Question about Vacuums
Baby lock companion intel-a-stitch 7500 manual
The reverse won't work on my singer 9018 sewing machine
STITCHING IN REVERSE
• To reinforce beginnings or ends of seams, push in
reverse lever
(1). Machine will straight stitch in
reverse for as long as you hold the lever in.
• For continuous reverse stitching, push lever in and
slide it to the left to lock. Unlock reverse lever by sliding
it back to the right and letting it return to its normal
position. if you need a manual let me know,,
Nov 25, 2012 | SewShop.com Singer Model 9018 Instruction...
What is the difference between a sewing machine and a serger?
Well..... A serger (or overlock) sews a different, and usually more complex stitch. Where a sewing machine usually only uses two threads to make the stitch, a serger can use two, three, four or even five threads and will sew around the edges of the work piece, as well as trimming the edge of the work just ahead of the sewing area, or as you feed the work in, the trimming takes place first. Sergers also make a stronger seam, attributable to more thread / stitching in the seam. Sergers are versatile and quick, but one drawback is the fact that sergers make a chain stitch instead of a lock stitch, like a machine with a bobbin, and lock stitches can be pulled out, like the stitching that used to close dog food bags and bags of charcoal. A lock stitch is just what it sounds like, it can't be pulled out. You only get a lock stitch with a machine that uses a bobbin, and sergers don't use bobbins. That fact makes serging desirable for the speed of production. Changing bobbins takes up a lot of time, even if you are using pre-wounds. Hope this helps!
Sep 10, 2011 | Vacuums
I have a Tacsew T20U73-1 straight stitch/ zig-zag machine and I am wondering how I go about making my machine go from zig-zag to straight stitch?
There has got to be a selector of some kind on the machine. Usually it will be marked with symbols indicating straight or zig-zag stitch. You may also try varying the width of the stitch. The wider the stitch, the more pronounced the zig-zag effect.
Aug 18, 2011 | Vacuums
I have been lent a Philips Baby Monitor 0682 without a manual and don't know how to work it. Can I access a manual on line, if so How, or do I have to buy one,if so How? Grateful your advice, John...
Hi John.
0682 did not correspond to any known Philips baby monitor model...at least nothing came up in Philips support database. I published below the manuals for different Philips baby monitors. Please check if any of them corresponds to your series.
Philips SBCS369
Philips SBCSC469
Here a list comprising the manuals for most Philips baby monitors models.
Regards.
Ginko
Aug 11, 2011 | Vacuums
Just purchased a used Babylock Companion 200 sewing machine; looking for a user's manual.
I just purchased one from from shop in McDonough, GA called Scarlet Thread. The are Baby Lock dealers and were able to get one for me. It took about 3 weeks but was only $6.99.
By the way, you bought an excellent machine that's super durable!
May 07, 2011 | Vacuums
Do you have a repair manual for a babylock serger BL3-407?
Do u have a repair manual for a baby lock serger.bl3-407
Feb 10, 2011 | Vacuums
I have a Baby Lock Serger Model BL4-605 Serger and can't find the Instruction Manual. Where can I find one? Also, I need a threading guide now, can you help?
I actually have the same model. I have the manual, but it is not very helpful. It does give instructions on treading, but not much else. You can download this manual online and it will cost at least $10.00.
Sep 13, 2010 | Vacuums
I need a Manual for Elna Baby Lock about 10 years old
http://www.tradebit.com/filesharing.php/search/0/elna/0/1
Jul 01, 2010 | Vacuums
Vacuums Logo
201 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
