Question about Whirlpool GS6SHEXMB / GS6SHEXMQ / GS6SHEXMT Side by Side Refrigerator
Clicking noise Ice maker started clicking after about 18 months. Clicking noise was continuous as long as ice maker was on, but went off when ice maker was switched off. Water dispenser also started clicking when used and dispenser light flashed intime with clicks. Water also dispensed in 'spurts' in time with clicking. Recently clicking noise comes and goes at any time, but is getting more frequent. I suspect a solenoid, but would appreciate some guidance on the difficulty of locating and replacing.
  • Anonymous Mar 25, 2014
    608Ltr side by side fridge purchased 2007
    light of ice maker flashes on/off for several seconds at regular intervals
  • Whirlpool Master
  • 909 Answers
THE FRONT PANEL IS DEFECTIVE. HAVE REPLACED TWO IN LAST MONTH. JUST TAKE NOTE OF MODEL WITH DEALER AS CERTAIN MODELS HAVE TO HAVE THE POWER BOARD REPLACED AS WELL.
Posted on Jul 20, 2007
Ice dispenser solenoid continually clicks
If the ice maker is working ok and you can live with the noise leave it alone. Eventually the solenoid will fail.
Don't worry though it's an easy fix. You'll need to replace both the ice maker and the water dispenser solenoids. They're located behind the hardboard cover on the lower right side (looking at the back of the refrigerator), where the water comes in.
Parts are under $50 and the job should easily take less than 1 hour.
Feb 04, 2014 | Electrolux Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Subzero 690 ss icemaker making a clicking sound why
If the noise is coming from the ice maker head itself. Then it sounds like the gear is slipping. They are plastic and it is very common for them to crack or break. Most ice makers are the same. Click Here to see a post on a Whirlpool ice maker with a broken gear.
Good Luck From David at refrigerator repair.
Apr 04, 2013 | Refrigerators
My ice maker fails to make ice, and seems to get "stuck" between batches, causing a clicking noise that occurs continuously about every 30 seconds. Any suggestions?
check for a stuck ice cube, something is preventing your ice maker to advance, if there is no ice cube, replace ice maker part #wr30x10093 for standard in freezer ice maker or part #wr30x10097 for ice maker in refrigerator
Aug 26, 2010 | GE Profile Performance 23.5 cu. ft....
My ice maker does not eject ice when frozen. Make
Good day,
Unplug refrigerator.
Snap off front cover of the ice maker. You will see a large white gear.
If the plastic gear has a screw in the center, then you can remove the gear and inspect for broken teeth. The gear is easily replaced thru any appliance parts house.
If there is no screw then the ice maker uses a semi-solid circuit board and must be replaced.
Dec 17, 2009 | Kenmore Refrigerators
ED5NHGXMQ00 stopped working overnight. Ice maker
Clicking could be a bad starter relay if the noise is coming from the back under the unit where the compressor is. check it here Check your compressor relay- http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
The clicking could be coming from a fan, one of which is near the compressor under the unit and another is in the freezer behind the rear cover inside.
The defrost timer could be clicking. This sound would come from the fridge. Part 6 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ED5NHGXMQ00&productCategoryId=0165000&brandId=1198&modelName=SIDE-BY-SIDE-REFRIGERATOR&diagramPageId=00011&componentDescription=CONTROL%20PARTS&documentId=W0309019&backToLink=Return%20to%20Sub%20Components%20list
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Sep 09, 2009 | Samsung RS2630WW Side by Side Refrigerator
Clicking noise, ice maker out, freezer temp high
Low temperatures are absolutely required for proper operation of ice makers components. Dirty cooling coils or possible low refrigerant.
Jul 08, 2009 | Freezers
Whirlpool GS6SHEXMB / GS6SHEXMQ / GS6SHEXMT Side by Side Refrigerator Logo
787 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
