Question about Sunbeam Cg-1 Vtg Waffle Maker Iron Replacement Parts
Plug gets hot on my vintage sunbeam CG waffle maker
  • Sunbeam Master
  • 494 Answers
You can replace the power cord on these models easy enough, as the cord is actually attached to a small black, plastic box that can be opened to replace the cord. You can find cords at home improvement or hardware stores. Before going this route, make sure the wall outlet you are plugging the waffle iron into, is properly grounded. You can check this by using a small outlet testing tool that lights up green or orange if installed properly or improperly. It also checks for reverse polarity, in addition to bad ground.
Posted on May 19, 2015
graemevm
  • 519 Answers
SOURCE: I am looking for a replacement rubber foot for our
Go to:
http://www.sunbeam.com/ServiceLocator.aspx?section=kitchen
Then select your area from the drop down menu to find out where your nearest service center is.
Best wishes,
Graemevm
Posted on Jan 10, 2010
SOURCE: No instructions for used Sunbeam#3856 waffle maker
download here:
http://www.retrevo.com/support/Sunbeam-3856-manual/id/952ag122/t/2/
Posted on Jul 28, 2010
SOURCE: I have a ventage sunbeam waffle iron model CG and
Yes, you do have to remove the knob.
you can see a step by step disassembly, with pictures, here:
http://www.lahabraheights.net/SunbeamCG_WaffleMaker/SunbeamCG_Disassemble.html
Posted on Feb 04, 2011
SOURCE: Looking for used "Sunbeam Waffle Baker &
I have a Sunbeam Radiant Control Waffle Baker and Grill with original care and instructional booklet dated 1954,
Posted on Mar 05, 2011
joeguest2
  • 2080 Answers
SOURCE: I lost the instructions for
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
Posted on Aug 31, 2011
What is the best electric waffle iron to make waffles at home?
In my opinion, the best waffle irons are the vintage ones made here in the USA. They are more durable and more reliable than anything made in China today. Look up the older Sunbeam, Toastmaster, Kenmore and G.E. models and you can usually find either round, square or rectangular versions, as well as models with and without non-stick coatings. The years from late 50's to the late 70's are best.
Jul 31, 2015 | Cuisinart Kitchen Appliances - Others
How do I replace the coil on my WMB-4 waffle maker?
It's most likely not the coil that's the problem, probably a thermal fuse. Unfortunately, these Made in China waffle makers do not last and are basically disposable after a few short years. Better off replacing it with a good quality, vintage 'Made in USA' Sunbeam waffle iron. You can find good deals online on eBay and Amazon.
Feb 20, 2015 | Cuisinart WMB-4 Belgian Waffle Maker
Manual for sunbeam cg
Here's a link to the manual you're searching for:
Aug 16, 2014 | Sunbeam Kitchen Appliances - Others
Sunbeam CG manual
Here is a link to the actual CG & CG-1 (12 page) owner's manual.
http://www.meba.com/manuals/SunbeamWaffleBaker.pdf
How To clean Vintage Sunbeam CG Waffle Iron Grids?
It will tell you how to clean it properly.
Jul 17, 2014 | Sunbeam Cg-1 Vtg Waffle Maker Iron...
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Preparing Waffles
Joe.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
Goodmorning, I bought a sunbeam waffle maker at a garage sale. It looks pretty old. When I use it the batter sticks even though I put oil in the batter, and spray the griddle. Is there something I can...
Try preheating the griddle for 5 minutes, then spray a light coat of pam on the hot waffle iron plates, and then add the batter (standard batter should work) (I wouldn't add oil if it's not in the recipe). Good Luck to You with that....
Oct 11, 2010 | Sunbeam 3852 Waffle Maker
Looking for used "Sunbeam Waffle Baker & Grill" with Radiant Control w/removable plates. Had one back in 1954. OR...Toastmaster Model #269 "Waffle Baker".
Jun 08, 2010 | Sunbeam 3852 Waffle Maker
I am looking for a replacement rubber foot for our waffle maker. It's the sunbeam 3 in one sandwich grill and waffle maker. It's the little black rubber foot that keeps it from wobbling. Any ideas...
Go to:
Best wishes,
Graemevm
Jan 10, 2010 | Sunbeam 3852 Waffle Maker
download here:
Apr 30, 2009 | Sunbeam 3852 Waffle Maker
Sunbeam Cg-1 Vtg Waffle Maker Iron Replacement Parts Logo
414 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
