Samsung WA80V3, display IE can't operation - Washing Machines
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Jul 15, 2014 | Washing Machines
Too much noise on spin cycle
the contents may be un balance you have to have your load balance
Jun 09, 2014 | Samsung CASE-DETERGENT;WA80V3 -...
Samsung automatic WA80V3 does not drain water
the pump maybe jammed or the filter could be blocked.
if you need advise on how to check, let me know
May 17, 2014 | Washing Machines
Sir, I would like to ask if this samsung washing machine model Diamond Drum WA80V3 220V - 50Hz - 330W can be use in Cebu City, Philippines where the electricity power cycle running is 60Hz?
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
Jun 17, 2011 | Samsung Washing Machines
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
