Question about Panasonic Smart Viera 50 Class UT50 Series Full HD 3D Plasma HDTV
Panasonic Viera UT50 shuts down and power light blinks 7 times. What is wrong?
I know that the blinking light is a fault code, but I can't seem to find a list of codes anywhere. Does anyone know what 7 blinks means? Any help would be greatly appreciated.
  • 1779 Answers
SOURCE: TH-42PX80U JUST TURNED ITSELF OFF
The 7 blinks indicates that a failure has happened within the Y main and the upper and lower y drive panels. I recommend you taking it in to a Service center for and evaluation.
Posted on May 23, 2009
tvservice306
  • 458 Answers
SOURCE: Panasonic Viera TH-42PV7HS Plasma does not turn
replaced su or sd board and check sc board
Posted on Nov 10, 2009
Raditronic
  • 196 Answers
SOURCE: panasonic viera wont come on
The problem is not the power supply, is with the tunner board voltage. change the P.A board fix the problem.
Posted on Apr 22, 2010
  • 418 Answers
SOURCE: panasonic 42
Loss of power from power supply. Usually bad power supply.
Posted on May 02, 2010
tvhelp-Dave
  • 178 Answers
SOURCE: error codes. no picture or sound after turning
When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
Posted on May 16, 2010
Panasonic TC-P55UT50 plasma went black. power light blinks 7 times, pauses blinks 7 times. Is this a power board? or Y-Sustain?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 06, 2016 | Panasonic Viera TC-P55UT50 55" 3D 1080p...
I have a Panasonic TC-P65ST50 which recently began shutting down and displaying 7 blinking lights and 8 blinking lights. Most of the time 7 blinking lights are displayed.
http://electro-medical.blogspot.com/
Feb 25, 2016 | Panasonic TC P65ST50 - 65" Class 64.7"...
Panasonic TC P5G20 turns on but screen will not activate. It then clicks and the led blinks 13 times. I've turned it off and on a few times and once the light blinked 4 times, but it's now...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Dec 16, 2014 | Panasonic Tc-p50g20 Viera G20 Series 50"...
My Viera TV: TH-P42ST30z seems to have shut down. When I turn it on the pilot light initially flashes green then starts a sequence of 7 red flashes, a gap, 7 more red flashes and this continues indefi
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Oct 09, 2014 | Panasonic Televison & Video
Blinking red power light on a Panasonic Viera 47 in. plasma
No sure how many blinks you have but here are the blink error codes and the common boards failures for each
Blinking Times Contents Check point
1 Panel SOSPanel
3 P+ 3.3V SOS A-Board
4 Power SOS P-Board
5 P+ 5V SOS A-Board
6 Driver SOS1SN-Board
7 Driver SOS2SN-Board
8 Driver SOS3SS-Board
9 Discharge Control A-Board
10 Sub 5V SOSA-Board
SN-Board
SS-Board
P-Board
12 Sound SOS A-Board
Speaker
13 Emergency SOS A-Board
Feb 01, 2014 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
7 blinking light on TCp54s2
7 blinks? Driver SOS 2 SU / SD / SS Boards (SC floating voltage area). These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 12, 2013 | Panasonic Viera TH-50PZ800U Plasma TV
What does 7 red blinks mean?
7 blinks of standby light to Panasonic brand Plasma TVs means; Driver SOS 2 SU / SD / SS Boards (SC floating voltage area). If you wish to get more details about the blinking codes and faults to Panasonic Plasma TVs, check this site. There is explanations with illustrations to many faults to many brand TVs, including Panasonic. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Jan 28, 2013 | Panasonic Smart Viera 50 Class UT50 Series...
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic Smart Viera 50 Class UT50 Series Full HD 3D Plasma HDTV Logo
115 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
