Question about Nikon COOLPIX L18 Digital Camera
Replacing Lcd screen on coolpix l18
What are the steps that needs to be done?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Step 1: Determine what you're trying to do.
Step 2: Repost your query, being sure to include the information from Step 1.
Posted on Feb 07, 2012
  • 125 Answers
SOURCE: Nikon coolpix L18 Screen has
Chances are the manufacturer will not accept damaged screens. If you've got a new camera, try your luck. Cracked screens are highly unlikely as the screens are not under pressure or stressed from the way they are constructed. Much like the cellphone screens, they are pretty tough to break. I broke mine after more than 15 accidental drops.
Posted on Jul 18, 2008
SOURCE: LCD screen took a hit, Where can I buy a replacement LCD for coolpix L11
Ebay has sellers but im comming up short on directions to install.
Posted on Jan 02, 2009
robmcd27
  • 423 Answers
SOURCE: Nikon Coolpix L18 Driver
Try this, it may work without the software.  Turn off the camera. Plug the usb cable between the camera and the computer. Turn on the camera. If a box pops up on the computer asking what you want to do, scroll down and see if there is an option to view pictures. If a window opens up with all your pictures on it, great. Now open up a folder where you want to put your pictures. Bring up the other window with the pictures in it and hit the control key and the d key at the same time on your keyboard. Then drag your pictures to the window where you want them and let go of the mouse key.  They should all move over. Then you can use Windows image viewer to see them. Let me know if that works.
Posted on Feb 18, 2009
zohail
  • 1223 Answers
SOURCE: NIkon coolpix L18 horizontal lines appear after taking picture
contact NIKON BAD CCD PROBLEM !
Get ir repaired free of charge just call them thousands face the same problem and all brands are repairing it free go call them
see the link for widespread Bad CCD problem dont worry if u are not on list but u have the same problem call them PLS RATE ME FIXYA for help !!
http://www.imaging-resource.com/badccds.html
Posted on Apr 13, 2009
dlundmark
  • 797 Answers
SOURCE: Nikon Coolpix S210 lcd broken - need step by step instructions
Most cameras are not that hard, if you are careful and willing to make notes of where each screw came from.
Be sure to get the correct screwdriver to fit the screws correctly and use enough pressure directly to loosen each screw...this is quite important, because if you strip the screw's head, it can be messy.
Most LCD screens are directly under the back cover, and can be replaced usually, once the back is off, remove three or four screw which will hold the LCD frame on. Once that is loosened, then you can carefully remove the screen and see if you need to remove anything else before loosening the cable plug. Take care here, because there are a few different ways these cables may be connected. Some are simply pushed into a connector. Some have a socket which has locks which must be loosened to remove the cable. These little sliding plug connectors are delicate, so you must take it slow and not rush the job. Some of these fold up to loosen, some simply slide away a bit to loosen the plug lock.
Most anyone who has done any delicate work on anything electronic will understand what I am talking about here.
A repair manual may be able to be downloaded for free, but you may have to be a member (usually free) in order to download manuals. Some may charge a small fee for the pdf file.
Hope it all works okay.
Posted on Sep 11, 2009
Testimonial: "Thanks for the suggestions and help. It worked."
Nikon coolpix l18 has white and hazy screen...
is there some small spot on the screen or maybe some black thing. it is due to the lcd screen liquid leaks out.so the lcd seems so blurry.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
e-mail:e-8090team@hotmail.com
Sep 15, 2011 | Nikon COOLPIX L18 Digital Camera
Is it worth fixing a broken LCD Screen on a Nikon Coolpix L18
That's up to you, of course. You can get a new screen here, but the cost is about the same as a used L18, and not that much less than a new L22 or L24. If it was me, I'd replace the L18 instead of repairing it.
Jul 01, 2010 | Nikon COOLPIX L18 Digital Camera
Broken screen
You can purchase a replacement screen for around $55.00 in US, or go on ebay for $20.00 and it is shipped from Hong Kong.
http://www.darntoothysam.com/categories/Nikon-Digital-Camera-Parts-and-Repair-Service/Coolpix-L-Series/
Aug 22, 2009 | Nikon COOLPIX L18 Digital Camera
Anyone know how to replace the screen on Nikon Coolpix L18?
Once you have all the screws out, seperate from the bottom first and then gently pry at the top sides to break the factory seal. The screen has a thin strip of black tape along the right edge you can pull off. Lift up on the screen to reveal the attached electronic strip attached to the board. It is attached with a grey strip that is hinged, just lift up to remove the strip. Replace with the new screen and reassemble your covers.
Aug 20, 2009 | Nikon COOLPIX L18 Digital Camera
Coolpix L18 LCD Freezes
If you are using the NiMH batteries they may be getting hot causing condensation. Try regular battries or wait for the camera to stabalise in the new tempature. If the regular battries work then buy the replacement rechargebal battries because the voltage will vary with tempature also causing errors to the sensors.
Aug 17, 2009 | Nikon COOLPIX L18 Digital Camera
Our Nikon Coolpix L18 was shut in a door. Now when turned on the the diplay screen loks like a broken mirror. Can this be repaired affordably?
Try to take pictures as normal, then transfer the pictures to computer. If the pictures are good, you only broke the LCD, check for ebay to buy and replace the LCD. If you can DIY, maybe it’s just 20-50 bucks.
If the pictures are not good on computer. You have a lens problem too. There is not worth to replace the lens and LCD.
Aug 01, 2009 | Nikon COOLPIX L18 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
81 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
