Question about Technics Audio Players & Recorders
Rs-t11 wont record - Technics Audio Players & Recorders
Forgot admin password Dedicated Micros Digital Sprite 2 RS Video
You can't. You have to send it back to dedicated micros, unless of course you can use hyperterminal.
Feb 07, 2010 | Dedicated Micros Digital Sprite 2 RS Video...
The player wont record. All other functions fine including playback and finalising.
You mean it records silence? if it finalises then it does recognise and burn to the disc- so the laser/drive seems to be ok..
If silence, bear in mind there are analogue, optical and coax digital inputs to chose from for record source
Don't forget too these units need the special CD-R audio discs not CD-Rs to record to.
Oct 19, 2009 | Marantz DR-700 CD Player
How to reset waste ink full epson t11
first go to this website download their software http://www.ssclg.com/epsone.shtml. after that install.
second go to counter reset improvements reset counter or go to protection counter to reset counter.try this but i no sure which oen please try this two method to see can or no
Apr 09, 2009 | Office Equipment & Supplies
Denon CDR-W1500 not recording
I had the exact problem and could not get any of the CR-Rs that I had to work. I looked up the code in the user's manual where it said the error means it's not a recordable audio CD and to refer to page 6. I looked at the front of the manual and saw that it mentions that the CD-Rs must be audio CD-R discs. I did some research online and found that there are in fact differences between CD-Rs that are just marked that and those marked as Audio or Music CD-Rs. I bought a set of CD-Rs that clearly had marked "Compact Disc Digital Audio Recordable" on the package. When I inserted this disc, I had no problems getting the recording to work. So, make sure the discs you use are clearly marked "Audio" or "Music". A computer burner won't know the difference, but your Denon recorder will.
Jan 27, 2009 | Denon CDR-W1500 2-Disc CD Recorder
MyPhone T11 cant transfer via Bluetooth
ahhm madali lang poh.nong bumili poh ako ng myphone t11. ang ginawa ko lang poh. linagyan ko poh ng sd card, and ang "sd card "nya poh ay micro SD. malapit pof yon sa my lalagyan ng baterry. tingnan mo na lng po sa manual booklet nun. baka andun poh. thankz poh
Nov 05, 2008 | Lands Phones
Initalizing DVD-Rs
are you using a quality brand of dvd-r like memorex.
Also after making a recording you must finalize the disc you recorded so it will play on other players.
Jan 08, 2008 | GoVideo Go Video VR3840 DVD Recorder/VCR
CD-R does not read disks anymore
I recently resolved CD-R recognition problems with the KLH CDR2000. It's absolutely imperative that you utilize CD-Rs bearing the logo "COMPACT DISC DIGITAL AUDIO RECORDABLE". These specific CD-Rs are designed for digital music recording with the KLH CDR2000 and other simular products. I have a Marantz CD20 that has the same CD-R requirement. I purchased a Memorex 50-pack from Best Buy for approximately $20.00 plus tax. The recordings with the Memorex CD-Rs are immpressive for the KLH CDR2000 given the obvious flaws in design. Again, when searching for compatible disc for the KLH CDR2000 look for the words "DIGITAL AUDIO" within the "COMPACT DISC RECORDABLE" logo.
Jan 25, 2007 | KLH CDR2000 2-Disc CD Recorder
49 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
