Question about Konica Minolta bizhub 350 All-In-One Laser Printer
C12cb HAVE c350 WITH c12CB ERROR HOW DO I FIX IT
  • Anonymous Feb 17, 2009
    How do I go into the administrator settings?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 62 Answers
Hi, C-12CB means you have a problem with a transfer of data from the Hard Drive.
You may be able to format it somewhere in the Administrator settings.
If not, a service engineer can Format the HDD in Tech Rep mode.
Posted on Feb 07, 2009
I ave problem on c350 error code 2160
BIZHUB C350 SHOWING ERROR CODE C-0900 AND
NOW C-0950
Sep 30, 2013 | Konica Minolta Bizhub C350 Digital Copier,...
Konica minolta bizhub c350 error codes c-0510
eror code c-0098 meaning ??????????????pls tell me the solution
Jul 31, 2012 | Konica Minolta Bizhub C350 Digital Copier,...
Hi guys i am saeid from iran.my problem is:i bought a c350 second hand.when turn on the machine it want volume track&access code.i cant relese this.i donnt know whats the #.pelease help me
Having got the details o the problem you posted, i would like to give you the detailed guided step by step clicks you carry out now to fix this problem and get the whole of your pc fast running again.
Its the COMPUTER HELP TEAM PROJECT
Follow up the experts detailed guide to ix the errors with your pc.
Access the platform for fixing all pc errors and optimizing your pc speed HERE
Step 1. success.
Feb 28, 2011 | Minolta C350 Printer
I install new imaging unit cyan and magenta but c350 machine shows still change imaging unit error. how to fix this error.
Did you turn the main power switch OFF then back ON? You need to do that to reset the counter. Also, did you put a brand new one in from a closed box or a used one? If it is a new one & it will not clear, return it to where you got it from... Good Luck
May 22, 2010 | Minolta C350 Color Printer/Scanner/Copier
Konica Minolta C350 colour copier T096 error code??
Transfer belt code C096 mite try open and closing the front door where you put the toner. Also remove the image transfer belt and then reseat it.
Apr 10, 2009 | Minolta Office Equipment & Supplies
Bizhub c350 -cobao code
finisher elevator drive error. Check the finisher tray for blockage or something under the tray. If all else fails, unplug and disconnect the finisher
Jan 20, 2009 | Office Equipment & Supplies
Konica Minolta Bizhub c350 error code c-0510. What is it? How do I fix it?
C0510 Upper fusing roller abnormally low temp
replace the thermistor in the fuser
Sep 25, 2008 | Office Equipment & Supplies
Erroe code
You post a wrong printer nr, you must have bizhub C350 not bizhub 350, beacause 350 doesnt have that kind of code.
In Bizhub C350 that code means:
C12C0: Hard disk recognition error
You have the following options:
- reinstall the hard disk
- change hard disk
or as a last chance change PWB-MFP
good luck
Feb 06, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Error code C-12CB
you ordered black IU ???? do you have bichub 350 or C350 ???? because 350 is B/W printer and you need trum unit and starter at least.
C12CB: Hard disk data transfer error
solutions:
1 Reinstall the hard disk.
2 Change Hard Disk.
3 Change PWB-MFP.
Dec 14, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
315 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
