Question about Magellan RoadMate 2000 GPS Receiver
I have a Magellan roadmate gps that will not turn on. I've plugged it in and it still does not turn on. Can you please help me?
  • Anonymous Feb 14, 2009
    my gps just shut off one day and will not turn back on.
  • 537 Answers
Look at this link:
http://www.fixya.com/support/t1437928-magellan_roadmate_turn
Posted on Jan 23, 2009
My magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Dec 18, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Reseting the Magellan Roadmate 360 to the factory settings
Hello there:
here is a couple of linkds that i was able to retrieve hopefully they will help you ok
best regards michael
  1. [PDF] Magellan User Manual 3519k - Adobe PDF - View as html The Magellan RoadMate 800 is a vehicle ... segments totalling 360 degrees. Starting at the Prime Meridian (which is ... 11.2 Resetting the Magellan RoadMate ...www.magellangps.com/assets/manuals/MRM_800NA_en.pdf
  2. Magellan RoadMate 360 Manuals, Support and Troubleshooting - GPS Free download of Magellan RoadMate 360 User Manual. Troubleshooting ... Resetting the Trip Computer " • Viewing a Saved Trip Report " • Deleting a Trip Report " ...www.retrevo.com/support/Magellan-360-GPS-manual/id/421ag200/t/2 - 109k - Cached
  3. Magellan_RoadMate_360_North_America_Manual Documents_and_Forms ... Magellan RoadMate 360 North America User & Instruction ManualGet access the the ... Resetting the Trip Computer. Viewing a Saved Trip Report. Deleting a Trip ...store.payloadz.com/str-asp-i.388383-n.Magellan_RoadMate_360_North_America_Manual_Othe... - 189k - Cached
Sep 18, 2009 | Magellan RoadMate 360 GPS Receiver
Magellan roadmate 1412
Try the reset button on the side above the plug in.
Jan 14, 2009 | Magellan RoadMate 1412 Car GPS Receiver
Magellan roadmate 2000 will not turn on!!! help please!!!!
You have to reset the unit with the slid switch and reset button on the teft side under the rubber cover
see your manual.
Dec 27, 2008 | Magellan RoadMate 2000 GPS Receiver
Magellan Roadmate 760
My Magellan Roadmate 760 turns on and brings up the Magellan screen and then it locks. Can anyone help.
Sep 02, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan roadmate 800 unlock code
turn off your unit with the slide switch on the top. Hold down the repeat button or the one beside the slide switch and then put the slide switch back to the on position. Then select hdd tools then format. exit out and turn the switch off and back on and it should work
Apr 02, 2008 | Magellan RoadMate 800 GPS Receiver
Help me please
I had the same problem caused by reformatting the internal memory and this is what I did which worked for me:
Make sure you remove any SD memory cards before trying this fix.
First: find the base maps (NA_BSMAP.mgi and NA_BSMAP.nlt)maps which are located in your computer in the Magellan Roadmate Manager (C:\ProgramFiles\Magellan\Magellan RoadMate Manager NA\Map\Basemaps)
Second: Connect your Roadmate with the USB cable to your computer.
Third: Plug in USB and power up your GPS. Cut and paste the two files mentioned above to your GPS (Devices with Removable Storage (example E:/). They are approximately 25 MB in size and will take a few minutes to copy.
Fourth: Unplug the USB cable and shut power off to the GPS.
Fifth: Power up the GPS and it should find the "base maps".
Good luck!!
Dec 26, 2007 | Magellan RoadMate 300 GPS Receiver
RoadMate 700 GPS is not working..
Does the initial Magellan screen appear? If it doesn't display anything and it's just blue... :( Normally means that something on the main board is your problem. Which, means your out of luck. What happened to it? It just suddenly stopped working? Let me know. R/
Sep 17, 2006 | Magellan RoadMate 700 GPS Receiver
Magellan roadmate 300
check the fuse in the plug - usually a ring around the end that unscrews and the fuse and a small spring will be inside the small metal pin that sticks out the end. Hope this helps, please post again if not :)
Sep 09, 2006 | Magellan RoadMate 300 GPS Receiver
Magellan RoadMate 2000 GPS Receiver Logo
122 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
