Question about Philips 20PS40S 20" TV
Philips 20PS47S301, no sound, picture flashes.
TV was fine two days ago. Just turned it on again, and no sound...and the picture flashes off and back on about every three seconds.
5 Suggested Answers
  • 8 Answers
SOURCE: tv will not turn on--- flashing red led
You will need to take the TV in for repair. The red light is the TV's way of telling you the protection circuitry has been tripped. There is most likely a problem with the power supply inside the TV.
Posted on Jul 13, 2007
  • 1153 Answers
SOURCE: tv power button flashing no picture or sound
Short in powersupply check secondary fuse and all other fuses too. Were there a color problem before this/ Because most of these set have convergence problems. The amps May need to be changed and resistors around them.
Posted on Aug 25, 2007
SOURCE: Turn on power, but no picture, when you turn off power see picture for a few seconds before tv shuts off
Even, I have the same problem...looking for a help on internet but not finding any...if you know...please post on this site.
Thanks,
Posted on Jan 13, 2008
  • 138 Answers
SOURCE: Philips 27PT6441/37
There is a install kit 483531057673 for this model when the set is dead. The kit will contain 7404 and the Horizontal Driver Transformer 5402 along with resistors that will limit stress on 7404 and includes complete instructions
Posted on Aug 19, 2008
  • 267 Answers
SOURCE: philips 20ps47s301 turns on then starts clicking and turns off
IT SOUNDS LIKE YOU HAVE A POWER SUPPLY PROBLEM OR RELAY PROBLEM. BEING A 20 INCH SET IT IS NOT WORTH REPIRING. PARTS AND LABOR WILL BE OVER $100.
Posted on Jan 16, 2009
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
I have a 7 yr old sony kf50we610 rear projection lcd tv. Two years ago the picture and sound started going off and coming back on. I replaced the bulb and it solved the problem. Now two days ago the...
As it was explained in live chat session, cable box needs reset/ reboot because tv has normal picture in other inputs.
After resetting/ rebooting cable box, problem is solved.
Thanks.
Jan 15, 2011 | Televison & Video
No sound on my 32'' Insignia LCD HDTV
Try to unplug the tv for a few seconds and then plug it back in again.
Jan 28, 2009 | Insignia LCDTV26 26 in. Television
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
Philips 27PT6441/37
May 03, 2008 | Philips 27PT6441 27" TV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
WD-52725 TV loses picture while playing DVD but not sound
replace DM or try to fix it.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
Jan 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Philips 20PS40S 20" TV Logo
98 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
