStation® 3 (60 GB) Console
I am a novice so how do I install it?
It should have come with an installation disk, please insert this disk in the CD-ROM then follow the on screen instructions of the wizard.
If you do not have the disk, message again and I can assist with further instructions.
Mar 02, 2011 | TP-LINK TPLink (TLWA730RE) Wireless Router
I have been running a Linksys BEFSR41 version 2 wired router for over 5 years without any problems. My wife is a teacher and her school p[urchased new laptops recently so I decided to go wireless. Got on...
I think the most likely problem is that both routers are using different IP address ranges and won't allow data to pass between them.
I suggest you use only the Linksys wireless router.
Nov 17, 2010 | Linksys Wireless-G WRT54GS Router...
I have followed all the instructions but at the end it failed to connect to the internet
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Jul 13, 2010 | Linksys Wireless-N WRT150N Router
My router was working fine until I upgraded from Vista to Windows 7 and then tried 192.168.1.1 to check my router settings and I went to a google search page and not the router configuration so i used the...
HI Friend
please follow the steps
1. Turn on the router and connect the desktop to router
2. push and press the reset button,which is at the back of router, for 30 seconds and after that turn off the router for 30 seconds and turn it on after 30 seconds.
3. Now open 192.168.1.1 and check your router settings.
4. If the internet does not works then in the router setup page click basic settings, click MAC address clone
5. Select the enable button and click the Clone tab. Click save settings and turn off the router for 30 seconds.
Enjoy
Regards
Chiranjeet
Dec 27, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
My cd disk drive is broken how do i install my
First reset all settings of router to default.
You can reset it with RESET button it is in back side of router press It for 10 seconds.
Then connect your router to computer with ethernet cable.
Then access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
then configure your router WAN settings as your internet service provider settings.
Go to wireless enable wi fi .
Then save all settings then check.
Also enable DHCP if you want ip addreses automatic from router.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
Sep 08, 2009 | Computers & Internet
For our two computers on wireless...we get that
If you use a cable modem use this link
http://kb.netgear.com/app/answers/detail/a_id/119/session/L2F2LzEvc2lkLzFpNTYybEVq
if you use dsl use this link
http://kb.netgear.com/app/answers/detail/a_id/120/session/L2F2LzEvc2lkLzFpNTYybEVq
follow the instruction on these sites to make sure that your router had the right settings, or use the instalation disk that came with the router to set it up. Since you get a message from our network that the signal is good you know that you are connected to the router.
Aug 01, 2009 | NetGear WGR614 Router
Cannot connect d link 1310 to imac
ignore the cd, temporarily,
try to connect to the router via its web interface at http://192.168.0.1
the wizards and helpscreens on the router if you can reach it are very good
the default admin name is admin password blank
which the wizards ask you to change once you get started.
For guest, check the settings on the macbook,
it may be configured to always ask for password,
a blank password may be valid
it may be configured to login to a domain, which it cannot find
Apr 17, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Computers & Internet Logo
81 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
