Question about Price Pfister Plumbing
I have a Price Pfister series 26 Avalon kitchen faucet. The water flow has been slowly decreasing for a while, and is now just a trickle. I have replaced the diverter tee and the cartridge, and have cleaned the aerator. Any other suggestions?
3 Suggested Answers
  • 92 Answers
SOURCE: New Pfister Avalon Install: Spray Hose Works, Faucet doesn't
sounds like your diverter is stuck or improperly installed ,try tapping at diverter location to free up diverter the other thing to try is remove the little device on the end of spout make sure its not clogged with debri
Posted on May 04, 2009
smokenic
  • 49 Answers
SOURCE: Low hot water pressure on newly installed kitchen faucet
it souns like a factory flaw in the piping or whoever hooked it up, over bent or kinked the line
Posted on Sep 20, 2009
How do I disconnect a price Pfister quick connect?
There is a tool that presses on the collet at the tend of the fitting. It look like an open ended wrench.
https://www.youtube.com/watch?v=dCbXw5bP9I8
Price Pfister Quick Connect Sprayer Hose Removal - YouTube
? 1:50
Feb 1, 2014 - Uploaded by brianmcdrummer
In a few easy steps I'll explain how to remove your sprayer hose from your diverter. ... Pfister Faucets 17,981 ...
trick to removing price pfister quick connect sprayer hose - YouTube
? 0:23
https://www.youtube.com/watch?v=vTJefezIvwg Aug 14, 2012 - Uploaded by Biren Patel
This shows you how to remove the price pfister "quick connect" hose on the end of the kitchen sprayer head ...
Pfister - How To ' Remove a Sprayer Hose Connection
www.pfisterfaucets.com/support/faqs/sprayer ... Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a sprayer hose connection for the Price Pfister 529 Series faucet.
Pfister - How To ' Remove a Diverter Tee Connection for the 26 Series
www.pfisterfaucets.com/support/faqs/diverter ... Information · Order Parts, FAQs. FAQs. Resources. Step by step instructions on how to remove a diverter tee connection for the Price Pfister 26 Series faucet.
Pfister - Removing quick connect HELP ' Terry Love Plumbing ...
terrylove.com > Home > Forums > Plumbing Forum, Professional & DIY Advice Dec 13, 2006 - 6 posts - ‎5 authors
Purchased a replacement sprayer (with hose) for a Pfister Contempra faucet. How the heck do you remove the old hose from the handle assy? How do disconnect price Pfister quick connect Google Search
Jan 08, 2017 | Price Pfister Plumbing
How to disconnect the quick connect spray hose in a Price Pfister Parisa
I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Nov 30, 2012 | Price Pfister Marielle Kitchen Faucet with...
I have a price pfister pull out kitchen sink 533 series. the hot water barely runs out of it. the cold water runs great. but the hot water 15 feet away in the half bath runs great. What is my problem?
There is a restriction in the valve or the stop from supply is restricted,check stop at sink to make sure it is opened all the way,if it is then turn off water supply disconnect hot water to faucet take container open valve slowly to see if it is restricted,if that is open and water flow is good.Then it is in the faucet you must then disassemble hot side cartridge and see if there is some type of blockage if none visible the with hot side disassembled slowly open valve to see if you can flush out any foreign matter (note the way it is disassembled so you can reinstall exactly how if was taken out to avoid any reassembly problems).
Jun 14, 2011 | Price Pfister Plumbing
There is low pressure at the kitchen faucet. All other faucets in the house are normal.
make sure all water valevs are open all the way??? also make sure there are no kinks in any of the lines????
Oct 21, 2010 | Price Pfister T26-4CBY Avalon 4 Hole...
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
Flow is very weak - less than 1 gpm. Ewplaced
There are little rubber restrictors in the stainless supply hoses you can pry them out with a small screw driver
Nov 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
No water flow in gooseneck faucet
Sounds like the diverter part (insode the faucet) is clogged or broken.
May 27, 2009 | Price Pfister J103-BC 100 Series Kitchen...
May 04, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
24 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
