Question about Oregon Scientific RGR202 Wireless Rain Gauge and Temperature Station
My Oregon rg202 weather station keeps coming up HH in temp section can I just put it back to temp
4 Suggested Answers
SOURCE: Lost the instructions to program my weather radio.
Just follow the link below. I just this PM downloaded it for the same reason. All you need is Adobe Reader to read or print it: http://site.ambientweatherstore.com/Manuals/wr102.pdf Regards, Craig Starr Danville, NH 03819 dts_cjs@hotmail.com
Posted on Feb 13, 2007
SOURCE: Operating Instructions Model No BA218
Setting the time and calendar
1. Press the [TIME] button once to enter Time Mode. The display shows the current time with hour, minutes, and seconds digits.
2. Press and hold the [SET] button for more than one second. The "Hour" digits of the time will begin flashing.
3. While the "Hour" digits are flashing, press the [^] or [down] button to set the desired hour time. Note: Press the [^] or [down] button once to advance the setting forward or backward by one digit. Pressing the [^] or [down] for more than one second will accelerate the forward or backward setting at a higher rate.
4. When the desired hour time is reached, press the [SET] button again. The "Hour" setting will be confirmed and the "Minute" digits will begin flashing.
5. While the "Minute" digits are flashing, press the [^] or [down] button to set the desired minute time.
6. When the desired minute time is reached, press the [SET] button again. The "Minute" setting will be confirmed and the "Year" digits will begin flashing.
7. While the "Year" digits are flashing, press the [^] or [down] button to set the desired year.
8. When the desired year is reached, press the [SET] button again. The "Year" setting will be confirmed and the "Month" digits will begin flashing.
9. While the "Month" digits are flashing, press the [^] or [down] button to set the desired Month.
10. When the desired month is reached, press the [SET] button again. The "Month" setting will be confirmed and the "Date" digits will begin flashing.
11. While the "Date" digits are flashing, press the [^] or [down] button to set the desired Date.
12. When the desired date is reached, press the [SET] button again. The "Date" setting will be confirmed and the calendar setting is complete.
Posted on Feb 10, 2010
kb8dns
  • 494 Answers
SOURCE: dashes in my outdoor weather reading of Oregon Scientific station
The signals are not being received by the main unit. Try to reposition the unit or move it to a different location. Also make sure the antenna is in the clear and not next to any thing like a cordess phone or charger as these can make RF noise that can block or cover the needed signals.
Posted on Feb 11, 2010
I have a new weathr station and can not get the outside temp. to display what can I do?
I assume it is a wireless station. If so, there is a procedure to go through to get the temperature sender and the base station to sync up and work. You need to check your owners manual to get the exact procedure for your unit. On my station, I have to remove the battery from the base station, let it power up and within 5 minutes, install the battery in the remote station(s) (temperature, rain gauge, wind gauge, etc.). Also, you must keep the remote station within a certain range for the base to get a good signal. Probably 25 feet, but the owners manual will have the right number. Also, use new batteries.
Aug 02, 2016 | Oregon Scientific WMR86 - Backyard Pro...
What does HH on the outside temp mean on Model 513-1311OT?
HH means that the temp is over the highest reading that it is specified for. That means either the sensor is bad or it is in a very hot place. The maximum temp for that sensor is 122 degrees
May 28, 2015 | Measuring Tools & Sensors
Model no 217s31 does not display outdoor temperature reading.
As much as it sucks to do, you have to reset the base and the temperature sensor. When you do it, keep the temp sensor next to the base until the base recognizes it.
Mar 11, 2013 | Oregon Scientific BAR386 Wireless Weather...
I See my Outdoor temp. Nothing
What do you mean nothing? How are the batteries? What channels are you using?
Feb 22, 2013 | Oregon Scientific BAR386 Wireless Weather...
Reset oregon scientific weather station
I always have trouble getting mine to work after changing the batteries, but I have just managed to get it going by doing the following:
taking batteries out of main unit
putting new battery in remote unit and pressing remote unit reset button
re-inserting batteries in main unit and pressing reset button.
i think the trick is to ensure that the batteries go in the remote unit first, then the main unit after that. It has taken me days to work this out!
Jan 19, 2013 | Oregon Scientific BAR206 Wireless Weather...
I have an Acurite 822-RX thermometer that shows HH as the outdoor temp, even after replacing the batteries in both the base and remote units. How can it be fixed or reset?
HH means it is showing the high temperature you (most likely accidentally) set with the MAX MIN / + button, which is easy to do when setting the clock. Just press that button again until the reading appears.
Jan 15, 2011 | Acu-Rite Acurite Wireless Weather...
My oregon scientific indoor outdoor weather station with atomic clock just stopped picking up the outdoor readings, it won't switch to that channel any longer. tried removing and reinstalling the battery,...
I had the same problem, Since the outside temp wouldn't read, I figured it was the outside unit batteries. Went through half a dozen AAA batteries and wouldn't read. It was the indoor unit. Had the same bats I installed 3 years ago. DUH! Replaced the AAA, and all was well. When the inside batteries die out, it has just enough juice to read indoor temp, but not enought to sense exterior signal.
Oct 20, 2010 | Oregon Scientific Wireless IndoorOutdoor...
Dashes in my outdoor weather reading of Oregon Scientific station
Feb 07, 2010 | Oregon Scientific Audio Players &...
Oregon Scientific RGR202 Wireless Rain Gauge and Temperature Station Logo
Top Oregon Scientific Measuring Tools & Sensors Experts
Lawrence Oravetz
Timllfixit
Are you an Oregon Scientific Measuring Tool and Sensor Expert? Answer questions, earn points and help others
