Question about Samsung Tracfone S425G Slider with Triple Minutes for Life and 1200 Minutes Tracfone
Trying to take a picture or a video on the phone, it says "capture failed".
Tried settings for both in-phone memory and memory card; neither is anywhere near full.
SOURCE: memory card settings
go to settings-memory settings-default memory-bluetooth-memory card
Posted on Jan 03, 2009
longgee
  • 322 Answers
SOURCE: root directory full of memory card
i suggest that you save a copy of that important documents that you are mentioning. Save a copy to your PC or flash drives. And as for the memory card, try reformatting it.
Posted on May 14, 2009
  • 36 Answers
SOURCE: My Samsung Propel says, "camera failed"
well I think the picture that you took before you got the problem with your camera..is corrupted ! try formatting ur memory card..then try ..that must do the trick..ok
Posted on May 25, 2009
SOURCE: Samsung Guru 1410 Memory problem
Goto Applications-->Bluetooth-->Default storage and change to memory card. Thats all
Posted on Jun 10, 2009
SOURCE: Samsung Pixon 12 Camera says 'CAPTURE FAILED'
camer not work
Posted on Oct 29, 2010
DV-136ZB can't take pictures to my computer.
Are you trying to transfer videos from your camcorder to the computer, or use the camcorder to create pictures directly on the computer ?
Jul 26, 2017 | Global New Beginnings DV-136ZB Camcorder
Tip
Tips for camera
Using the camera:
Your phone has a flash to help you to take pictures in different lighting environments. The flash is on by default, but you can turn it off or use the automatic setting. To set the desired mode when using the camera, select Options > Flash and Flash off, Flash on or Automatic.
Fast viewing with memory card To view your images and video clips quicker, use your memory card as the main memory for storing them.
In the camera application, select Options > Settings > Image / video storage > Memory card.
Capture and send You can send the picture immediately after you have taken it when you are previewing it. To display a picture immediately after you take it, select Options > Settings > Image preview time and the preview time. During the preview time, select Back to take another picture, or Send to send the picture as a multimedia message.
Print your images Your phone supports Nokia XpressPrint to print images that are in .jpg format. To print your pictures, connect your phone to a compatible printer using a data cable or send the image by Bluetooth to a printer supporting Bluetooth technology. Select the image you want to print from the Gallery, and when viewing the picture, select Options > Print.
on Jun 13, 2010 | Nokia 6500 Slide Cellular Phone
I can not get my pictures on my sd card
Can you describe in more detail what you are trying to do, step by step, and how the process is failing?
I have uploaded and downloaded pictures from my micro-SD card, both while it is in the phone, using a USB cable and setting the phone to "Menu | Settings & Tools | Tools | USB Mass Storage". Then the phone and the micro-SD card appear on my (Windows) computer as a removable drive, and I can just copy files in either direction.
I am also able to remove the micro-SD card, and plug it into an SD-card slot on my computer (with a micro-to-SD card adapter), and it mounts as a removable drive that way, too.
Note: if you have the micro-SD card in the phone, and you want the pictures you take to be stored on there so you can download them in one of the ways I've described above, then be sure to go into "Menu | Settings & Tools | 9. Memory | 1. Save Options | 1. Pictures" and set this option to "Card Memory", or else your pictures will get saved in the camera internal memory, and not on the card. This may be your problem if you are not seeing the pictures you expect on your memory card when you look for them. If you take Videos and/or Sounds, you might want to set those "Save Option" to the Card Memory, too.
Jan 02, 2010 | LG enV3 VX9200 Cell Phone
After capturing photo in Nokia N70 mobile, the picture is not saving in memory card
Hai,
Please open the camera or open Imaging, open camera, select options, select settings, open settings, select memory in use "select your memory card".
Now take a picture and check this should save in memory card.
Dec 29, 2009 | Nokia N70 Cellular Phone
Nokia N85 installed applications , captured pictures and MP3s are missing / corrupted / unable to launch after i turn it on , the next day. sometimes the captured pictures or videos are missing if i turn...
It is your memory card. Replace it with a new one. I also experienced that kind of problem. Even I reformat my Memory Card still the problem persist.
Please don't forget to rate me..:-) Thanks..
Nov 11, 2009 | Nokia N85 Cellular Phone
My new lg cookie isnt taking pictures
your memory might have gotten full...
or other thing may be is that the memory card you are using has viruses...check for that...better you format after backing up the data...your problem must be solved...thank you
Sep 13, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Picture capture failed and system error when using camera
the mainboard need to be tested and diagnosed to determine what the problem is and to fix it.
Dec 02, 2008 | Motorola Mobility W510 Mobile Phone
you may sort it by taking out the battery and putting back in again, or go to settings and select factory/reset default which will erase all settings to when you purchased it.
Aug 02, 2007 | Motorola Mobility MOTORIZR Z3 Cellular...
Samsung Tracfone S425G Slider with Triple Minutes for Life and 1200 Minutes Tracfone Logo
24 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
