Question about Jura Capresso Impressa Z5 Espresso/Coffee Maker
Z5 back is not latching-- needs to be removed-- but how?
How do you remove the back of the Jura Z5? The back is not laying flat and we can see it needs to be removed and relatched. Tried everything, dont want to break the new machine. Any thoughts?
  • 8 Answers
You first need to remove the Jura crest by turning it clock wise. I use a piece of ruber pressed against it to help.
Then you will need a special screwdriverZ5 back is not latching-- needs to be removed-- bu - 0e8bdcd.jpg for the oval shaped screw heads.113e935.jpg
I ordered the screwdriver from germany; www.juraprofi.de.
The cover can then easily be removed by sliding upward.
Posted on Jan 24, 2009
Jura impressa Z5 doesn't switch on anymore. A few days before just was displaying "maintenance" and then no more signs of life.
Search Results
    How to Fix Jura Z5, Z6 and Z7 - YouTube
    ? 16:03
    https://www.youtube.com/watch?v=HlCu5m9isT4
    Aug 18, 2013 - Uploaded by Parts Guru
    I changed the filter, pressing button for System Fill, get message System is filling. .... My Jura Capresso Z5's milk frother doesn'twork. When I ...
    Jura Capresso Z5 Impressa - No milk frothing - YouTube
    ? 1:05
    https://www.youtube.com/watch?v=_jF_8rNUn4A
    Oct 25, 2013 - Uploaded by Frederic Valiquette
    Hi all, My Jura Capresso Z5 Impressa is acting up. The milk frother doesn't work anymore. When I ...
    [PDF]Instructions for Use, Manual JURA IMPRESSA Z5 - Esperanza
    https://www.esperanza.ch/.../download_manual_jura_impressa_z5-gen2_...
    The IMPRESSA Z5 - Generation II Manual. The 'IMPRESSA .... 5 Preparation at the touch of a button. 40 ..... As coffee and coffee specialities are very important to JURA, we have compiled a ...... It doesn't matter whether whole milk or skim.
    My Jura Impressa Xs90 won't switch on and nothing is - Fixya
Jan 31, 2016 | Coffee Makers & Espresso Machines
Can't get system fill message off jura impress z5
My guess would be that your water tank float is trapped.
The remidy would be to descale the watertank itself.
If you use the Calris filter cartridge. remove it before descaling with a mild commercially available descaler. Don't forget to rinse thorrowly afterwards and reinsert the filter. Always use cold water to fill the watertank.
Hope this helps
Oct 05, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
Water in disposed coffee container jura impressa z5
You may have to clean the unit using cleaning tablets, also there is a flap in the bay (remove the tray and use flashlight, sometimes it cakes up and moisture collects. Final thought is you may need to send it in to Capresso/Jura for service. Mike
Mar 08, 2014 | Jura Capresso Impressa Z5 Espresso/Coffee...
I can't get the tray back in
Remove the grinds container than put it in, rinse or power cycle the machine and it will be sorted out.
Sep 03, 2012 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura-Capresso Impressa Z5 - left coffee spout is clogged the left spout only lets drips of coffee coming through yes we: 1. use only dry beans 2. have the water harshness setting below 10 (we only use...
As the coffee is dispensed, it is normal to have some residue left in the tubing and spouts. It is the reason that the machine will require cleaning on a regular basis using the Jura tablets that dissolves the coffee film. In the case the spouts get clogged, the best approach would be to dismantle the spout assembly. Since it may not always be possible, I found that filling a cup with a coffee cleaning solution such as Puly Cleaner (pulycleaner.co.uk) and having the spout dip in the solution overnight can help. Probably that dissolving a Jura cleaning tablet in a cup of warm water would provide similar cleaning power.
Dismantling the spout is rather straightforward. You start with removing the front logo by rotating it counter-clockwise. Behind it you will find a T15 Torx screw. Removing it will allow removal of spout cover by pulling the top part lightly towards you and then sliding it down below the spouts. Grab the spouts by the sides and wiggle downwards until it comes loose. You can now clean the spouts but will most likely need to soak it. See the video showing removal of the spouts @ youtu.be/9QlRGY0eX3s
Jun 08, 2011 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Z5 - no water being sucked up through the system
If you are holding the filled water tank in your hands does it leak? If no then the o-ring in the bottom of the hole on the machine where the tank sits is damaged.
If yes then check the spring and o-ring on the bottom of tank.
Apr 28, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Impressa Z5 Error 8
We have just done a full disassembly, cleaning, and relube of our Jura Z5 Impressa unit. Here are the full details of the RainyDayProject:
http://www.rainydaymagazine.com/RDM2009/Home/October/Week4/RDMHomeOct2009.htm#JuraZ5BrewUnitCleaning
Click on any of the images for larger version.
Sincerely,
RainyDayInterns
May 04, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa Z5 Espresso/Coffee Maker Logo
448 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
