Question about Kenmore 56722 / 56724 / 56726 / 56729
No water to door
Problem getting water to fridge door. Door is no frozen and either is the fridge(I defrosted them).Also changed filter. When you press for water the motor works.That is the one one the frige side, the motor on the freezer side does not work when you press for water. Can someone please help me with this problem.
  • 1 more comment
  • nick vocino Jul 07, 2007
    No to all of these.
    Door is not frozen and either is the fridge(I defrosted them).Also changed filter 3 times.
    When you press for water the motor works.That is the one on the frige side, the motor on the freezer side does not work when you press for water.The ice machine works fine.
    No it is not in the lock position. Any other ideas?
    Thanks found the problem! Switched water pump to ice maker pump and now the water works.
    Thanks the Nickster
  • 432 Answers
Did you change any settings resently or move the fridge? Water line could be kinked. Could be a frozen water line. If the ice maker is set on rapid ice, turn it off. You could turn the temp setting down for a day to see if that helps. Do you have any leaks behind or under the fridge? Check the filter again, make sure you pulled the shipping tag off and that it is seated properly. Freezer temp could be set too cold. Make sure the freezer door closes properly and that there isn't anything hendering it.
Posted on Jul 07, 2007
  • Raymond Scott
    Raymond Scott Jul 07, 2007
    Make sure the dispenser button lock isn't in the lock position.
  • Raymond Scott
    The water pump is not pumping water to the frozen water dispenser.
No cold water, ice maker works fine but no water from the door
HI THIS SOUNDS LIKE WATER DISPENSER FROZEN.DEFROST FRIDGE FIRST.GOOD LUCK.ALI
Jun 27, 2012 | Samsung Refrigerators
Seems the freezer door was not completely closed. Ice started ot melt and then form icicles! Well we closed the freezer the next morning. Now the ice maker and water dispensor are not working. In...
when you closed the door, the freezer froze all the condensation/melting ice,hence the icemaker freezing.
the best solution is a TOTAL defrost/clean out,then dry out.DO NOT USE HOT WATER/SCRAPERS,let it defrost naturally or use car de-icer.wipe out with bicarb to keep fresh.and then restart as new.
Sep 11, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
My water dispenser will not dispense water. I
you just need to defrost turn off fridg. over night it is frozen in the frezzer door
Feb 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
I left my freezer door open by accident on a beko cda540w fridge freezer freezer defrosted now when i turn the fridge back on it does not seem to freeze and the fridge stays warm i can here the fridge...
you may need to manually defrost the evaporator coil. If condensation built up from the door being left open, it may have frozen the coil solid. At that point even the evaporator defrost bar won't be able to remove the ice. Remove the cover, if it is frozen solid, unplug the unit and use a hair dryer to defrost the ice.
Nov 13, 2009 | Refrigerators
My whirlpool suddenly stopped dispensing water.
most fridges stop dispensing water when you open the door. Find the door switch and make sure fridge interior light goes on/off when you manually press door switch. This would show you that the door switch was faulty.
If the water connection to the appliance is one of those watts flood-safe water lines, it may have stuck shut. I've seen this happen when the house water pressure is too high.
Does it still make ice?
If so, then the water connection is good, and either the switch in the water dispenser has failed or the water shutoff valve for the water dispenser has gone bad.
Some models have a problem with the water line getting frozen, such that simply leaving the light on in the water dispenser compartment overnight and/or manually defrosting the unit can get it working again.
Nov 02, 2009 | Refrigerators
Water leaking out the front freezer door... the bottom of freezer unit has water pooled in it frozen... melts and runs out the door
The defrost drain hole in the bottom rear portion of the freezer is frozen shut. Turn off the fridge,use a hair dryer to defrost the drain hole. Pour a 1/4 cup bleach into the hole after is is cleared out. Turn the fridge back on.
Aug 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water dispenser won't shut off nor will the ice dispenser motor
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Electrolux Refrigerators
Things are freezing in my Fridge & Water Dispenser isn't working. I recently put items in my automatic ice maker for lack of room and freezer is overly stuffed. Could this be the reason? I'm assuming that...
Wrap all food together in blankets to insulate. But first check for a kink at the bottom of the freezer door where the water line comes up trough the door ,disconnect and press for water. If not check at filter if all fails; replace water valve.
Mar 25, 2009 | Frigidaire FRS23H5AS Side by Side...
Side-By-Side GE Fridge Won't Supply Water
Sounds like a frozen line ... press on the inside door lisen to see if there is ice inside defrost the freezer check if water will flow ... if stainless steel door there is a heater kit you can put in... if plastic you will have to replace the door.
Dec 15, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
No water flow
turn the freezer side to zero fridge side will zero also . click for water it should work . just worked for me no water for 1month replaced the filter and everything.
Dec 06, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Kenmore 56722 / 56724 / 56726 / 56729 Logo
66 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
