Question about Microsoft Xbox 360 Console
My xbox 360 cables input the one with the colors wont show the image but the sound comes out ive tried with the two tv's and the sound just comes out and i just bought another cables and is the same thing only the the sound comes out
  • Bobomonkey May 11, 2010
    What kind of tv are you trying to connect it to SD or HD? What kind of cables are they? Yellow Red and White or Red, Blue, Green, Red, and White?
    Problem Solver:
  • 3 Answers
Xbox repair in mumbai :- 9819767710/9867635653 ?xbox repair in mumbai :- 9819767710/9867635653 ?xbox repair in mumbai :- 9819767710/9867635653 ?xbox repair in mumbai :- 9819767710/9867635653 ?xbox repair in mumbai :- 9819767710/9867635653 ?
Posted on Jan 23, 2009
I have a daenyx lcd tv, model DN-15, input 12VDC-4A and am trying to hook it up to an xbox 360 console.
If you are using the Red/Yellow/White cable, that's composite cable, but if you're using the one that's Red/Yellow/White/Blue/Green, that's called component. So basically, you set your TV's input to the corresponding color match. 5 colors: Component, 3 colors: Composite.
Sep 13, 2014 | Video Game Consoles & Games
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
My sounds works and so does my directtv but no picture will show up for my 360 i bought a new av cord and it still wont work how do i fix it
Are you on the correct channel or input for the xbox 360? Also check your av cable to see if it is on the hdtv or regular tv. You can move the switch to make the adjustment. It may be how you have set up your xbox 360 cables and the directv box cables to the tv so you should consult your tv manufactory for the correct guide on setup.
Dec 22, 2010 | Microsoft Xbox 360 Console
Light is on and green but no video coming out to television what might be the problem.
Typically, this problem occurs if the audio/video (A/V) cable is not connected correctly, or if the A/V cable is faulty.
Solution 1: Set the television or monitor to the correct input
Make sure that the TV or monitor is set to the correct input for the console. Check the TV or monitor's manual to see how to configure the video inputs, or try to use the console on a different TV or monitor.
Solution 2: Connect the A/V cable securely
Sometimes, you can insert the A/V cable far enough to prevent any red lights from flashing on the Xbox 360 console but not far enough for the console to transmit images or sounds to the screen.
Solution 3: Switch the Xbox 360 Component HD AV Cable to the correct setting
Make sure that the TV/HDTV switch on the cable is set correctly.
  • For standard-definition TVs with only the yellow connector plugged in, set the switch to TV.
  • For high-definition TV or monitors with the red, blue, and green connectors plugged in, set the switch to HDTV.
For more solutions, check this web page.
Oct 09, 2010 | Microsoft Xbox 360 Console
My xbox shows no picture but has sound
This might not help everybody but it might be a cheap fast solution to the "Xbox 360 no picture but sound ok" problem. I have old refurbished 360 that has had no problems at all. SInce I got it have used it with powerwave cooler attached to the back. This cooler has seperate Outputs for Vga, SVga, audio, component and av. Don't need the microsoft cable at all just standard cables. Always had it plugged in with VGA or SVGA cables and got great picture. I bought new 360 and put the old one in bedroom with old tv which only has av inputs. Got shocking picture that was unwatchable but sound was good. Tried all ways but no different. Seems the xbox plug has problems. If you get the powerwave cooler it splits the xbox output socket in to seperate outputs for everything so you can use it with Vga or Svga cables if your tv has those inputs and it should work fine. Only seems to be the standard AV outputs that have problems. Haven't tried the componet leads but I guess they might work as well. If you only have the old yellow, red and white AV inputs on your tv this wont help you but if you have the other types of inputs it might fix it. The powerwave cooler you should be able to buy for under $20 so it could be a cheap solution for this problem everyone seems to be getting lately. It works for me at least so get one and give it a try.
Jun 16, 2009 | Microsoft Xbox 360 Console
Lose sound on phillips hdtv unless xbox360 is turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Jun 06, 2009 | Philips 42PFL7422D 42 in. LCD TV
XBox 360 to Reciever to TV via HDMI no sound
I recently got the same receiver and had the same problem. Here's what I was told - and it worked for me:
Even though HDMI cables carry audio and video, for whatever reason this reciever won't accept audio through hdmi. Apparently only much more expensive recievers carry audio through hdmi. What you have to do is run optical audio cables from your xbox, cable box, dvd player or other video device to the optical inputs on the back of the reciver. Then you customize the scene buttons to match your video and audio inputs.
You can get these optical cables pretty cheap on line or even at target. Don't get ripped off by Best Buy for these cables. I love best buy, but they rip off on cables!
This receiver is great - once I got it all figured out and running right I've loved it! Hope everything works out for you!
Mar 09, 2009 | Yamaha HTR-6130 Receiver
XBOX 360 NTSC only Black and White
yes xbox 360 NTSC only in black and whit colours
Feb 06, 2009 | Ulead Videostudio 8 for PC
Xbox 360 is showing purple lines on tv screen.
Hi...
Pull out the video cable from both ends.
Re-attach and try again
Let me know
Jan 18, 2009 | Microsoft Xbox 360 Console
Why wont my xbox play in color
Sounds like you are using the Component cables but are not on the correct component channel. Keep searching through your input channels to find the right one. Some older TV's that intergrated component inputs merged them with the normal input channels. I had this same problem with a JVC TV.
Jan 09, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
79 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
