Question about Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX
I have poulan 2075oc that floods out as soon as u pull started rope.you pull it one time and spark plugs is real wet with gas.Saw set for long time with gas in tank and i had to replace all the fuel lines and fuel filter but couldnt find any thing else wrong with it. Fiklled it with fluids and it started on about 3rd pull and run fine.I even sawed a little with it.Today i went to start it and this is what happened.Cant figure it out.Any advice would be greatly appreaciated.f Thank u Carroll Fetcher
  • 181 Answers
You need to open the carb up and take the old fuel line out of the carb filter.....if it is left.the needle is probaly stuck in the open possition letting to much fuel to go to cylinder
Posted on Feb 17, 2009
How to start poulan 18 inch wildthing chainsaw
Hello Wade,
There should be starting instructions on back on saw, if not its usually the same for most saws. Fill tank with proper mixed fuel. Add bar and chain oil if necessary. Pull knob out to "start" position. Pull choke all the way out. Prime unit 6 times. Place saw firmly on floor, slide right foot under handle and have left hand firmly on top handle. Pull throttle and lock it in high. Pull rope 4 to 5 times until unit pops.Then, set chock lever on half.(this is usually pushing in half way). Pull rope again 4 to 5 times until unit starts, then after 30 seconds or so push choke knob in to turn choke off. If this procedure doesn't work, give it 10 minutes or so, because unit may be flooded, then try again. Good luck!
Sep 28, 2013 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Earthquake cs4518 wont start
pull the spark plug out and check it for wetness. you may have flooded it unknowingly so it won't start. if it is wet, blow it off or let it air dry. turn the saw so the spark plug hole is facing down and pull the rope a few times to clear all the excess fuel out of the cylinder. put the plug back in and with NO choke try starting it again. if the plug isn't wet let me know and we will see if we can figure something else out
Feb 16, 2013 | Earthquake Chain Saw - CS4518
I just bought a new Poulan Model P3416 chaisaw (34cc) and I have followed the starting instructions and have not been able to start the saw. I have even varied the instructions but no luck. Any thoughts...
see if your switch is in run position and then pull your spark plug out see if it is wet, then see if it is sparking when you ground it and pull cord to roll over, if all is good hold throttle wide open and crank over without choke on, probably flooded, good luck
Aug 19, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
Crank rope extreemly hard to pull.
Take the spark plug out to see if there is fuel in the cylinder...drain it out if there is lubricant in the cylinder.....pull the rope a few times and then go back to normal start procedures.
Feb 07, 2011 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Chain saw won't start - pull starter pulley hard to pull?
If it worked fine the last time you used it, then pull the spark plug and try pulling the rope. See if it's easier or if gas shoots out of the plug hole. I've seen this happen when the diaphram in the carb goes bad from sitting over winter. It loads up the cylider with fuel and makes it very difficult to pull the rope. If there is no fuel in the cyliner and it's still hard to pull, make sure there is nothing binding the clutch/sprocket. I've had chucks of wook lodged in there that caused it to bind the crank output, which resulted in a hard pull on the rope as well.
May 26, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
NO SPARK, HAVE NEW PLUG BUT IT CONTINUES TO FLOOD.WHEN I TRY TO PULL START, THE PLUG JUST GET WET, PROBABLY IN THE FUEL AIR MIX ADJUSTMENT. HOW DO I CORRECT THIS? FUEL ALSO COMES FROM EXHAUST.
If raw fuel comes out of the muffler then you have an extreme flooding condition. There are no Model Numbers to tell me which type of saw we are working on but this works most of the time.
Try this: Remove the spark plug and BE CERTAIN the stop-switch is in the OFF position. Take the saw outside and bring a fire extinguisher with you! Hold the saw by the rear handle and let the muffler hang down to the lowest point possible. SLOWLY begin to pull the starter rope and observe the fuel being pumped out of the muffler. Gradually increase the speed of the rope pull and get as much fuel out as possible. When satisfied that it's dry, it isnt. Use compressed air to LIGHTLY blow into the spark plug hole and continue to pull the rope. (Might need 50 or more pulls!) Blow the spark plug dry and reinstall it.
Turn the switch ON, leave the choke OFF, and hold the trigger wide open. Start the saw and allow it to run at full throttle until it clears out all unburnt fuel and has good throttle response. If you need further assistance reply to this post with the make and model of the saw and I will be happy to help.
Hope this is helpful,
Dolf-
Oct 19, 2009 | Garden
Will not start and doesn't even fire. New saw used once. New mixed gas added and sill no fire. Acts like the on/off switch is not operating properly??
Take the saw outside and have a fire extinguisher handy.
SCENARIO #1)
With the switch in the OFF position, remove the spark plug and SLOWLY pull the rope.
CAREFUL HERE!
If you notice raw, liquid fuel coming from the spark plug hole you have a fire hazard in you bare hands!
Gradually increase pulling speed to see if you notice any fuel vapors or mist coming from the spark plug hole. If you do, you have found the problem: It's flooded.
Continue pulling rope and use an air blow gun to LIGHTLY blow into the spark plug hole and dry the cylinder. You should pull 20 or 30 times while blowing air in.
SCENARIO #2)
If the cylinder is bone dry reattach the spark plug wire to the plug and touch the outer shell of the plug (or the threads of it) to a metal surface on the saw's engine (AWAY from the spark plug hole!) You can use any metal object to conduct the electricity and increase your reach if needed. Turn the switch back on and pull the rope medium speed and check for spark on the electrode of the plug. If no spark, turn switch to other position and repeat.
NOTE: IT WILL NOT SHOCK YOU as long as you maintain contact with the outer shell of the spark plug and the engine's metal parts.
If spark is present, reinstall plug and try again.
Be sure the choke lever is set properly for either cold or warm starts (whichever applies) and it should start easily for you in the future.
Hope this helps!
Sep 28, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro 18 inch saw. Once the unit is warm it
start saw when cold and work it hard. if it stalls or quits remove spark plug and hook the plug wire to the plug and ground to the cyl head have switch on and pull the start rop briskly a few times or use a test plug. if there is no spark disconnect ign switch from from the ign wires and pull rope a few more times.spark?= replace ign switch,no spark until engine is cool,replace coil.
Sep 23, 2009 | Poulan Pro Chain Saw 46cc 20"
My poulan chain saw sat for about 2 yrs with gas in it. I emptied the tank, put new gas in it along with a carburator cleaner but it will not start. lost the manual for it and don,t know which position to...
Empty out the gas and replace with proper gasoline mixed with oil in the proper proportion. Always use a good quality 2-cycle oil that contains a fuel stabilizer.
To start the generic chainsaw, follow these steps:
1. Pull the choke all the way out
2. Press the fuel bulb serveral times to prime the carb - you can feel when the fuel flows into it.
3. Set the lock on the trigger to full speed.
4. Now, pull the starter rope until the saw sounds like it tried to start.
5. Press the choke in to the 1/2 way position.
6. Pull the rope until it starts.
7. Release the trigger lock and push the choke all the way in.
If starting it when it is warn, skip steps 1 and 4.
It is unlikely that the spark plug is the problem. If you replace it without properly setting the gap, you may make it worse. If you start trying to adjust the carb without knowing exactly what you are doing, you will make it much worse, You can try spraying some carb cleaner into the carb and pulling the rope to such the cleaner into the jets.
In the future, always add fuel stabilizer or oil with a stabilizer to you gas/oil mix. This prevents the varnishing caused by aging gasoline.
Jul 11, 2009 | Poulan Garden
Wild Thing-(18")hard starting
I own the Poulan Chain Saw the Wild Thing. Replaced the spark plug and fuel filter and made a fresh batch of gasoline mix and I am still having a hard time getting it started. I had the exact same problem last fall. Repair shop told me it was flooded. If this is the case how do I resolve the problem. I took the plug out and it was dry.
Thanks,
**** Hansen
Oct 30, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 16-Inch 38 cc Anti-Vibration Chainsaw #PP3516AVX Logo
175 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
