Insigna 32 when whatching tv the right half of the screen has a reddish tint on white or light colored surface
    Scholar:
  • 140 Answers
The LCD television you have has two light inputs and/or sources. One is for the right hand side of the screen and on is for the left.
From what you have described, it sound like the inverter/ballast for the right side of the screen is going bad or has faulty parts. The lighting tube that the right hand side circuts drive is not functioning properly.
This is not a "user" serviceable part.
If your unit is under warranty you need to send it in ASAP!!!!! If not then pring it to a service center near you ASAP.
Shortly, your right side will go out completely and your television will be usless. Get it repaired now before it causes more damage.
If the repair costs out weigh the replacement cost then just chauk it up to modern electronic and get yourself a new unit.
Good Luck...
Posted on Jan 23, 2009
My pictures have a reddish tint to them
If your pictures that have the reddish tint are taken indoors, the tint is likely caused by the lighting. You can set up a 'white balance" adjustment to fix that.
May 02, 2015 | Nikon D50 Digital Camera
How to set perfect color on samsung 48" led smart tv
To achieve true life like colors, the primary colors need to be balanced to produce a perfect black and white picture. Turn the color level on the tv to 0 and tint to middle then look at the picture - does it have a reddish or other "coloration" to it? Then set the individual color levels (if your TV has these settings) of red, blue and green to balance out and get a true black and white picture. After that, bring the color level up slowly until the facial levels are natural - not over driven as seen in most store displays. You may need to use tint control slightly.....
One other way - There is a dvd from Disney called "Wow" that aids in getting your set to optimum display.
Jul 27, 2014 | Televison & Video
Hitachi RP CRT Gone Red On All Inputs!!!
I want you to do a simple visual check of something that will tell me what the problem may be.
Go to a channel that is in black and white--old movie and tell me what color the screen/picture is.
You can also turn the COLOR in the customer menu all the way off and look that way.
What we are trying to see here is if TRACKING is set correctly or has changed. If the screen is somewhat to medium reddish it may be an adjustment outside of the customer menu.
Let me know what you find--I have seen several of these where the black and white picture was somewhat red--the idea is it should be as close to black and white as possible--if red is the predominant background color the picture will look reddish.
If this has helped and you confirm the red instead of black and white picture--I can tell you a easy way to adjust this.
If this information told you something you did not know and helps you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Hitachi 57F710 TV
Green tint
Check 3.58 MHz color oscillator,, little metal can near large ic,
Also check color output transistors or any loose connections in the output stage
Jan 19, 2009 | Symphonic ST420FF 20" TV
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
Projection tv has a reddish tint on the screen and appears to look hazy and flushed. Flesh tones have a red/orange hue.
first try adjusting the color-tint on the menu if this does not solves the problem you have a failing proyector and has to be replaced
Apr 03, 2008 | Televison & Video
Color out of wack
There are only two things can cause that problem out of value resistors on video stage. or weak picture tube . the first one 60 to 80 dls dependig on the tech ,at shop service 125.00 if is the picture tube more than 450.00 good luck and let me know thanks
Jun 12, 2007 | RCA F32649 32" TV
Televison & Video Logo
229 people viewed this question
Top Televison & Video Experts
