Question about Apple iMac G5 Desktop
Cannot open 3rd generation iMac G5
I have read your articles about opening the iMac - but the bottom of my computer is not like the one described in some of your articles.  The 3 screws are closer to the memory slot (not near the sides of the computer) and the screws come out completely (easily).  The back does not lift off easily.  What needs to be done.  (I suspect my power supply is going and want to check it out.)
    Problem Solver:
  • 6 Answers
I also had the same issues. The cord when i would jiggle it out slightly then push back in would restart the computer. I truly wouldn't mess with it too much. What it was for me was simply giving it a dedicated outlet for some odd reason. However, to remove the back. Lay computer screen down on a towel. Lossen the screws, they do not come out, mine didn't. Remove the panel and that is that. The entire back did not come off fo me, jus the panel to add more memory.
Posted on Jan 24, 2009
Adobe has stopped opening documents on my Imac G5. Solution please?
Hi David.Forget adobe and use Preview - it's installed in your imac.Single click a document. then go to File - Get Info in the menu bar.Near the bottom of the window that opens you will see this5_9_2012_9_29_04_pm.pngChange the bit where it says Open With, to Previes and then click the button underneath that says Change All.
This will change all Adobe PDF files and other PDF files so that they open with preview - that's how it works on all the macs here, no Adobe Reader at all.
May 08, 2012 | Apple iMac G5 Desktop
Ik Krijg verschillende kleuren lijnen op m'n lcd van canon g5
Eerst moet je het "model" & "generatie"van uw G5 iMac moet je wetenHoe je je iMac te identificeren van informatie over uw computer
U kunt deze informatie weergegeven op de bodem van elk bericht door te gaan naar 'Mijn instellingen' die zich bevindt in de kolom aan de rechterkant onder uw naam, en het invullen van de gevraagde informatie.
Controleren om te zien of uw model iMac in aanmerking komt voor een van de iMac G5 reparatieprogramma programma voor video en voeding
Als uw computer niet in aanmerking komt, hopelijk heb je AppleCare.
Mar 21, 2011 | Canon PowerShot G5 Digital Camera
I have a 17" imac g5 that will no power up. no
Check for blown capacitors on the logic board and power supply. If you have signs of blown capacitors you will have to replace logic board or power supply.
The trick is getting the computer open. Stick a credit card in the back vent at the top of the display. Their are two tabs one and each side of the vent push forward unscrew the screws at the bottom. sit it up facing you and pull the top to you. be careful of the isight cable at the top. you will need to unscrew the LDC from the housing be careful of connected cables and check under for the blown caps.
Jan 24, 2011 | Apple iMac G5 Desktop
Is imac g5 17" lcd compatible with imac intel core duo
Possibly, the newer G5 Imacs feature Intel 2 Core Duo Processers. While older generations, do not support Intel Core Duo or Intel 2 Core Duo Processers.
Jul 09, 2009 | Apple iMac 17" MA199LLA Desktop
17" iMac quit working
Your Imac may be one of those affected by Apples purchase of inferior capacitators from Taiwan. If you are less than 3 years from the purchase date, apple will repair the problem for you for free. Just take the unit to your nearest local Apple Genius or tech. If you are outside of the repair extension guidelines, I have provided a link here which can show you or someone more skilled how to repair the problem. Ordering a new motherboard and power supply will set you back a lot of money, however the following guide and pdf give you step by step instructions on how to ressurrect your dead imac without speding more than $100.00. I was able to repair my imac using this guide and it was worth it to save a $2k computer that was only 3 1/2 years old. Check it out:
the following information (in italics and bold)  is taken directly from:  (this site is complete with instructions, manual and the full compliment of materials available at an extremely affordable and fair price. I took a chance and repaired my own, it is not as hard as it sounds1)
The iMac G5 Repair Extension Program for Video and Power Issues applies to first generation iMac G5 computers that have video or power-related issues as a result of a specific component failure. If your iMac G5 is exhibiting any of the symptoms listed below and your computer's serial number is within the noted ranges, your computer may be eligible for repair, free of charge. If Apple or an Apple Authorized Service Provider (AASP) determines that your iMac G5 computer is eligible as part of the program, the repair will be covered by Apple for up to three years from the original date of purchase even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
Scrambled or distorted video
No video
No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to contact Apple or any Apple Authorized Service Provider.
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between approximately September 2004 and June 2005 featuring 17- and 20-inch displays with 1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper band of the ranges listed below. Only first generation iMac G5 computers are affected by this program.
Where do I find the serial number of my iMac G5?
The 11-digit serial number is located on a label under the foot of the iMac G5. There is a bar code underneath the serial number.
To view the label, hold the sides of the iMac and gently lay the computer face down on a soft, clean towel or cloth.
Is the iMac G5 Repair Extension program available for other Apple computers?
This program applies only to the systems noted in this FAQ. Other versions of the iMac G5 line are not part of this program. Click here for more information on how to identify iMac G5 models
Free guide for how to repair the motherboard capacitors, rescue the hard drive and more.
Feb 22, 2009 | Apple (661-2795) for iMac Motherboard
IMac won't recognize the files on a PC
In order for a Mac to open files generated on a PC, you must have a program capable of reading these files. The new version of Microsoft Office defaults to saving files in a new format which is not compatible with earlier versions. This can be rectified by 'Back Saving' files to an earlier version of Office in the 'Save' menu.
If you have files that you know can be opened with an application that is installed on the Mac, ctrl/click (right click) on the file and chose 'Open With' from the drop down menu. This will allow you to choose the application.
Jan 05, 2009 | Apple iMac G5 Desktop
Changing a hard drive on third generation imac
After a bit of confussion by what you mean by 3rd Gen and Aluminum and glass I've decided to give you two guides and you can choose which one you actually mean.
One of those should help you out.
All the best
Dec 18, 2008 | Apple iMac G5 Desktop
Airport Extreme 802.11g
At this point you are much better off installing a USB wireless antennae than spending money on an Airport card, cracking open the iMac, and installing it.
USB wireless adapters are cheap, plentiful, and have more capabilities than the generation of Airport cards that were made for G5 iMacs.
Apr 14, 2008 | Apple iMac G5 Desktop
Imac g5
HI, read through this Apple artice, I hope it helps. Please rate if useful, thanks!
Dec 02, 2007 | Apple iMac G5 Desktop
Apple iMac G5 Desktop Logo
629 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
