Question about Philips LX3600D System
Unit stays on standby
My unit had been powered off for two weeks while I was on holiday, on my return it will not power on for longer than 3 seconds. it then drops back to standby. I have disconnected it from the TV and checked the internal fuse. Can anyone please help ??
    President:
  • 1,114 Answers
The only thing I can find in the manual (link below) is to remove the power cord for a few minutes & try powering on from the "Standby ON" button, also set the "source" to anything other than TV. http://www.p4c.philips.com/files/l/lx3600d_25/lx3600d_25_dfu_eng.pdf
Posted on Jul 27, 2007
Keep PC from turning back on after a power fail
If the power drop is of a very short duration (a burp, you may say), the computer reacts the same as if you hit the RESET button on the case front (which is what the RESET button does). Longer drops will usually result in powering off and staying that way, unless the power setting in the BIOS are such the unit should return to previous state after power loss, The only way to prevent such restarts is to invest in an UPS (which is a great idea anyway) which will keep the PC from seeing these kinds of power issues.
Jan 23, 2012 | eMachines EL1210-11 PC Desktop
All the lights on the printer are flashing off and on, the message it gives is turn it off and on. I did that and the whole thing starts over again. also my computer no longer recognizes my printer.
Re-initialize the HP all-in-one
Force the HP all-in-one to reinitialize by following the steps below:
1. Turn the unit off by pressing the ON button.
2. Disconnect the power cord.
3. Wait five seconds, then reconnect the power cord.
4. but before plugging the unit back in, press and hold the # and 6 keys on the HP all-in-one numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the all-in-one re-establishes communication with the computer, reset the language and country.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 29, 2010 | HP OfficeJet 7110 All-In-One Thermal...
Password reset on modem for wifi
on modem or router?
Router reset:
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Thanks, Joe
Dec 29, 2010 | Office Equipment & Supplies
I have belkin router connected but my computer says it does not have internet connection
Reset the router:
Note: Do not recycle power during the reset procedure.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds.
After you reset the router, restart your computer
Thanks, Joe
Dec 20, 2010 | Belkin (F5D5231-4) Router
Oven shows F2 fault several times a week. The oven is less than a year old and we keep it very clean.
F2 EO Shorted keypad/
key stuck
1. Disconnect power from oven for longer than 30 seconds.
2. Reapply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control, then go back to step 2.
F2 E1 Keytail unplugged 1. Verify that keypad is plugged into the connector on back of control.
2. Disconnect power from oven for longer than 30 seconds.
3. If failure remains, disconnect power, replace control, then go back to step 3.
Nov 19, 2009 | Whirlpool Ovens
Trouble w/ the connector in the back of the unit
make sure there is nothing stuck in the power port such as lint use a flash light to look` if u cant fix it take it back to were u bought it and try to return
Nov 04, 2009 | Garmin nuvi 205W GPS Receiver
Just come back from a 2 week holiday and my dell dimension 5100 was off but i usually have it on 24/7. having returned from holiday , when i press the power button nothing happens but the yellow l.e.d...
This model has had a very high failure rate. The amber led on front is on to show an error. This can be 1 of 3 things. 1. The power supply has went bad. 2. The motherboard is bad. or 3. The front control panel is bad. Since Dell used proprietary parts on this model you would need to contact them for replacement. www.dell.com will have the contact info. Hope this helps.
Sep 11, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
How can the Error 2200 be fixed? Lexmark X7170
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black / photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black / photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black / photo cartridge.
Mar 31, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
My nuvi 780 suddenly won't power on. Used it this morning and then a short while later it's broken!
Solution A:
1. Disconnect from power source (automobile cradle and/or usb cable)
2. Slide the power button right into the lock position.
3. Slide the power button to the left and hold it for 10 seconds.
4. Your unit should have powered on after you released the power button
Solution B:
3. Apply light pressure anywhere on the touch screen with your finger.
This worked for me... hope it works for you. - Happy Holidays!
Dec 04, 2008 | GPS
Powerin up - screen goes blank after a few swconds -
had same problem. the cause was corrosion in the boat wiring. the power wire was corroded 95%thru. there was enough voltage to start the unit but when the sounder kicks in the voltage dropped below minimum and the unit shut off. took a LOOOONG time to find.
Nov 15, 2006 | Lowrance LCX-19C GPS Receiver
Philips LX3600D System Logo
544 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
