Question about Carrier LFP Humidifier
Humcclfp1418 owners manual - Carrier LFP Humidifier
Need essickair humidifier manual
Follow the provided web link. Select from the appropriate category of humidifiers by Essickair, then click on the "More Info" link after which you should choose the specific model humidifier that you own. After doing so you will find a link to the lower right(under "Resources") saying "Owners Manual."
Clicking that Owners Manual link will allow you to open and/or save your humidifiers manual.
Oct 18, 2013 | Honeywell HE360A1027 Whole House...
Is set to 60 end is no water coming
First, is the saddle 'T' valve open on the water supply line? If it's not turn it ON no water can fill the tank. If after that, it doesn't work, there may be a problem with one of the solenoids.
I have included a link to your Owners Manual, which may be of assistance, since it has a Trouble Shooting Guide.
http://www.autofloparts.com/manuals/autoflo-sc15-250-owners-manual.pdf
Hope this helps you.
Rich
Feb 07, 2011 | AutoFlo 250 Humidifier
Should water be continualing running through the drain tube?
Water will flow over the filter pad as long as the unit is calling for humidity. once the unit is satisfied the solenoid valve should stop the water flow. if the water continues to flow with out call then solenoid valve has failed open. hope this helps.suppling an owners manual in case you need one.
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
Dec 21, 2010 | Aprilaire 600 Humidifier
My Aprilaire humidifier is not working, even with humidistat in TEST position
May be an issue with the solenoid valve. check for voltage at the valve. if there are error codes check the owners manual for cause. I am providing a link to the manual if you don't already have one. the last thing to check would be the control itself. the control and the solenoid valve are the 2 main items for the unit. hope this helps.
Dec 21, 2010 | Aprilaire 700 Humidifier
On my Aprilaire 560 humidifier it says to replace water panel evaporator annually. Are there any documented instructions on how to do this?
Dear Reader,
If you visit aprilaire.com, you can go to the "OWNER'S CENTER" tab at the top of the page. With the cursor on "OWNER'S CENTER", more options will appear. Click on the "OWNER'S MANUALS" option. Scroll down to the bottom of the page and you'll get to a list of our older model humidifiers. Click on the first link which includes your model 560. By clicking on this link, you will be able to download the owners manual for your 560. On page 16 of this manual will be the step by step instructions explaining how to perform the water panel change.
If you have any further questions regarding this or any of our products, please feel free to contact our customer service department 800-334-6011 at your earliest convenience.
Kind regards,
Zach Handyside
Customer Service Specialist
Research Products Corporation
www.aprilaire.com
Nov 16, 2010 | Aprilaire 600 Humidifier
Carrier LFP Humidifier Logo
195 people viewed this question
Top Carrier Humidifiers Experts
paulcarew
Mack Baxter
Tom Chichester
Are you a Carrier Humidifier Expert? Answer questions, earn points and help others
