Question about IBM ThinkPad T40 2373 Notebook
Operating system not found
Pxe-e61:media test failure, check cable operating system not found
  • IBM Master
  • 32,281 Answers
The error PXE-E61: Media test failure usually means the hard disk has failed or the hard disk needs re-seating or the disk controller is faulty. First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Posted on Jan 13, 2013
4 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: Operating System not found PXE-E61 Media Test Failure IBM T42
Some BIOS allows for a hard drive diags. try it to test the hard drive, if ther is no such utility you need to test the hard drive anoter way.
Basically either the hard disk controller has failed or the hard drive is faulty. In most cases the hard drive is dead.
To check if the hard drive is OK, remove the hard drive and attach it to a USB hard drive adapter then plug it into a working computer's USB port. If the computer sees it as an external drive and you can view the contents of the external drive then the hard drive is OK.
Posted on Mar 22, 2009
  • 32 Answers
SOURCE: pxe-e61,pxe-m0f
No; the message indicate absence of hard drive.
open the laptop and remove the hard drive and reinstall it.
if the message still appear then your hard drive is faulty.
Posted on Jan 01, 2010
  • 11800 Answers
SOURCE: it appears INTEL(R)BOOT AGENT CE
This means that the motherboard is dead - it no longer detects its own southbridge chip, the one that controls the hard disk.
Time for a new laptop.
Posted on Oct 20, 2010
Pxe E61 Media Test Failure Check Cable
my server ph prolite doesn't start gives an error essage "PXE-E61: Media test failure, check cable" the reboots after 5 seconds
Apr 22, 2012 | HP ProLiant DL180 G5 Server
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
When i start my lapt top i get black screen that reads intel undi,pxe-2.1 (build 082) for real tek rtl8101e/8102e pci-e enthernet controller v1.07 (080320)pxe-e61 media test failure,check cable pxe-mof...
If the sound you are referring to is a clicking sound, then it is a hard drive failure.
Your computer is trying to boot up the operating system from the hard drive, but when it fails to access the hard drive, it tries to boot up from other devices configured on the BIOS. Apparently, your next choice for booting the operating system is set to the LAN card. Hence, you get the message "PXE-E61 Media test failure", which means that the computer tried to boot up the operating system over the network but it found out that your network cable is not connected to your computer's network interface card.
Dec 07, 2010 | Toshiba Satellite Laptop
My IBM T20 Notebook is given me this message -PXE-E61: Media test failure, check cable- and then say -Operating System Not Found- ---- What do I do?
The error message PXE-E61 is Network card that try to conect this is because hard drive failure or Operating System
check on the bios if you can see the hard drive if you see the drive it could be the OS
hope it will help
Nov 02, 2010 | IBM ThinkPad T20 2647 Notebook
PXE-E61: media test failure, check cable PXE-MOF: exiting broadcom PXE ROM Operating system not found
The motherboard has died - there is nothing that can be done to save it. Time for a new one.
Oct 10, 2010 | Computers & Internet
I keep getting codes pxe-e61 media test failure,
Something went wrong with your last installation. try reinstalling windows. But, before that go to BIOS and check the BOOTING devices
Nov 18, 2009 | IBM ThinkPad T42 Notebook
Aspire 3682 PXE-E61:Media test failure.check
PXE error means that it is trying to boot from an ethernet / lan connection.
check your boot order options first and set it to boot
1. Hard drive
2. CD rom drive
3. Floppy (or usb if you know how to do this)
4. network(aka PXE)
If it still fails then yes there MAY be an issue with your hard drive.
Check all hard drive connections before running off for a new one.
This can be especially true with SATA type drives most of which dont have any sort of true locking device to hold the connections secure.
Sep 28, 2009 | Acer Computers & Internet
Media test failure,check cable, exiting bordcom pxe rom os not found
check connections of hard drive. 2nd check boot order in Bios, remove Lan or network boot from top order. 3rd choice if not solved reset bios by removing cmos battery and putting back in to clear it.
Char S.
May 24, 2009 | Computers & Internet
check your harddrive, is it detected in bios ?
if no, it could be motherboard or hdd, but most of the time is hdd problem, so just replace it.
if yes, your operating system is corrupt, so you can reload your operating system.
Sep 30, 2008 | Computers & Internet
IBM ThinkPad T40 2373 Notebook Logo
157 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
