Question about Watches
Set up to beep sound on g shock 2688
I want the casio 2688 g shock to beep every hour and alarm
Doodad
  • 64 Answers
SOURCE: Setting Alarms
Here is a link that might help. Just make sure you have the latset version of Adobe Reader. Click on the model/version number and start to dowload. It should already be there, just give it a click.
http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2688&submit.x=58&submit.y=1
Posted on Jan 03, 2008
SOURCE: Lost alarm & all Beeps on Casio G-Shock G3110 Wristwatch
You probibly lost a little spring that goes into your movement that makes contact the curcit board and the back of your watch. It is VERY small and alot of people who change their own batteries don't even see it when they open their watch and it falla out . If I knew your address I would send you a couple. If you look at the back of yhe inside of your watch you will probibly see a hole with a LITTLE straight line comming off of it, that is where that spring goes. NOW you MAY not have grounded your watch, that could cause that to happen to. Open your watch and look at the back. You should see a AC marking. Take a tweezer or a metal object and touch the ac and the top of the battery.Then re-set your watch time. I'm hoping that is it, if not you need that spring.Let me know what happens, and if I can assit you with any other watch or jewelry problem.Also we at home are proud of you!!! Good Luck!!!
Posted on Jul 09, 2008
SOURCE: Alarm goes off at midnight & repeats for half hour, and not set
what you have to do is
1. press the mode button until you get to the setting that has "AL" at the bottom right.
2. then you press the "receive" button to switch between the four alarms.
3. as you are going through each alarm time, you need to look in the circle at the top right. When you are going through the alarm times, if there is a mark next to "ALM", you need to press the "time memo" button so that the mark next to "ALM" is no longer there.
4. repeat step fout for all of the alarms, and the problem should be fixed.
Posted on Apr 07, 2009
  • 2501 Answers
SOURCE: CASIO Baby G Shock Watch BG905B cannot turn off
If you haven't got instructions on how to do this, you can get
instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Posted on May 23, 2010
My G-Shock doesn't beep every hour, how do i get it to do that?
To make it beep every hour you must first put it on the alarm mode. Then, press the START-STOP button until a little bell shows up at the left. Hope it helps!
Oct 01, 2010 | Casio G-Shock G2600 watch
CASIO Baby G Shock Watch BG905B cannot turn off hourly beeps. I want to turn off all alarms and beeps
watches;
Accept terms
May 23, 2010 | Casio BabyG Shock Resistant #BG905B Watch...
Shut off hourly alarm on g-shock
Okay I have this module so here goes.
Start from your regular timekeeping mode (use lower left buttin to cycle through until you get to the normal time display).
Press 'mode' button (lower left) once. You are now in alarm mode.
Press lower right button to cycle through the alarm modes. The cycle goes: hourly beep on, timed alarm on, both on, neither on. You will see the corresponding icons (a ripple icon for hourly beep and and a bell icon for the alarm) appearing/disappearing in the top left of your display as you cycle through. So if you are in hourly beep mode now you probably need to press that lower right button 3 times to get to 'neither' alarm being on.
Press lower left button to return to normal display.
Hopefully - enjoy the peace!
Jul 05, 2008 | Casio G-Shock G2600 watch
Apr 13, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Alarm/Beep
Use the MODE button (lower left) to get into Alarm mode. Then press the RECEIVE button repeatedly, cycling through Alarm1, Alarm2, Alarm3,Alarm4, then SIG (for Signal). Press the TIME/MEMO button to togge On or Off.
David Mize
Pickerington, Ohio
Mar 04, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Setting Alarms
Jan 03, 2008 | Casio DW9051B-1V Wrist Watch
Resetting watch
ive set an alarm that goes off at twelve every day.it goes off every five minutes for thirty minutes. its driving me nuts. how do i fix this?
Nov 04, 2007 | Watches
Watches Logo
37 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
