Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Not cold 596.75533400
Top part not getting cold. feezer seems to be ok.
3 Suggested Answers
  • 1122 Answers
SOURCE: feezer still cold frig warm
YOU HAVE A DEFROST PROBLEM WITH YOUR FREEZER,CALL AN HONEST APPLIANCE REPAIR SHOP(NOT SEARS$$$$) IT CAN BE ONE OR MORE OF 6 THINGS,MIKE
Posted on Sep 13, 2008
  • 1218 Answers
SOURCE: not cold in the fridge part top freezer seem ok.
Good day,
One of 2 problems.
1. The fan motor in the freezer compartment is not running. While the machine is running, open the freezer door. You should hear the fan motor running.
If not, then remove the rear panel in the freezer section, and inspect and replace the motor if needed.
2. The defrost system failed.
When opening the freezer door, look at the rear panel. If you see the beginning of a frost build up on the panel, the defrost system has failed.
The defrost system is made up of 3 parts. The main heater, which is located behind the rear panel in the freezer panel.
The defrost thermostat which is a small round device clipped to the top of the evaporator coil, and once again, is located behind the rear freezer panel.
The timer, which is located in the fresh food compartment on the top underneath and behind control panel.
You will need an ohm meter to test the main heater for continuity, and the defrost thermostat as well.
The timer can be checked by using a small screw driver and turning the advance shaft clockwise until the machine shuts off.
Wait 35 minutes. If the machine turns itself back on, the timer is good. If not, it is bad, and needs replaced.
Here is an excellent tutorial to explain the system.
http://www.appliance411.com/faq/howdefrostworks.shtml
Posted on Dec 07, 2009
Testimonial: "looks to be the defrost system failed,noticed frost on the panel.what do you recomend,check the timer 1st then the main heater and the thermostst"
Where is the defrost heating element
Freezer side at the bottom and maybe middle of evap coil. Need to remove screws to access
Jan 20, 2013 | GE J Series 18.2 cu. ft. Top Freezer...
Feezer cold ref. not
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 23, 2011 | Dometic RM2852 Refrigerator
Hello How to trouble my GE top feezer, it is making avery load noise.
Check the fan to see if it is hitting on built up ice...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 01, 2010 | GE Refrigerators
Feezer cold frig.warm
sounds like your freezer is not defrosting, causing lack of air flow to fresh food side
May 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Feezer COLD food compartment not cooling. It
the heat element or the thermostat IN YOUR FREEZER PART need to be check...they might went bad and when you defrost the unit it is working fine but only for period of time....:(
Dec 30, 2009 | Amana Easy Reach Plus ABL2037FESL...
My bottom fridge is not getting cold but my top freezer works
The air circulation is neede to prevent this Make sure it's the freezer fan you hear running.
The fridge gets its cold air from the freezer through a vent(damper)between the freezer and fridge.The fan in the freezer blows air throughit. There is a flap you adjust with thefridge temp. control. Make sure it's opening and closing when you adjust thefridge temp ..
If the evaporator coils behind the back panel of the freezerare icing up because of auto defrost failure that will stop the circulation ofcold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Aug 16, 2009 | Frigidaire FRT18S6AW Top Freezer...
My Refrigerator and Feezer are not cooling. mff2557hes
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
we
Aug 01, 2009 | Maytag MFF2557HES Stainless Steel French...
The refrigerator is not getting or staying cold enough. the freezer seems to working ok
Check the vent at the top of the shared refrigerator wall for cold air from the freezer. If not, then you can either replace the motorized flap inside the vent or prop the flap open with a stick or something. The manual solution won't harm anything. The motorized flap is an over-engineered solution designed to create service calls. :<)
May 21, 2009 | Frigidaire FRS3R5EMB Side by Side...
FRIGIDAIRE REFRIGERATOR PROBLEMS
Freezer stayed cold but upper compartment wouldn't. Freeze started having problems with staying cold. I just paid $377 to get the two year old evaporate fan replaced. It is located inside the frig behind the panel in the freezer compartment. It took about 15 minutes. Seems this part is part of the evaporator system but not covered by anything other than the first one year warranty. Problem solved but what a ripoff from Kitchenaid.
Jun 21, 2008 | Refrigerators
Dual cooling fridge feezer top part of fridge warmer than bottom
You're frosting up. Either the box is set too cold or you've got a moisture problem which requires a full defrost. The fan noise is the blades hitting ice. Leave the unit open and off for a day or more and then start with standard factory settings. Avoid open liquids and window shopping inside your fridge.
Feb 01, 2008 | Refrigerators
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
Top Kenmore Refrigerators Experts
John Tripp
John Tripp
minguy15
Level 1 Expert
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
