Question about Samsung Electronics - Others
Samsung refrigerator leaks
Leaking on the inside
aborcass
  • 2651 Answers
SOURCE: Estate TT21AKXKQ Refrigerator Leak
sounds like you have a clogged defrost drain tube. removing back panel of freezer will give you acess to drain trough, melt away the ice with a hair dryer, youll find a drain hole under there somwhere,pouring boiling water down the drain will clear it pretty quickly( i use a steam machine purchased from the infomercials works awesome, after you clear it and all water drain down tube wrap a piece of solid copper wirearound the heater( black calrod heater right above the drain trough) and stick it in the whole maybe an inch or so. now everythime the heater comes on to defrost it will prevent the hole from freezing over
Posted on Mar 18, 2008
SOURCE: frigidaire refrigerator leaking water inside refrigerator
There is a plastic panel inside the frigidaire looking at the underside of the freezer inside the refrigerator compartment which holds the thermostate dial and the light fixture. remove the four 1/4 in hex head screws holding the assembly. pull the panel toward the front. you will expose the drain hose connection you can let it dangle from the plug wires or remove the panel completely, I worked with mine in place. look at the back funnel shape drain. just in front of that see a rectangular styroform collar which should be snug fit to match the underside. clean and dry all. there is a divider between the two funnel compartments, mine was separated between the plastic and the styroform. I used kitchen and bath tub caulking to seal the gap. and a little around the rectangle shape that fits to the underside. plug the wire back in if disconnected. reassemble the panel. that may fix it. good luck.
Posted on Jun 17, 2008
SOURCE: Leaking Whirlpool refrigerator
My Whirlpool fridge had water droplets falling onto all three shelves and pooling unter the crisper drawers. I solved the problem by clearing the ice-clogged drain in the freezer.
In Whirlpool model ET21UM, the condensation drain hole is located directly behind the freezer. To access the drain hole, remove all your frozen items and place them in a large picnic cooler. Notice that the floor of the freezer is basically a large plastic tray fastened by two small bolts. Unscrew the bolts with a wrench or ratchet and remove the plastic tray. At this point you will probably see that water has seeped under the tray and created a mini ice rink on the bottom of your freezer. You can tap the ice lightly with the handle of a screwdriver to break it up. Once it's broken, toss the ice into your sink, or put it in a plastic bag and store into your cooler to keep everything cold.
Once the ice has been removed from the freezer floor, you should be able to see a metal drip trough in the back under a false wall hiding the condenser coils. It's a little tougher to remove the ice from the drip trough with the screwdriver method, so you might want to use a hair dryer. After a few minutes with the hair dryer, you should be able to remove most of the ice by hand. You can remove any water with a sponge or turkey baster. The only ice left will be a plug of ice in the drain hole in the middle of the drip trough. Heat up a cup of water in the microwave and carefully pour it into the drip trough. If the drip trough is hard to access, you might need to use a funnel. The hot water should melt most of the ice in the drain hole. If it pools in the drip trough and doesn't drain, use a sponge or turkey baster to remove the water and add hot water again. A small length of wire or a pipe cleaner might help clear any other obstruction in the drain hole. When the drain is clear you should hear water flowing through it. Dry off the floor of the freezer and return the plastic floor tray to it's spot and fasten with the two bolts. Remove any water that has pooled in your refigerator and you're done.
Posted on Nov 12, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
rylee_smith
  • 8619 Answers
SOURCE: water leaking inside the refrigerator
Hi
Most times this is a plugged defrost drain system. The defrost heater in the freezer section melts the frost and changes it to water, this water is suppose to flow down a drain system. If this drain system is restricted or plugged the water will leak inside the refrigerator. The drain system starts in the freezer section with a tray built under the evaporator coil. The water is funneled through a small hose into a cup in the top middle of the fresh food section ( not on all models, but this is the most common way ), from there, the water is directed out the back wall to a drain hose that runs down the back of the refrigerator into a condensing tray. The heat created under the fridge makes the water evaporate and disappear. Some of the cups ( in the top back of the fresh food section ) can be removed for cleaning. A turkey baster can be used to help clean out the drain system. Fill the baster with hot water and "blast" it into the drain hose to help flush it out. A piece of wire or pipe cleaner can also be pushed into the drain hoses to help clean then out. On a S x S style of fridge the drain system is in the bottom back of the freezer section and often you will have to remove the evaporator cover to access the drain hole. You can clean this out in the same manner as previously mentioned, but because of the water leaking into the freezer instead of the fresh food section you will have to remove the ice build up to clean out the drain system. For some reason Whirlpool has found a need to "hide" the drain hose inside the walls now ( Whirlpool makes many of the Kenmore branded refrigerators ) on there top freezer refrigerators. This makes accessing the drain hose to flush it out more difficult, no cup inside the fresh food section, no hose down the outside back wall and the only access is inside the freezer section behind the back false wall and under the evaporator coils.
Please do rate the solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Posted on Apr 17, 2009
Fix leak inside Samsung refrigerator
water may not be leaking inside? What u may have is water condensation? this happens when u have a clogged or plugged evaporator drain plug line or bad seals on the door which allow air and moister to come in and CONDENSATE, THEREFORE WATER IN THE FRIDGE. U NEED TO CLEAN THE DRAIN LINE USE HOT WATER, AND A SOFT FLEX TUBING OF SOME TYPE
Feb 15, 2015 | Samsung Refrigerators
Water leak samsung rm255barb
sorry,don't have same refrig nor that kind of problem so can't help you!
May 29, 2014 | Samsung RM255LASH Side by Side...
Gas leaked out inside the freezer because of a small hole inside .can this be repaired?
If you know that refrigerant has leaked out for sure then you need to replace it these are nearly impossible to repair.
Apr 08, 2014 | Samsung Refrigerators
Water inside refrigerator
Because your model has an evaporator located inside the fresh food compartment it also will have a drain opening below that evaporator. This is a common problem with these dual evaporator models that have drain blockage caused by ice or gunk blocking the drain and causing water to flow below the crisper drawers. Sea Breeze
Nov 19, 2013 | Samsung RS275AC Refrigerator
WATER LEAK SAMSUNG RB215LASH
When water is leaking inside of your refrigerator, the problem could be as simple as condensation from humidity or a worn gasket, especially since you purchased your refrigerator used. The problem could also be a clogged drain or frozen evaporator.
To help you determine the problem, along with solutions that you can use, check out Refrigerator leaking water inside for some simple troubleshooting steps. I hope that helps!
Aug 02, 2012 | Samsung RB215LASH
Samsung frig is leaking water at the bottom - it does not appear to be leaking from the inside because it is dry, but from somewhere internally at the bottom. What would cause this? The temperature...
SMALL PLASTIC water pipe under front of door has joiner which changes from 8mm ? TO 10MM ? this leaked on mine and had to be replaced .any good plumbing supply shop could supply. May need to be tightned.
May 05, 2010 | Samsung RS2630AWW Side by Side...
Water is leaking on the inside bottom draw of the
Clean the drain tube and drain pan under fridge.It may be clogged.
Hope this helps.
Aug 06, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung rs21wcns has a leak
I found my leak, after checking all lines, connectors, couplers, behind the second to bottom drawer from what appears to be a cooling resevoir. It appears the seams are slightly leaking on both sides. I found water pooling under the bottom drawer and then leaking out the front and followed it back. My Samsung is model RS2556SH
Jul 04, 2008 | Samsung RB2155SH Bottom Freezer...
Electronics - Others Logo
29 people viewed this question
Top Samsung Electronics - Others Experts
Jeff Sterrett
Jeff Sterrett
Tom Chichester
Steven's...
Steven's...
Are you a Samsung Electronics - Other Expert? Answer questions, earn points and help others
