Question about Epson Office Equipment & Supplies
Epson al-cx11 ip address - Epson Office Equipment & Supplies
2 Suggested Answers
SOURCE: What is the IP Address for Epson TM- U220PD
If you have the same model, on the back of the printer next to the ethernet port is a little button/ hole. Push and hold that down for a couple seconds until it starts printing. It will print out the IP address. Manually assign your computer to have an IP address in the same range (I.E. if the printer says 192.168.1.23, set your computer to 192.168.1.29 with the same subnet mask, etc.). Plug a network cable from your computer directly into the printer. Then, you can change the settings.
Posted on Mar 04, 2010
Set up epson workforce 600 printer wifi via dlink dir615
Configure the IP address range your wireless printer, (this is done through the printer's menu settings) make sure it matches the IP address range on your wireless network, it maybe 192.168.1.*** then configure the wireless printer with a fixed IP address with the same IP address range but higher address eg. 192.168.1.10 so it does not clash with any other IP addresses.
Next install the printer driver normally.
Then configure the printer Properties.
Click Start - Printers and faxes - right click on the Brother printer - click Properties - Port tab - click Add Port - Standard TCP/IP port -
Port Name eg. 192.168.1.10
Printer name eg Network printer
Click OK
Then do a TEST print if it does not work then the IP address is probably incorrect.
Oct 26, 2012 | Epson WorkForce 600 All-In-One InkJet...
Tip
Steps to Configure Static IP Address for Epson Wireless Printer
The IP address is a specific number allocated to a device, which is connected to your PC network. If you require configuring a static IP address for your Epson printer, it can be possible by using the network configuration menu that you can access via the Internet browser on a connected system. To do that, it's necessary to know your printer's existing IP address. If you have a password protected the device, then you must know the username and password credentials to access your Epson printer network configuration menu. You can call at the Epson Printer tech support phone number and get expert's assistance to do that in a proper way.
Find Epson Printer's IP Address
    1.Click the 'Windows Start' button and choose the 'Control Panel' on any system connected to the similar network as your Epson printer.
    2.Double-click the 'Printers and Faxes' option and then find the Epson printer that you want to configure a static IP address for in the printer list.
    3.Right-click on the Epson printer from the list and choose the 'Properties' option.
    4.Click the 'Ports' tab and find the printer to configure a static IP address. Click on the printer to select it.
    5.Click on the vertical bar between Description and Port and shift it to the right to expand the Port column. Find the Epson printer's IP address under the 'Port' column, which is a series of numbers divided by, resembles and periods 192.168.1.2.
      1.Open up your favorite Internet browser on the system connected to the similar network connection as your printer for which you need to set up a static IP address.
      2.Input the printer's IP address into your browser address bar. Click the 'Enter' button.
      3.Enter your printer login information. If it's not password-protected, enter 'admin' text into the 'Username' box and leave the password field vacant. Click the 'OK' button, followed by the 'IP Configuration' tab to sign into the Epson wireless printer settings page.
      4.Find the 'IP Address Configuration' or 'TCP/IP' section and adjust the value from 'Auto' to 'Manual' or 'Static.'
      5.Input the static IP address that you need to allocate to the Epson wireless printer into the provided boxes. It forces the network to assign the selected IP address to the Epson printer every time it tries to connect to the computer.
      6.Click the 'Save' button to apply the settings and close the browser.
      Additional Tips:
      Configuring a static IP address for the Epson wireless printer is not a complicated process if you are a tech-savvy user. However, if you can't set static IP address for your printer even after following these steps, you must avail the help and guidance of technicians that can be possible via the Epson technical support phone number. They will assist you step-by-step to configure IP address of your printer in an efficient manner.
      Source: http://bit.ly/2lJLWxS
configure static ip address for epson wireless printer-yxa4stq55mknsqg0b4p2yanw-2-0.jpg
on Feb 15, 2017 | Epson Office Equipment & Supplies
How to set ip address for epson dot matrix printers
How to remove the ip address,for dot matrix printer?
Feb 06, 2012 | Epson DLQ 3500 Matrix Printer
I have a 2wire486 modem from AT&T at home. Can you please show mw how to connect Epson AL-CX11 advanced printer to this modem? Thanks
Welcome to FixYa.
Please click the link below for the step by step instructions on how to connect your printer to your home network (2wire router). Your printer is a high end business machine so setting it up is quite different from the regular printers. If you are using a Windows Operating System (Windows XP/VISTA/7), ignore the notes and instructions that refers to MAC OS.
http://files.support.epson.com/htmldocs/cx11nf/cx11nfng/lhowt_4.htm
Thank you for using FixYa.
Have a great day.
Jas247
Jun 07, 2011 | 2wire Computers & Internet
I have one Epson TMU220PD printer. I have to set its IP address. how can I do it. Also, i want to know its default IP. Thanks, Saket
switch on your printer while pressing feed button.printer will print some pages and u can read ip address of printer in printed page.Then add same ip range in ur computer.connect printer to pc by network cable.test ping command to printer ip address.if ping succes then open internet explorer, type printer ip address in address bar, press enter key..there u can set ip adress from tcp ip options.
Oct 23, 2010 | Epson TM-U220 Matrix Printer
Epson AcuLaser CX11NF does not worik on Ubuntu 10.04LTS
Check the bottom of the comments here for a solution. The Epson AL CX11 now works with Ubuntu 10.04 x64
http://www.gedda.info/?p=132&cpage=2#comment-31938
Aug 11, 2010 | Epson ACULASER CX11NF All-In-One Printer
Ip address IR2800
You need to tell copier the IP, gateway and subnet. If you have DHCP set Ip on auto.
Jan 27, 2010 | Sharp AL-1642CS Copier
How change ip address of epson epl n2500
Hi, i know its been months already but i have a solution to your problem, we have same problem and i solved it already..First, you have to get the ip address of your printer,..Then, open command prompt..
At command prompt, Try this command;
telnet ip address (this is your ip address)
Then, as you can see, their is a lot of instructions there..
So, you must follow it..
Take note: It automatically saved the changes.
Second options:
Type the ip address of your printer at web browser, it looks like this:
http:/192.168.1.100/ (this must be your ip address)
Then, as you can see, there is a lot of choices there.
So, you have to choose the configuration to change your old ip address.
I hope it can help you..
Thanks
May 13, 2009 | Epson EPL N2050 Laser Printer
Epson Aculaser CX11 NF
I had the same problem which turnedout to be the photoconductor. The only solution is to fit a new one.
Jeff B
Jul 31, 2008 | Epson ACULASER CX11NF All-In-One Printer
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
