Program remote for yamaha rx v850 - Audio Players & Recorders
SOURCE: remote controll
Try these: 0055,0605, 1095....taken from my RX 520 remote codes...might work.
Posted on Sep 08, 2007
  • 236 Answers
SOURCE: yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
redrivera0314@yahoo.com
Posted on Mar 19, 2008
  • 50 Answers
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
Posted on Jul 06, 2009
smarthome2
  • 1114 Answers
SOURCE: Yamaha Rx-v365 trying to program remote for
Press and hold "DTV" then, while holding doen DTV, press power and hold for three seconds. Release both buttons and enter your code. The front panel of the receiver will say "remote setup ok" or "NG" (no good) That being said; while you are in the process of finger acrobatics! make sure your remote is pointing in the general direction of the receiver. Yes, it's a pain, however, once your done, the Yamaha remote is a champ! Hope this helps.
Posted on Oct 01, 2009
Tempus Fugit
SOURCE: Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Posted on Dec 14, 2009
Do I need to connect my older Fisher Turntable to a pre-amp before connecting to my Yamaha RX-V850?
No, you don't need a preamp if your turntable has a moving-magnet (MM) cartridge, it should work as-is! Happy vinyling =]
See page 27 of the manual:
Yamaha RX V850 User Manual Page 27
Aug 09, 2016 | Yamaha Rx-v850 Audio Video Receiver Black...
I need codes for a Yamaha rx-v2500 receiver. The codes listed turn it on but not off. Can you help??
Joseph, codes 0081,0082,0176, 0186, 1176, the attached manual may have more codes.
Yamaha rx-v2500 receiver, try the auto programming feature on your remote to set up universal remote. It is possible the remote may not support your equipment and you will have to replace with compatible remote. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RC Yamaha RX V2500 Receiver and DVR PVR 5 HELP
Codes for Universal Remotes Codes for Universal Remotes How to Program Universal Remote
Yamaha RX V2500 Owner Manual Setting Remote Control Codes
Aug 08, 2016 | Yamaha Audio Players & Recorders
How to connect my lg lcd tv to yamaha rx-v850
Use the Component Out sockets (RCA sockets - Yellow , Green , Red yes 3 wires) on TV to Component In sockets on Receiver which is again 3 wires
Jun 14, 2015 | Yamaha Rx-v850 Audio Video Receiver Black...
Rx v850
Are they connected and turned on. First read the instructions they contain some amazing information.
May 04, 2014 | Yamaha Audio Players & Recorders
Yamaha rx v850 centre and rear speakers dont work
-- Are they connected and turned on. First read the instructions they contain some amazing information.
How do I connect the Bose Equalizer (for Bose 901 Series VI speakers) to a Yamaha RX-V850 RS? (not as a home theater) Thanks
If you get a second amp for the 901's you can have your cake and eat it in front of the TV too.
http://www.retrevo.com/support/Yamaha-RX-V850-Receivers-manual/id/320bh027/t/2/
Two solutions:
ONE: dedicated 901-RX-V850 stereo-analog-audio only:
If you want to have the Yamaha also support non-901's as the second set of Front Speakers, put the Active Eq in one of the three selectable Tape Loops. That way you can dial the 901 EQ out of the equation and select the 'normal' speakers for your Dolby Surround video experience.
Now imagine this:
TWO: 901's for the Front on a 100wpc stereo amp, your RX-V850 or a nice digital AVR driving center and rear, maybe 'normal' fronts, too
Get a nice 100wpc amp with its own volume control on eBay and slave it off the Yam. Remove the Front Pre-Main jumpers and place RCA Y-splitters in there so the pre-main connection out is maintained but shared with the Active EQ, which is in series with the 901's dedicated amp. Use the new amp's volume to match the 901's to everything else and you just have to turn it on or off to enjoy the 901's along with or instead of the 'normal' front speakers. You could even just disable them at the Yam.
Now for some boilerplate I created to get your creative juices flowing ij case you have a digital AVR in mind for the future:
Having a 901-based multichannel setup myself, I would highly recommend getting the Full Monte for video listening (below)...
In that case a separate stereo amp for the 901's would work. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers.
You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W). Run it with the Active EQ between the receiver Front L&R Pre-Outputs ** and the 901's amp channels.
** Front Pre Out (or one of your analog Tape Outs) >>> Bose EQ Amplifer IN, then
Bose EQ Amplier OUT >>> new amplifier IN.
Then set the new amp's volume control (if it has one, mine doesn't) to something HIGH and run through your speaker setup routines on the Yamaha. After levels and distances are set the Yam will be the boss of the 901's. I recommend sharing or directing any LFE with them. With 901's don't even need subwoofers but they don't hurt.
I've done this in my own setup once. Turn the 901's around so the rear faces point into the listening area. Crank up Master and Commander and when the waves are crashing or cannon are firing you WILL FEEL A BREEZE from them. Now THAT is multi-media!
Jan 17, 2011 | Bose 901 VI Main / Stereo Speaker
Display illumination is out
If it is Yamaha,that model is obsollete,you have small chances to fix it
Nov 24, 2009 | Yamaha Audio Players & Recorders
I need a display bulb for a yahama rx- v850 av reciever
The display bulb is a 14 volt bead style lamp about 0.150 inches wide with wire leads. You'll need to cut the old bulb off the two -pin cable assby and wire the new lamp into the existing wires.
partsexpress.com
mcmelectronics.com
or
studiossoundelectronics.com should have lamps for that
Jan 11, 2009 | Yamaha RX-V461 AV Receiver
I just purchased a yahama rx- v850 av reciever
if you dont mind a lettle customization, just go to radioshack and set your favorite color l.e.d. and wire it in, if you can find a specs diagram for your reciever, you might look up voltage and wattage of the bulb so you can get appropriate resistors for the led, and install that. itll last forever, cost virtually nothing, and its easy to do.
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
101 people viewed this question
 Grubhead
Grubhead
