Question about Technics SA-EX400 Receiver
Technics sa-ex400 will not turn on.
When i push the power button, only the yellow light comes, no power
5 Suggested Answers
seabelow
  • 95 Answers
SOURCE: Overload on Technics SA-AX710 Receiver
Turn it off...remove all the speakers and turn it on....If it goes into the protect mode. you have a bad power amp. That's the big black flat things attached to the cooling fins.. one or both is shutting the system down. If it doesn't trip out, plug a head set into the phono jack and see if you can hear the music there. Can you turn it up without tripping.... if it's still ok...hang one speaker on the system, if it trips thats the bad leg...check the speaker/wire
Posted on Oct 23, 2009
  • 20 Answers
SOURCE: Technics SA-AX730
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: Even though fused, your receiver has internal overload protection systems to prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized service center must do this.] But, before you take it in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Posted on Jul 18, 2007
  • 36 Answers
SOURCE: Dish Network Box, Technics Receiver, RCA LCD TV connections
I would use the s-video out & red & white rca audio out on dish box to s- video & audio in on the t.v., then audio out from t.v.(RCA, red & white) to one of the inputs (RCA) on the receiver.
Posted on May 25, 2009
SOURCE: I have a Technics SA-gx550 receiver and it i turn
wich is low imp in my technics sa-gx550 please tell me?
Posted on Nov 24, 2010
Connect laptop to technics av sa-ex400 reciever
you will have to buy an 1/8" stereo jack to rca plug....insert the headphone jack into the headphone out of laptop and plug in to any input of choice in the back of the receiver (i.e. aux, video in, cd)...play some music or whatever on laptop and turn your reciever to that input....
Jun 22, 2013 | Audio Players & Recorders
Technics sa ex400 help reset light staying on
I to have a Technics SA-EX400 Receiver, The reset light stays lit also, I assumed it is normal. When I push it, it says operating normaly...
Jan 04, 2012 | Technics SA-EX400 Receiver
The fuse blow up and now say overload
Hello, Replace the blown fuse with same current rating. Also remove the load and power it on ,if it does on , then you reduce the numbers of load that was initially on the receiver....
May 19, 2010 | Technics SA-EX400 Receiver
My receiver does not come on and the only thing that turns on is the help and reset button ? I push it and nothing happens
Check your speaker wires aren't touching or that there aren't any shorts in the wires or speakers.
Jan 13, 2010 | Technics SA-EX500 Receiver
May 25, 2009 | Technics SA-EX400 Receiver
Overload at medium (4-6) volumes. Can you adjust or disable the overload protection on these Technics amps??
try this mate:
http://www.electronicspoint.com/googlesearch.php?cx=002919058480771089906%3A03mranmmdze&cof=FORID%3A10&ie=UTF-8&q=Technics+SA-GX550&sa=Search#862
May 23, 2009 | Technics SA-EX400 Receiver
Technics SA-DX950
when turn on receiver , after few seconds got message
F70. when wants to do any operation with receiver got message SWITCH POWER OFF
Jun 25, 2007 | Technics SA-DX950 Receiver
Open Questions:
See all Technics SA-EX400 Receiver Questions
27 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
