Question about Kenmore Refrigerators
Kenmore manual or answer for model 253-68882014
Fridge is in a non temperature controled cabin. When I arrive and inside cabin temp is in 30's, the cooling and freezeing to not run until area around fridge warms. Food in my freezer has started to thaw. My last kenmore never shutdown even through colder temps. Why is this happening?
Joe_Rex
  • 114 Answers
SOURCE: Fresh Food & Freezer Warm
CHECK AND MAKE SURE YOU CAN HEAR YOUR EVAPORATOR FAN RUNNING (INSIDE MOTOR). IF IT IS NOT RUNNING ... AND YOUR COMPRESSOR IS RUNNING. THE MOTOR OR DEFROST TEMENATION SWICTH COULD BE DEFECTIVE. IF NOTHING IS RUNNING ... TRY TO LOCATE THE DEFROST TIMER(USUALLY LOCATED WHERE YOUR COLD CONTROLS ARE) YOU SHOULD SEE A SMALL HOLE WHERE YOU CAN MANUALLY TURN THE TIMER WITH A SCREW DRIVER.IT CAN ONLY TURN IN ONE DIRECTION. IF THE MOTOR IS RUNNING. CHECK TO SEE IF COMPRESSOR IN THE BACK IS RUNNING ... IF IT ISNT AND IS "HOT" (BE CAREFULL) SEE IF THE CONDENSER MOTOR NEAR THE COMPRESSOR IS RUNNING ... IF NOT ... THE COND. MOTOR IS BAD ... THAT MOTOR RUNS IF POWER IS GOING TO THE COMPRESSOR ALWAYS. IF COMPRESSOR IS HOT AND NOT RUNNING AND COND. FAN IS RUNNING .... UN PLUG FRIG AND WAIT TILL COMPRESSOR IS COOL TO THE TOUCH. THESE COMPRESSORS HAVE AN INTERNAL T-STAT THAT PROTECTS THE COMPRESSOR IF IT SHORT CYCLES.IT SOMETIMES GETS SO HOT IT DOES TAKE HOURS TO COOL OFF. THERE IS ALSO A DEFROST-TERMINATION SWITCH THAT CAN GO BAD. CONSULT A LICSESED FACTORY CERTIFIED COMPANY TO GIVE YOU A FIXED-PRICE DIAGNOSTIC TEST.
Posted on Apr 28, 2007
  • 25 Answers
SOURCE: Freezer and fridge areas both 50 degrees
Assuming you have a frost-free refigerator:
Is your motor-compressor running?
If so, check if you have ice in the freezer section; if so, maybe your defrost thermostat or heating element is kaput.
If the motor-compressor is not running, check in the back of the refrgerator if the defrost time is stuck open, bu turning clockwire the small test screw, with a 1/2inch screwdriver.
Posted on Dec 10, 2007
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
Posted on May 10, 2008
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
SOURCE: GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Posted on Mar 01, 2009
It is a french door, items in the fridge part are freezing, what should temperature in freezer and fridge be?
The factory presets your temperatures to the MID / MID setting of 0? for the freezer and 37? for the refrigerator. Refrigerator adjustment range is -15? to +15? in the freezer and 33? to 47? in the refrigerator. Depending on ambient temperatures the temperatures will be + or - 6? the set point. Whenever you make a temperature adjustment, you need to wait 24 hours to notice any temperature difference.
To adjust your temperatures: Adjust controls according to your Use and Care guide. Start out by making sure your settings are at the factory setting of MID / MID. Make only one adjustment: Adjust one control and wait 24 hours before making another adjustment.
To measure temperatures: If you try to measure temperatures, it is important to follow these directions: Fresh Food Section: Put thermometer in a glass of water. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work). Frozen Food Section: Put thermometer between two bags of vegetables. Check the temperature during the first door opening after a long (8+hours) non-usage period (such as overnight or when you arrive home from work).
For more information it may be helpful to look at http://www.whirlpool.com/ or contact your local whirlpool support number
May 17, 2011 | Whirlpool Refrigerators
Hi, Please tell me how to change the temperature on my elite kenmore.
Klay421 --
Which model Kenmore Elite refrigerator do you have? If you have one of the older manual models, the thermostat is located inside the fridge side. If you have a newer model with digital controls you need to press and hold the the ON/OFF button for 2 seconds until the digital displays for temperature for the Freezer and Refrigerator lights. The Up/Down arrows allows you to adjust the temperature. If you are still having problems, write back. -- SWT
Aug 22, 2010 | Kenmore Refrigerators
Freezer will not come on It is at our cottage and last week end when we arrived it also wasn't on but when I turned the control higher it came on and froze the food very well. We left 5 days ago and just...
What is the temperature in the cabin when it isn't occupied??
If the temperature in cabin drops to or below 55 degrees, then the thermostat that controls the machine, being in the fresh food compartment will not cycle the machine.
If you warm up the cabin for a decent period of time, and it fails to run, you will need to replace the main cold control.
Without the approx. age, the style of the machine, top, bottom or SXS style and where the temperature controls are located. Both in Fresh food compartment, one each in freezer and fresh food area, this is the best I can give you.
Please, in the future, give as many details about what machine we are working on to give you the best possible answers. Jack
P.S. is it possible someone shut off the power that runs the machine when you left ???
Oct 31, 2009 | Kenmore Refrigerators
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
My fridge freezes everything
If the temperature outside the refrigerator drops below the temperature inside such as in a non heated garage the things in the refrigerator will freeze. Short of moving the refrigerator to a temp controlled place there is not much you can do about it.
Jan 07, 2009 | Freezers
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerator and freezer temperature control
hi. thanks for te question. since you asked the question. has your fridge settled down and cooling sometimes the fridge will set itself
Sep 24, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore bottom freezer refrigerator
This sounds like the Maytag bottom mount that has a High Voltage Control Board problem. Does this have the freezer/fridge temp. display/controls on the left hand fridge door? Whats the model number and on the manufacture tag does it something on it like Code:0304 maybe? Let me know I may have an answer I do work on these for a living.
Jan 26, 2008 | Kenmore 73503 Stainless Steel Bottom...
Temperature control
For the Kenmore, keep pushing the button and it should cycle back to the top of the temperature range.
Sep 04, 2007 | Kenmore 63822 / 63824 Bottom Freezer...
Refrigerators Logo
52 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
