Question about LG Televison & Video
Lg flat screen how do you scan for channels? - LG Televison & Video
What is the code for I can no what channel im on and for my letters and numbers to show on my 7"wide screen lcd tv with atsc tuner tv
      Select and highlight INPUT CONFIGURATION and press ENTER. Using the left/right arrow buttons, select Antenna or Cable as desired, then select DONE. Press the CH RTN button to go back to the TERRESTRIAL menu. Select START SCAN to begin the Channel Program.Aug 7, 2013
      How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
      forums.toshiba.com/t5/Televisions...To-TV...Program-Channel.../345660
    Feedback
    LG LED TV won't show program information or channel name ...
Jan 13, 2016 | Televison & Video
I run the auto scan and it is picking up 0 channels and say to please run auto scan
Where is your antenna hooked up? Thru a cable box? Direct to tv? Completely describe setup, maybe post photos
Apr 02, 2015 | RCA Lg 65lm6200 65" 3d Led Flat Panel...
How do i do a channel scan my lg tv with no remote
Without its remote control you can't do a channel scan.
Nov 28, 2012 | LG 26LX1D 26 in. LCD HDTV
Vivitar tv shows small square box that reads auto scan required. What does that mean?
YOU MOST LIKELY HAVE TO REPROGRAM THE CHANNELS THAT YOU GET.THAT IS WHAT THE AUTO SCAN DOES IT RESETS CHANNELS THAT RE NOT SCRAMBELD
Aug 09, 2012 | LG Televison & Video
How to initial The TV? Problem: Only one channel available when connect a cable right now.
Hello:
It sounds like you need to do a "channel scan". For the LG 26LX1D, you can follow these directions:
  1. Press the "MENU" button on your remote
  2. Use the Up and Down Arrows to select "SETUP"
  3. Press the ">" button
  4. Use the Up and Down Arrows to select "EZ Scan"
  5. Press the "ENTER" button
This will scan all available channels. You can edit the channels by choosing "Channel Edit" in the same menu.
Mar 06, 2011 | LG 26LX1D 26 in. LCD HDTV
LG 37LT 75 faults Picture freezes everything locks only solution is to pull plug and then restart. Occasionally just get black screen whaen changing channels. Recordings failing due to "time setting error"...
Call out an LG engineer, there are software updates which control the operations of the TV, it would appear that you have an older version & need this to be updated.
Jan 08, 2010 | LG Televison & Video
My flat screen lg tv has lost its channels,says its not programed...help
i was watching tv last night on my lg,and it went off and said no signal?so i went to retune and now it says not programmed i cant get my dtv channels back
Aug 20, 2009 | LG 42PG20 42 in. Plasma HDTV
I can not get some local channels but my converter box picks them up on other TV"s with no problems from the same out side antena. Why?TV is a LG super slim XD DTV
the only converter box in my house is in the bedroom. I have to scan each night for Channel 11 and in the morning its a black screen. Is it the box or Channel 11?
Jul 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
262 people viewed this question
Computer Repairing
Computer Repairing
