Paper jam in my gbc h340hs - Office Equipment & Supplies
2 Suggested Answers
m4c2
SOURCE: a laminate and paper jam in a Gbc HeatSeal H425 Laminator
You need to loose the vertical plastic wall on the left side, and pull it up and to the left, only then you would be able to take pink rollers and metal piece away. Step by step do this (BTW, make pictures of each step if you think you will not be able to assemble it back) :
Download parts scheme here (if link is broken I can send you; write to ororeivis [at] g mail com):
http://www.gbcconnect.com/assets/docs/H425_PARTS_POUCH_LAMINATOR.pdf
Take the lid (3) off and hang it on the corner.
Next goes off (42) part.
Now focus on the left side. Take to the side part (30) with 7mm wrench. Then both parts (14) from both sides [4 in total]. Then both parts (2). Then take out screws that are holding this vertical plastic wall place. There is two screws from the outside of laminator in the bottom!
Then black roller (36) you lift up and take out by sliding to the side. Then two long black metal pieces.
Now you should be able to pull up and move to the left that vertical plastic wall on the left side of laminator. If not, try loosing some screws that are in this wall.
Be careful taking melted jammed stuff away from heating panel. Do not over-scratch it, as it is very sensitive.
floating cowboy
Posted on Jun 30, 2012
Testimonial: "Thanks! It's all fixed now and put back together!"
Why won't my shredder come on?
Plugged into socket? Paper jam? Bad switch?
Feb 26, 2015 | Swingline GBC ShredMaster GLX2030 Jam Free...
My gbc heatseal h300 wont feed paper.
I have the same machine, GBC H-300. I have it apart right now, and found the feed motor gear in pieces.
Motor Gear 18T 120v part #26700056
Mike Dettling
May 26, 2011 | Grilling
Hi I have a GBC Shredder, made by swingline, model GLX2030. Since this morning the shredder didnt stop! Normally the shredder work only when we put paper into...but today we have to push the ''ON'' button...
There is an infeed sensor that isn't being made for auto on which is just a simple flipper switch and if it doesn't work it is because there is paper jamming it. Unplug it and turn it over where the blades are and see if clogged up and if so than put back on and reverse it and than forward again until it releases if it has a reverse ,reverse it. If no reverse unplug and use a narrow object to clear from the bottom side
Mar 28, 2011 | Gbc GLX2030 Shredder
Jammed the machine too many papers. how can i get it unjammed
Unplug the unit ! Remove the cover if possible then carefully use pliers or vise grips to turn the gears that drive the punch cam backwards to get the paper out.
Dec 17, 2010 | Gbc ® 24-Sheet 3230ST Electric Two- and...
Paper shredder does not rotate in either direction
You most likely have a paper jam in the unit. Check rollers and also check gears in the motors at edges or machine. Leave unplugged while doing this and an hour or to later to reset machine's memory
Aug 20, 2009 | Office Equipment & Supplies
How to fix a stuck shredder
get a pair of needle nose pliers and pull the jammed paper out. (you may need to figure out how to pop off the top cover to get better access to the blades)
May 27, 2009 | Quartet gbc ShredMaster 950S Strip-Cut...
Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Jun 03, 2008 | Office Equipment & Supplies
Shredded paper is wrapped around blades
Try saturating paper jam with liquid vegetable based cooking oil from your kitchen this should soften the paper after sitting 6-7 hours
Oct 28, 2007 | Quartet gbc 1150X Shredder
99 people viewed this question
k24674
jasbo
jasbo
