Question about Samsung PN51D430A3DXZA - PN51D430 51 720p Plasma TV - 16:9 -
Samsung pn51d430a3dxza when turned on power light blinks 5 times and makes buzzing sound
tvtek
  • 1284 Answers
SOURCE: My Samsung T5271F is taking
You have failing capacitors on the power supply board. This is a very common issue with these and others. If you know how to test capacitors and solder its not that tough to repair. Or you can just replace the power supply board which is part number BN44-00184A and runs around $100. You can purchase the board at many places on line. Just do a search in Google with the part number,,,,Good luck
Posted on Sep 18, 2010
  • 8457 Answers
SOURCE: Samsung plasma tv pn42a400c2dxza. when i try to
This problems is the power supply board is causes and the problems.Try website like Ebay.com buy a whole refurbish power supply board for the replacement,will solved this problems.
Posted on Nov 29, 2010
nadeemnazar
  • 300 Answers
SOURCE: i have a samsung pn50b530 plasma tv 50inch that
problem with your display or software
Posted on Apr 26, 2011
SOURCE: Samsung TV LN40B630N1FUZA will not
I had the same problem, I changed the T-CON CBA and it fixed the problem
Posted on Jul 07, 2011
gopakumarg43
  • 75581 Answers
SOURCE: samsung ln40a530p1fxza led light blinks 3 times and makes an tiny audio sound, repeats itself, and tv will not turn on. Main board problem?
Just visit this site 'electronicshelponline'. Type in this site name to your browsers search box. It is a blogspot site, purely technical. It is in English language. Has all details about the blinking codes to Samsung TV. you can get details about these blinking codes from here. Pull up older posts there. The site name is 'Electro-help'
Posted on Jun 21, 2012
Samsung plasma tv pn50b860y2f no sound no picture. When I turn the tv on the red light flashes and I get a buzzing sound from the back right hand side of the set. Any information would be greatly...
Probably the power control board has failed. You can find them on ebay pretty cheap for most TVs and change it yourself if you're mechanically inclined, otherwise have a repairman check it.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
Mar 30, 2015 | Samsung Televison & Video
I have the Samsung model: LN46E550F6FXZA, I can hear it power on, the red light on the front blinks 5 times then goes off. There is no sound or picture.
You will need to have it repaired, looks like the inverter board is broken. Google Samsung tv blinks 5 times, there's tons of threads.
Mar 09, 2015 | Samsung Televison & Video
Samsung txr3079whx/xaa 5 blinking lights
5 blinks to Samsung indicates a fault in the main power supply output voltage.
Jan 23, 2013 | Samsung Televison & Video
Will anyone purchase a tv with a cracked screen for the inner parts?
not likely as if set was on or powered on later there may not be any usable parts---consider listing it on EBAY?
May 13, 2012 | Samsung PN51D430A3DXZA - PN51D430 51 720p...
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and...
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Oct 14, 2011 | Samsung DLP HL-P5663W 56" TV
3 lights blink and a loud buzzing sound.
Color wheel you can get one at the following link with instructions on how to replace it
Jun 01, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Turns on, no picture or sound, light blinks 5X, reboots itself
First thing is to check the lamp. you can easily change this yourself.
May 26, 2009 | Samsung HCM4216W 42" Rear Projection...
Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Jan 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung PN51D430A3DXZA - PN51D430 51 720p Plasma TV - 16:9 - Logo
61 people viewed this question
Jerry Greenberg
Jerry Greenberg
