Question about Bakers Pride Y-600 Gas Single Oven
Automatic oven starter-timer
Have an older y600 which is left 'on' 24/7
even with the very low flame there is considerable fuel waste
I am wondering if there is such a thing as an automatic oven- starter
would like to shut propane off except for pilot and time it to come on before
we open the next day
many thanks if you could steer me in the right direction
---Steve
    Novelist:
  • 125 Answers
Hi there. If you have an older oven, it most likely does not have a combination valve with a thermopile, not the same as a thermocouple, or a hydraulic safety. If there is a red button sticking out the panel where your thermostat is, you have a hydraulic safety. What you want can be done with wiring, solenoids,timers, and the correct location in the gas line, but would require a bit of modification. I would only use a servicer for this type of modification, if they will even do it, could you find someone to do it, with little concern about safety? sure, but it must be understood, you are taking the risk, and responsibility. This is definitely not a do it yourselfer task.
Posted on Feb 21, 2009
Candy fl 134 x uk , single oven ..... oven works fine ... clock/ timer is dead and keeps making clicking noise , when not in use i power it off ... do i just need to replace the clock ???? Thanks roy
[n 75 years I have never heard of anyone powering off an oven when not in use . those little clocks do not use enough electric to worry about waste
Feb 25, 2017 | Candy Ovens
STOVES 900GDO USER MANUAL NEEDED
Good luck, and im being sincere, unless you find someone with exact stove to help you i didnt see a single thing for a manual online.
If you can make the timer function, a standard digital timer can have up to 4 numbers.. and when you punch in numbers it goes from right to left.. my stove for instance.. the very first number is minutes. so even if it says 0005, that could be 5 minutes not seconds, and my oven, you dont press anything to start timer, you just put it to required minutes and it starts itself lol.......maybe this provided some insight?
Nov 01, 2013 | Ovens
Flame very low in bottom oven
If the flame stays low from the beginning then it will be the flame safety device (fsd) not opening on sensing the flame and will require replacement by a gas certified engineer.
Jul 29, 2012 | Ovens
Resetting the clock
You can set the timer on a single oven slow cooker to automatically switch to a warming setting when you estimate foods will finish cooking.The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the work, and come home to a fully cooked meal.
INSTRUCTION BELOW.
  • Fill the insert of the single oven slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • Please rate this solution after use.
    Thank you and thanks for using fixya.
    Oct 03, 2010 | Maytag CWG3100A Gas Single Oven
    I need to get 2 slates for y600 pizza ovens do you sale them.
    When your looking for this part it is called the "Stone Deck"
    36" X 60" for most Y600 Models. FixYa is a "help you" site not a full blown retail outlet.
    This is the Y-600-(old style) manual:
    http://www.bakerspride.com/pdfs/Y-600%20Parts%20List%20OLD%20STYLE%207-05.pdf
    This is the Y-600 manual: http://www.bakerspride.com/pdfs/PartList/Y-600%20Parts%20List%20U6050A%208-08.pdf
    This is the Y-600-DSP manual:
    http://www.bakerspride.com/pdfs/Y-600%20DSP%20%20Parts%20List%20U6051A%202-07.pdf
    Their website went down for maintenance as I was doing this. But their phone number is on the website. http://www.bakerspride.com/
    Thier manuals list is here. Note the price list for parts is at the very bottom block top of 3rd row.
    http://www.bakerspride.com/manuals.asp
    Thanks for choosing FixYa.
    Kelly
    Sep 14, 2010 | Bakers Pride Y-600 Gas Single Oven
    It won't heat up... even though there is a flame
    Check The Power Source
    If the gas oven won't turn on, the first thing to do is check the power source. Most modern gas ovens are electrically powered. Check to make sure the oven is plugged in and the breaker isn't tripped.
    Check the Heat Source
    When a gas oven won't heat, the pilot light can also be set too low; if the pilot is lit but the oven isn't catching, adjust the flame.
    Newer gas ovens use electric ignitors that produce sparks. If the oven doesn't heat, the ignitor could be broken.
    Feb 05, 2010 | Ovens
    Too hot
    Hi, not sure if you ever received a reply, but there is a setting known as "bypass" on commercial thermostats, if you took the cover off to replace it, you can access this screw, it is part of the body of the thermostat, either to the left or the right of the knob shaft, usually has a "B" stamped, or molded into the body. What this setting does is when the thermostat reaches temperature, it would normally close, shutting off the supply to the burner, thus the temp would begin to fall, by the time it opened back up, the temp would have fallen too much, causing a large temp swing. The bypass setting opens or shuts a passage that "bypasses" the thermostat main valve, keeping just a little burner, making the swing, or fluctuation smaller. So, you probably have a setting too big, causing your bypass flame to be too big, raising, or keeping the temp too high, try turning it in (cw) to lower it slightly, a small turn makes a huge difference, so go easy. Hope that helps, and thank you.
    May 08, 2008 | Bakers Pride Y-600 Gas Single Oven
    Fault with Gas Ignition
    Sound like the flame sensor is faulty on the ignitor
    Apr 23, 2008 | Ovens
    Door on my bakers pride y600 pizza oven
    Theses are called 3/4 door busings and should be changed when you replace the left side door rod (complete)and are available from any parts depot that sells bakers pride parts
    Jan 20, 2008 | Bakers Pride BAK-DS805 Gas Single Oven
    Bakers Pride Y-600 Gas Single Oven Logo
    504 people viewed this question
    Top Bakers Pride Ovens Experts
    ashburton
    Paul Carew
    Dan Webster
    Dan Webster
    Are you a Bakers Pride Oven Expert? Answer questions, earn points and help others
