Question about Sewing Machines
Singer Futura SES2000 Error E1
Owners Manual says Thread Breakage or Incorrectly Threaded....I have Checked Thread, Replaced Bobbin, Cleaned Machine off all lint, Oiled Machine, It gives me error in both Embroidery mode and straight stitch mode... I can continue to sew just have to hit the start button every 8-10 stitches, it looks great...just wont sew more than 8-10 stitches,,,
SOURCE: Bernina 1130 not catching bobbin thread
there will be a adjustment in that you should select the stiching mode and in that give the straight mode the problem will be solved
Posted on Jun 05, 2008
  • 323 Answers
SOURCE: Loose stitching underneath. HOW CAN I FIX!!!!
Sounds as though you may have a burr or rough spot on the hook where the bobbin inserts. Run your finger along the edge of the hook to see if there are any rough spots.I'm sure you're going to find at least one from the time you broke the needle.Once you locate it, remove it with an emery stick or small sharpening stone. Polish it so that it is smooth. Should work okay.
sewman7
Posted on Jun 27, 2008
vash4me
  • 5 Answers
SOURCE: Machine sews zigzag although stitch is set at 0 for straight
It must be a design flaw- things don't always last like they are supposed to. I would personally check the physical reason it is not responding... knowing what it would take to make it stop moving- or whatis causing it to. *perhaps the switch isn't working to stop it- or the mechanism that controls it is worn down. If it was new- I'd return it- but there are only a few options at this point.
Posted on Jan 13, 2009
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
SOURCE: janome straight stitch loose
I don't know if this is the right answer for any of you, but thought I'd put my 2 cents worth in. Often this can be the bobbin in backwards. It needs to unwind a certain way depending on the machine. I've heard a phrase for this: Mind your p's and q's which means some wind off to the right like a q, others to the left like a p. Mine has to unwind one way then be slipped backwards into a little slot or it does that loose bottom thread looping and bunching someone here mentioned. It seems everytime I get that problem I rethread the top thread 100 times before it clicks again and I remember it could be the bobbin thread. Either your manual will tell you the correct way, or you could experiment and try one or the other. Once you figure out whether you're a p or a q, mark it on your machien somewhere to remind yourself.
Good Luck and Happy Sewing!
Posted on Apr 04, 2009
Singer quantum futura ce200 - thread breaks
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Feb 06, 2012 | Singer CE-200 Quantum Futura Computerized...
Machine is threaded correctly on both the bobbin and top.I have followed the manual step-by step and tried suggestions from other users. The machine will stitch about 2 inches and then beeps. The thread...
It sounds as if you have tried all the usual fixes so it might be a problem with the actual circuitry causing this. I'd take it into nearest Singer the sewing machine dealership or shop where you bought it and ask them to service it (or if still under warranty, for them to diagnose the fault).
Jun 11, 2011 | Singer CE-100 Futura Computerized Sewing...
Singer futura 250. while sewing the E4 code
Are you using bobbin thread? Is your thead new? Is themachine threaded correctly?
Make sure that when you thread the upper part the thread go under the circle that pull it.
Another thing is that when you hit the start button, pull the upper thread until the machine goes two or three times. It helps the bobbin thread to come up and the machine start sewing.I you leave it along the thread sometimes doesnot comes up and that is why the machine beeps.
I use this technique to make sure it doesnt beep and to cut the thread (the one at the beginning so it doesn't mess my design)
Feb 15, 2010 | Singer CE-200 Quantum Futura Computerized...
Singer Furtura E1 error message.
Hopefully, you didn't use any bobbins that weren't specifically meant for this machine. Here's the joke-there are special bobbins that that this machine only works with. And anything else gives you a mess.
They're not terribly easy to find, but they are available on eBay. Do a search for Singer Futura CE100 bobbin under crafts. I just bought a bunch from a place called World Weidner in Oklahoma through there. This will hopefully take care of your problem.
Wish I had been on here answering posts for you a number of months ago. If this doesn't help, please leave me a message in comments. If nothing else, I'll buy the bobbins back from you.
Jan 16, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a Singer Futura CE-150 and it keeps stopping due to "Thread break error" but the thread and bobbin seem okay what could it be?
Either upper thread is not passing through thread sensor area or sensor is broken.
Second possible reason is that if design is not optimized the sporadic speed change provides thread breakage error even if the thread is not broken physically. Make sure your software is updated to optimize it automatically (Futura main menu->Help->Live Update).
Dec 20, 2009 | Singer CE-100 Futura Computerized Sewing...
Top thread will not pick up bobbin thread makes a big loopy mess
This is sometimes caused by the upper thread not threaded correctly. You need to thread it first with the pressure foot in the up position. You need to "floss" the thread into the clear plastic guide as this is where the tension is. The tension should be set to E for embroidering. Also make sure you get the bobbin thread in the slot on the bobbin case. Also, lower your pressure foot before you begin embroidering. Hope this helps!
Sep 20, 2009 | Singer CE-100 Futura Computerized Sewing...
I keep getting the thread breakage message and there is no broken thread it is threaded correctly but it keeps saying that there is threas breakage can anyone help me this is for the futura 250
have you tried re-threading the machine, sometimes the thread can slip off the check spring for needle thread and cause a thread break message.
if you have re-threaded and cleaned the bobbin area (preferrably with compressed air) then most likely the thread break sensor is damaged and will require a tech to repair.
goodluck
scott.
Jul 28, 2009 | Singer Sewing Machines
Can't thread the bobbin on a singer futura CE 150
Be sure the bobbin thread is coming off from the left. There is a picture on my Futura bed that shows the correct way to insert the bobbin. If the thread is comming off from the right you will have the problem you described.
Good luck,
Beth
Jun 29, 2009 | Singer CE-100 Futura Computerized Sewing...
"thread breakage detected"
I had the same problem and one day my 9 year old said Mommy the thread is winding and cathing. I noticed that if the thread is not close to the silver metal arm it coils and makes a knot around the silver feed arm and also sometimes it cathces the little white plastic peace where the silver feed arm is connected to the machine.
Mar 24, 2009 | Singer CE-100 Futura Computerized Sewing...
Thread breakage sensor
Select in the main Futura menu Help->Machine setup Tutorial, lesson 10b, the balloon shows the proper position of the upper thread inside sensor checked area.
Sep 24, 2008 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
96 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
