Hard disc issues - Computers & Internet
  • 4 more comments
  • jeffreyjhook Jan 23, 2009
    when i try to, fill up my i-pod--back-up hard drive to ex-hard drive or defrag disc, hard drive makes clunking sound then i lose all controll
    what mean clean cables and the re arrange
    When I try yo back-up my hard disc to my 250 gb portable passport, it only works for about a minute then I lose all controll. The samething happens when I try to back-up my i-tunes, not a good situation.
  • Daniel Martinez
    Daniel Martinez May 11, 2010
    CLARIFICATION::
    1) What is "" fill up my i-pod ""?
    2) "" back-up hard drive to ex-(external?,extra?) hard drive""
    "" or defrag disc "" ??
    quick answer:: When a hard drive " clunks " it is usually failing or going to fail. copy all the important files to CD or DVD disc and get a new h/d.
  • Jarish Castañeda
    Jarish Castañeda May 11, 2010
    Please send more details pls.
  • Art Ellison
    Art Ellison May 11, 2010
    We need to have you tell us what the issues are. Be as specific as you can so we can offer you a solution that works.
  • 85 Answers
Clean the cables of hard disk and the re arrange it will work ...
Posted on Jan 23, 2009
  • zam zam Jan 23, 2009
My Dell Windows 7 laptop won't boot?
Press the Delete key during start up, to enter its bios settings window. At boot sequence selection, select CD ROM as first boot device, Hard disc to second boot device, and deselect all other boot devices. Means, there should be only CD ROM and Hard disc as boot devices, as said above, in sequence. Select 'Save and reboot' at the bios option, the computer will restart with hard disc; provided there is no CD at CD ROM. Gopakumar Gopalan Google
May 10, 2014 | Dell Computers & Internet
Unlock windows vista
1 fix for this issue is to use the restore disc that came with the pc. If you don't have those and u have a vista disc you can use the Vista disc to install Vista and get the vista code off the Microsoft sticker on the pc. You can contact Microsoft for help as well they may have a way of unlocking it. Also if you are looking to upgrade the pc and u have a Vista install cd you could just put in a new hard drive and then install Vista on it. Hope this helps you. The other issue is there may be a BIOS Password if so then there is a whole new set of issues.
Aug 28, 2012 | Compaq Computers & Internet
Pc not booting from cd
Hi ankushh91,
try a different Bootable disk and see if it will boot, also try you disc on a known good computer see if the disk you are using is bootable aswell to eliminate the cause of the issue.
When Booting from a disc make sure the disc is inserted in the dvd/cdrom drive once you turn the computer ON then you will see press anykey to boot to CD or disc if this shows just press any key this will boot to the Disc if it is Bootable it will show the message press anykey if the disc is not bootable it will only try and boot to the Hard drive directly.
I hope this can help,
mvincentc
Apr 17, 2012 | Lenovo Computers & Internet
M9500f gets into blackscreen at startup with blinking cursor at top left of screen. F11 (system recovery) don't work.
It is having issues booting from the hard drive, there could be a simple file corruption issue or a hard drive issue.
You will need to get hold of recovery discs or a windows disc to attempt to repair it.
Mar 08, 2012 | HP Computers & Internet
My hard disc maybe slow how can i make fastert
Run hard drive tests and see if it is actually what is slowing your system. I doubt the HD is the issue.
Jul 23, 2011 | Samsung Computers & Internet
Dell Vostro 1310 - when turned on screen still blank, numlock blinking, capslock and scroll lock light on and stable. tried changed new RAM,issue still persist. whats wrong with it?
it may be bios problem or loose connection with Hard disc... So, follow the below steps: 1.remove the battery and power adapter 2.press the power on button 2 minutes 3.replace the battery 4.now on the laptop normally... now see the result.... ---------------------------------------------------------- if not solved then follow the below steps
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 3.replace the battery 4.now on the laptop normally... 5.if any display appears then problem with ur hard disc or cd/dvd drive.
------------------------------------------------------ follow the below steps to check the problem with your hard disc or cd/dvd drive
1.remove the battery and power adapter 2.remove the hard disc,cd/dvd drive 6.connect the cd/dvd drive 3.replace the battery 4.now on the laptop normally... 5.if any display appears then the cd/dvd drove has no problem,then problem with ur hard disc drive. ---------------------------------------------------
Apr 17, 2010 | Dell Vostro 1310 Laptop Computer PC...
A305 keeps rebooting
You could have a few different issues.
1. You have a driver issue. Try running windows repair from Microsoft install disk.
2. Possible power supply issue.
3. Bad hard drive. Possible bad sectors. Nothing to do here but replace hard drive.
Try disconnecting all hardware in system except hard drive and video card. This will include network cards and any other peripherals. Try to boot up.
Jun 23, 2009 | E-Machines eMachines Desktop PC
Reformated used HP recovery disc when I restart it says SW build ID different from ID on recovery media
You have 2 options. You can write to Microsoft or to HP about your Issue & they might be able to help about the ID issue. Best I would suggest you buy the OS. ( Full installation Pack) this way you have nothing to worry.
May 11, 2009 | HP Pavilion a1610n PC Desktop
I have a blue screen on my DELL Inspiron 6000 with message UNMOUTABLE_BOOT_VOLUME
assuming you have a windows xp disc you would insert the xp disc and boot from the xp disc as though you are going to re install but when you get to the options select to go to recovery console / recovery mode and then use the following commands
fixboot
fixmbr
chkdsk /r
notice there is a space between chkdsk and the /r
the last command might take quite a while but should repair any issues.
Once done you should be able to boot back into windows - if not then it is an issue with your boot.ini file
http://support.microsoft.com/default.aspx?scid=kb;en-us;330184
If you have any problems let me know.
If chkdsk /r will not run or reports issues then your hard drive is most likely damaged and you will need to recover your data in which case make a bart pe disc :
http://www.nu2.nu/pebuilder/
Go to the FAQ / help section and it should give you a guide on how to create the bart pe disc but it is fairly straight forward
you will need your xp disc the download ( provided on the downloads section of the above website ) which you install and run and it will create an iso or allow you to burn the outcome to a cd which you can then boot off of and should allow you to recover your data.
The other option is to attach the hard drive in your dell to another computer making sure the jumpers ( if its an IDE drive ) to slave mode and then you should be able to retrieve your data off of the drive that way.
Apr 13, 2009 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
