Question about Kenwood KR-V7080 Receiver
How to change battery on kenwood kr-v7080 receiver
Having problem on short memory storage on pre set channel
  • 319 Answers
SOURCE: problem with playing my Kenwood KR-X1000
Unit apparently has problems. Check/replace batteries in remocom
Posted on Aug 14, 2008
  • 35 Answers
SOURCE: Hi, I can't figure out
Here is a link to the manual:
http://www.kenwoodusa.com/Support/Home_Electronics_Owners_Manuals/#_
Posted on Nov 23, 2008
  • 10 Answers
SOURCE: receiver cuts in and out
Sounds like a cold solder to me or maybe an oxidized terminal but could be something more simple.
1- If the unit still has power but no sound - Try and reseat the jumpers on the back of the unit - top middle (adapter unit)
2- If you are tapping near the speaker button it may have dirty terminals and may be cleaned with some electronics cleaner. One way to diagnose this is switch it off and on several times and see if it changes.
3- If tapping on the front panel makes it start working - can you duplicate it going back out by tapping? This may be a cold solder on the ops panel. If you have some soldering skills this may be an easy find and fix. If not you may need to take it to a repair center. By no means operate on the unit with power to it with the cover off!
Posted on Mar 25, 2009
MNfisherman
  • 11896 Answers
SOURCE: need a code for universal cox cable remote to turn on and off Kenwood KR-V-8040 Receiver
[PDF] Cox Manual File Format: PDF/Adobe Acrobat - View as HTML
not respond to the Cox Universal Remote Control after trying all of the codes listed for your brand,or if your brand is not listed at all,try searching for ...
www.cox.com/support/digitalcable/hdtv/pdf/Universal_Remote.pdf - Similar pages
  1. More results from www.cox.com »
  2. Universal Remote Control Codes Apr 17, 2009 ... More Cox Remotes, Includes Cox Digital Interactive, Universal DVR, Navigator, Millennium and Model ER1 PDF manuals. Cox Universal Remote ...
    www.xdiv.com/remotes/ - 73k - Cached - Similar pages
  3. How to Program a Cox Universal Remote for Your TV | eHow.com How to Program a Cox Universal Remote for Your TV. Have you ever dreaded programming your universal cable remote for your TV? Many people put off this very ...
    www.ehow.com/how_2153479_program-cox-universal-remote-tv.html - 52k - Cached - Similar pages
Posted on Jun 01, 2009
SOURCE: Need info on a Kenwood KR-V106R Receiver.
been awhile but according to the manual, this model is set in stadium mode only.
Posted on Nov 12, 2010
How to hook up a pioneer 7 band gr 470 equalizer to a Kenwood kr-v6030 receiver
Connect one pair of RCA cables between the receiver and equalizer. Connect one pair of cables to the pre-amp output channels on the receiver and the other end of the cable to the left and right channel inputs on the equalizer. You will usually find these channels on the rear of the equalizer.
May 09, 2016 | Pioneer Audio Players & Recorders
One channel has no bass. what should I check first under the cover
No bass like speaker isnt working? If so first thing a would try is switching speakers...If it fixes that channel then its your speaker.
Mar 23, 2016 | Kenwood KR-V7080 Receiver
Kenwood KR-V7080 reciever will not play through speakers.I can still plug headphones into the reciever and get audio but not through the speakers. Tested the speakers and they still work.
If the speakers used to switch off when the headphone plug was put in the socket, suspect the socket it goes into as being the trouble. It is clearly not connecting the speakers, when the headphone plug is removed.
Aug 17, 2015 | Kenwood Audio Players & Recorders
How do I hook up my HD TV to the kenwood kr-v7080 so I can hear stereo TV ?
Maybe hook up the actual source of the TV audio (not necessarily the TV) directly to the Kenwood. Cable and SAT boxes have nice standard digital audio outputs. They're wasted on TV's which typically have sucko speakers. Lower-end analog audio is also available if you want to watch Cable/SAT throught the TV speakers.
May 17, 2011 | Kenwood KR-V7080 Receiver
My kenwood amplifier suddenly off when i turn the volume high?
You need to make sure you ohms are correct if there too low this will happen to protect the amp.
Dec 03, 2008 | Kenwood KR-V7080 Receiver
No power to the receiver
Go here for the manual:
Then follow procedure on pg 2 of the pdf. Check that the voltage selector is set correctly.
Then try the procedure on page 36: Operation to Reset.
Aug 19, 2007 | Kenwood KR-V7080 Receiver
Station Preset Memory Lost When Power Off
Have same unit, exactly the same problem: station presets lose setting when power is off. I've opened the unit; there is no apparent battery of any kind.
As long as the unit is powered up, the station pre-sets seem to hold. There IS a capacitor across the power switch. Some A/C will therefore be transmitted into the unit when plugged in, even with the switch off. If the capacitor is open, no charge will enter the unit when the power switch is open. I will probably replace this capacitor and see if that fixes things, but it may take several days to do so. Has anyone else tried this?
Feb 02, 2007 | Kenwood KR-A5080 Receiver
47 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Eddie Dalton
Eddie Dalton
Henry  Thomas
Henry Thomas
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
