Question about RCA 20F512T 20" TV
I an RCA TV Modle# 20F512T the fuse keeps blowing . maybe I'm puting in the worng fuse . What is the right size fuse amp and volt.
  • 5 more comments
  • kris30_hamil Jan 23, 2009
    the tv fuse in side it is litttle
    it says T3.15A 250V, hubby got a A3 250v
    But is that why it keeps blowing .(the worng size fuse?)
    is that the power cord?
    how much would a transformer and can you send a pic of it
    ok but what would it look like so they dont try to rip me off.
  • Mike McWhinney May 11, 2010
    Which fuse is blowing? Do you mean your breaker fuse for your house wiring? If your breaker is popping, then there is something internally wrong with the RCA TV, like a short circuit in the wiring).
  • 537 Answers
You might look at this FixYa link:
http://www.fixya.com/support/t244483-tv_will_not_power
Do you still have the original fuse? There is numbering on there that shows the specifications. You probably need a slo-blo type fuse, 3A or so, but I can't be sure on that.
Posted on Jan 23, 2009
  • 3 more comments
  • Mike McWhinney Jan 23, 2009
    Try this link:
    http://www.radioshack.com/search/index.j...
    I would get the fuses from Radio Shack.
    One of these should do the trick
    If the fuse keeps blowing, even though the correct type is installed, then there is another problem (probably with the power supply) that is blowing the fuse.
    The power supply is inside the TV. It has the transformer.
    Check this link:
    http://www.fixya.com/support/t244483-tv_...
    You might contact RCA for information on repair/service for this. Otherwise if there is someone locally that can take a look at it (like a TV repair shop). I would not spend more than $50-80 to repair it.
    In general, a transformer/power supply will look something like this:
    http://www.made-in-china.com/image/2f0j0...
Need manual for RCA TV Model 20F512T
https://www.samswebsite.com/en/photofact/details/index/id/222590
Aug 03, 2015 | RCA Televison & Video
Can you help i lock the fpa of My RCA tv model
Here is a link to the online manual for your TV. It has instructions on how to resolve your problem.
http://tv.manualsonline.com/manuals/mfg/rca/20f512t.html
Dec 06, 2014 | Televison & Video
I have a 86 dodge d100. It keeps blowing the main fuse from the alternator to the battery. I have a 100 amp alternator and a standard regulator. Do you think I need a bigger regulator. It only blows...
More testing and info needed. With the car stopped, how many volts at battery? With fuse out, how many volts at each terminal? With vehicle running, repeat previous measurements. What size fuse is popping? Answers to these questions will lead you in the right direction.
Nov 30, 2014 | Cars & Trucks
My Fender LX1506 powered mixer keep blowing the fuse as soon as i turn it on what is the problem?
There is a direct short somewhere. Is the fuse the right size amps? volts? You dont want to put an dc fuse in an ac power amp. Double check your fuses.
Apr 11, 2012 | Fender Music
RCA 20F512T, unable to get sound on tv. It worked
check in menu, enter in the audio setup and check if tv speaker is in on.
Apr 21, 2010 | RCA 20F512T 20" TV
My tv wont turn on when i push the power button it ticks??? what coud be worng
if your tv is not powering on, firstly check the switch contacts, rectifier diodes, power trsnsistor, fusible resistors and zener diodes. all these components are at power supply section.
make sure that a HT voltage of 90-115v, shows at the line transister near the line transformer.
note-----a tone be head on the supply.
Apr 29, 2009 | RCA 20F512T 20" TV
No power to tv
The power management and protection circuits have taken over. There is something taking too much current and the protection system has shut the system OFF to prevent further damage ...............if you are familiar with tv service you can check the main fuse that should be close to where the power cord comes in,if you find the fuse blown it needs to be replaced with an exact replacement for AMPS rating and VOLTS rating as well as size,if the fuse is blown black we might have more problems ahead in the circuit and it will blow up again as soon as you plug the tv back in,if it blows again it will need a more involved repair,the problem could be in the primary side of the power supply.......Check horizontal output transistor.............
Feb 04, 2009 | RCA HD52W59 HDTV Projection Television
Rca 27f630t
It takes a star driver if I am not mistaken to take the back off probably two different sizes one for the top bottom and sides and one size for where the rca jacks are.. I only recommend checking the fuse...if blown never put foil around it. Takes a 4 amp. 5 amp would be ok. Dont go over this. If the fuse is good you should take to a good tv repairman. If blown and blows the fuse you put in take to tv repairman. Anything past this is highly technical. Hope you have a blown fuse only.
Dec 30, 2007 | Televison & Video
RCA 20F512T 20" TV Logo
111 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
