Question about Splendide 2100XC
Splendide 2100xc door wont open - Splendide 2100XC
2 Suggested Answers
allbrands
  • 600 Answers
SOURCE: How do I replace the drive belt for splendide
Hello, Thank You for using FixYa. I will be helping you today.All you have to do to replace the belt is remove the back panel and you will be able to replace it. Hook it on the motor pulley first then turn the tub pulley while holding the belt on to roll it onto the tub pulley.
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Posted on Jul 06, 2011
Splendide 2100xc wont dry
check heating element and thermostats fuses
Feb 08, 2015 | Splendide Washing Machines
Cycles won't advance
the module board is bad and needs replacing. it controls all the functions. it's at the bottom right rear corner.
Feb 28, 2014 | Splendide 2100XC
Error code is 1 flash
my splendide 2100xc will not go off the dry mode?
Feb 05, 2014 | Splendide 2100 Vented Washer-Dryer
Washer will not pump cold water, but it will hot
Cold water inlet selenoid/valve is broken or power cable to same is off.
Dec 07, 2013 | Splendide 2100XC
Fabric softener well is full of water. No room to add more softener. Can the insert be removed for cleaning?
Is there any chance you could fit a small towel or sponge inside? You could drain the water out rather than take it apart
Jun 01, 2013 | Splendide 2100XC
Lock door blinking along with the low heat pre-wash also
I just had the same problem. I called splendide. First thing they asked me was if this was happening when I was trying to dry. And, it was. I was told lint clog and that there is a cycle you can run to hopefully clear it. Below is the instructional e-mail they sent immediately. Love the company - tech service on the phone is wonderful. :)
e-mail from splendide:
Run the unit without clothes and with the dry time off on cycle # 11. When the water stops entering the unit push and hold the start button until all the lights come on then release the button. Next, move the cycle knob to cycle # 2 and press the start button once (do not hold) then let it run through that complete cycle.
Nov 10, 2010 | Splendide 2100XC
Storage for year. Will not drain. Washes correctly. Buzzes when pump should work. Two green lights and red light flashes.
The door inter-lock switch is likely bad. Call Westland Sales and ask them to send you a new one. In the meantime, you might be able to use a screwdriver to release the door manually.
Michael Lee
Thor Appliance Company
http://www.thorappliances.com
Sep 19, 2010 | Splendide 2100XC
Door lock not engaging on our spledide XC 2100
I'm Sorry to post a complete "Gerry Rig" solution to the problem: I inserted a plastic clip in the door lock to fool the machine that the door was locked; removed the clip then secured the door with a tension rod. It ran its full cycle without a leak. I think the plastic door mechanics was inadequately engineered. Our Machine is less than 6 months old?- Im on the road & have to make things work on the fly. Warning my next fix might include Duct Tape Good Luck Everyone Kevin_ByDesign
Jul 20, 2010 | Splendide 2100XC
Splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Sep 19, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100XC Logo
51 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
