Question about Whirlpool GGW9868K Gas Dryer
Whirlpool dryer model number ggw9868kq1 3 beeps
Will not turn on, but there is power to the panel
SOURCE: Whirlpool dryer front panel
I located a video on youtube.com free of charge. I removed the lint screen, and removed the two screws located in the lint screen housing. Then I pryed the top off near the front of the dryer, which has two clips. Then I remove the two screws locate on the top of the front panel, but they are located on the inside. I removed the door lid swich by removing the two screws. Lastly, I pulled the front panel outward and pulled up lightly. The front panel was off. The issue I had was the dryer would heat up and then got cool after five minutes. The solution was to replace the coils. Important point is that the coils ohm readings were within specifications, but I did located information on the web that indicated this was a potential solution to the issue, and I replaced the coils even though the resistances were within specification. Total cost $22.95 plus tax.
Posted on Mar 25, 2009
  • 512 Answers
SOURCE: whirlpool dryer model number lgr7648kq1 won't get
Sounds like one of the cavity switches is bad. Open back of dryer, you will see wires that attach to little clip next to each other. Try jumping wire from one side to the other, do one switch at a time and try dryer to see if heats, if you get heat replace that switch. These switches burn out if dryer gets to hot, usually from to much lint in duct work. Also vacuum out duct work in wall and on back of dryer.
Posted on Jun 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: My whirlpool dryer won't start.
Check your door switch for continuity. If no continuity,replace it.
Posted on Aug 13, 2009
SOURCE: my whirlpool duet dryer will not start. Power
Mine isn't stacked and I had the same problem. My husband and I just bought ours last week. I had to close the door and then press on the top of the door to hear another click and it then would start the cycle. I don't know if this is correct or not. I have searched whirlpool web site and not found mention of this. I am calling the department store we purchased ours from to see if this is normal. Hope this helps!
Posted on Mar 01, 2010
SOURCE: I have a Whirlpool Duet Dryer Model GEW9200L and
on a Whirlpool Duet Dryer is the thermal fuse on the houswing where the heating element is? mine has 3 different fuses or sensors on the heating element houseing which on is the thermal fuse?
Posted on Nov 30, 2010
Bizhub 363 panel does not start
There are 2 power switches on this machine. If you are turning it on then you know where the main power button is. Now lets try turning the control panel switch on. Its located on the right side of the control panel itself. When you turn the main power on, do you hear the machine running and booting up?
Apr 09, 2014 | Konica Minolta bizhub Office Equipment &...
Sanyo dp50747
sounds like a mainboard problem
Jan 31, 2013 | Sanyo DP50747 50 in. Plasma TV
TV worked 1 day and no sign of power when turned on the next.Toshiba REGZA 42
if no any power indicator at the front panel, check for a blown fuse at the power supply board.
Oct 27, 2012 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Will not power up
If your television will not power up, there is just one problem related to this, and that is the power panel. But before You confirm it is the power panel, You will have to run a test on some components to be sure that it not other components before You go ahead to replace the power panel of the television. The components to tests are the power outlet, check if the voltage is not too high or too low to power on the television. Then You also test if the cable that connects the television to the power outlet is not bad by using it on another television and trying to use the another power cord on the television, then You confirm if it is not a blown fuse on the power cord. Once that is confirmed, then You can go ahead to replace the power panel of the television. To replace the power panel:
  1. Get a screw driver, a glove a cup and a replacement power panel,
  2. Unplug the television and put on Your gloves,
  3. Turn to the back and unscrew it open,
  4. Keep all screws in the cup in order for them not to get missing,
  5. The power panel is the panel that the power cord is attached to at the back of the television, remove it,
  6. Fix in a new one
  7. Reverse the process to reassemble the television back together,
  8. Plug it into the power outlet and power on the television.
It should turn on now.
Hope this helped. Thank You for using FixYa!!!
Jan 21, 2011 | Toshiba 32AV500U 32 in. LCD HDTV
My TV does not turn on power and the red right on TV blink 5 times repeately. How can I fix this.
When you have your televisions standby light blinking for about some time, it means there is a power problem affecting the television. It is recaiving power but not using it up.
The power problem is most likely caused by a bad capacitor or a bad power panel. The bad capacitor can either be on the main panel or the power panel.
To confirm, unplug your television for about an hour or two so the high voltage will dissipate, then you unscrew the screws that are at the back of the television to gain access to the main and power panels, then you carefully turn the back of the panel where you have the capacitors and check for bad capacitors, if it looks swollen, compressed, of burnt, then it is faulty.
The solution to that is for you to turn to the other side of the panel where you have the tip of the capacitors and melt off the burnt capacitor using a soldering iron, then fix in an new capacitor with the same capacity in the holes and solder it to the panel. Then cut off the extra tips of the capacitors, then fix the panel back on the television and couple it back together.
After doing that the television will be in good condition once again, and if there are no bad capacitors on both panels, then it means the power panel is faulty and needs to be replaced.
Take care and good luck.
Oct 26, 2010 | Panasonic TH-42PX6U Plasma TV
Upon initially turning on power the tv lost sound and went black and would not turn on again.
The television is having a power problem, that is why it is no turning on, it most likely is as a result of a bad capacitor on the power panel of the television.
Have the power panel replaced the assess the main panel for any problems.
Also check the sound ic, it might hsve been burnt due to some bad power problem.
Oct 25, 2010 | Sharp 27C-240 27" TV
MY asus pc continues to not wake up. I have to
POWER OPTION
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
POWER OPTION
-set display to never
Restart pc
Jul 15, 2010 | ASUS Eee PC 900 Notebook
Screen goes blank after a few minutes
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 14, 2010 | Dell Inspiron 1318 Notebook
Think pad t42 monitor keeps turning off. I tried changing power settings to never ... did not help still doing the same thing anything else I can do? thanks
POWER OPTION
Restart pc
POWER OPTION
Restart pc
Jul 02, 2010 | IBM ThinkPad T42 Notebook
Monitor is black, the blue lcd at the switch does not lite when switch is turned on. The internal fuse is ok. I tried to find a schmatic on I could check the power supply, no luck.
I have the same problem. Took it apart for troubleshooting. Found that if I disconnect the ribbon cable between the display driver circuit board and the LCD panel, I can turn on power and it will stay on. I can turn it on and off with the power switch. With the LCD panel cable connected, Power turns on (power light blinks) then apparently a fault with the LCD panel causes the power supply to shutdown. At this point the power switch does nothing. Now the big question is "Can you purchase a LCD panel?" If so, it probably costs more than a new monitor. Hope this was helpful.
Jan 02, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Whirlpool GGW9868K Gas Dryer Logo
49 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
