Question about Samsung LN40A550 LCD TV
Ln40a550p3fxza My tv makes a buzzing noise then it shuts off then turns back on again. I cant turn it off with the remote when this happens. Please advise
  • 610 Answers
SOURCE: 32'' Samsung LCD HDTV - will not turn on
needs power supply board replaced. VERY common problem, can call 1-800-samsung for nearest service center.
Posted on Dec 29, 2009
jrweighing
  • 183 Answers
SOURCE: Turned the TV on this morning and it is making a clicking noise
I know exactly what the problem is. If you feel competent to do so..remove the back of the tv with the power disconnected for your safety. On the power board located in the centre you will see capacitors on the right of the board that have bulging tops..There are usually 4 of them that bulge (go faulty) like this..The value of each of these should be 1000uF..Replace these by buying from Maplins Electronics or CPC, both online..Solder new ones in (takes 10 mins) and all will be ok..
Posted on Feb 04, 2010
  • 55 Answers
SOURCE: watching tv last night, the
It can Have one of 2 Troubles, The Inverter Board is Defective or the Power Supply has bad Capacitors. I found 3 Capacitors known to go bad in that set. Replace the 10 Volt Capacitors with 16 Volt Caps and they will last forever.
Posted on Oct 08, 2010
  • 916 Answers
SOURCE: samsung ln40a550p3fxza power take long to turn
You need to determine the type of capacitor - Capacity (usually in uF), Voltage, polarised or non-polarised and physical dimensions. The capacity and voltage are usually written on the side and there will also be a band indicating the negative pin if it is polarised. Most electronics shops e.g. maplin can supply capacitors, or search on-line.
Posted on Feb 24, 2011
  • 8457 Answers
SOURCE: My Samsung HDTV takes almost
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Take the tv aparts and check the tv power supply board carefully for dying and leaking components parts that are calling capacitors parts these capacitors parts are most likely bugles ups or puffing up onto it tops and leaking.These capacitors parts are dying and leaking that why it give the tv power supply board low power and long time to power up the tv.Have all the tools and know basic electronic also can do basic soldering work?Yes,than changes all these dying and leakages bulges ups capacitors components parts with the same Miro Fared and thoes voltages on the capaictors parts like 5 or 10 volts higher than those capacitors parts was in the power supply board u are replacing,these 5 or 10 volts higher rating will help these newly replace capacitors parts withstand heat better and last longer and the operation on the tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power suply board for the replacement.
Posted on Aug 19, 2011
I have the samsung DLP HL-6163W model. I've had this TV for 6 year, and have logged many hours on it. Tonight, the TV started making a buzzing noise in the back, and the colors got all screwed up. I...
This tv have a colors wheel design in it to this tv.The buzzing noises and the colors are all screwed up because the colors wheel is worn out and spinning off of is axis and rubbing it against the wall of it hall of the steal box frame that hold the colors wheel itself.Don't attemp change the colors wheel by ur self,if u have no mechanical skills.Bacause the colors wheel itself sit way back of the tv,have to take out many mechanicals parts,before can come to the colors wheel itself to replace it.Because u will regret it later if u putting the colors wheel itself in wrong.Hire a tv repair person to replace it.
Apr 04, 2011 | Samsung HLP6163W 61" Rear Projection...
My rca d52w19 makes a noise when turned on.no picturet henshutsof
what kind of noise? is it like an electrical buzzing?
a rapid clicking?
Apr 29, 2010 | RCA D52W19 52" Rear Projection Television
Tv makes buzzing noise then picture fades and eventualy shuts off
Ur colors wheel is dead,must call tech.for this is very difficult to take out,and replaced have no tv tech. experience.Best to call tv shop service,to replaced this colors wheel,and have warrenty on it.
Jan 11, 2010 | Samsung HL-P5663W 56" Rear Projection HDTV
My SOny Projection HDTV makes buzzing noise when turned on
if tv is a dlp you have eithor a bad color wheel or bad fan.would need model number to research it more
Sep 07, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
HL-r6167w wont start up (HELP)
it sound like the color wheel is bad
Nov 26, 2007 | Samsung HL-R6167W 61" HDTV
Samsung LN40A550 LCD TV Logo
Henry  Thomas
Henry Thomas
