Question about Canon PowerShot SD1000 Digital Camera
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Posted on Jan 23, 2009
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
Canon SD1000 Power Shot Lens Error
try to reset the camera, take the battery out for a while..
let me know..
micro-
Sep 10, 2008 | Cameras
My cameras power seems to work but the screen is all pur black ?? what can i do to fix this???
I have canon power shot sd1000 camera. Every thing is o.k. except that recently the screen stays dark in picture mode and when on for taking pictures. pl let me know.
Feb 03, 2011 | Canon PowerShot SD630 Digital ELPH / IXUS...
My Canon Sd1000 will not take pictures. You can
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Note that your camera does not have shutter priority mode (Tv) as listed in the link. Instead, put the camera in manual mode and turn off the flash, and also turn off the LCD display (press the DISP button). With these settings, try the fix in a darkened room, opening the battery door immediately after taking the picture. Give it several tries, if no luck consider also trying step 5a described in the link.
Dec 29, 2009 | Canon PowerShot SD1000 Digital Camera
I am having power supply and lens problem with a canon sd1000 digital camera. its not working with the battery inside and the lens got stuck and was not closing and now it is open but the camera is off and...
I am afraid you have the notorious lens stuck problem. If you google "canon lens stuck" or "canon lens not retracing" the results will be in millions. Canon's quote for repairing this issue is well over the cost of the camera itself. However all is not lost. It may be just dust. You can try to clean the lens contacts with isopropyl alcohol and see if resolves the issue. I have previously suggested placing the camera lens on the edge of the table and hit it with moderate force to force the lens back into the slot and I was surprised to know it worked for a lot of people!
http://www.fixya.com/support/t240817-camera_error_e45
Might be worth a try after getting a quote from canon?
Dec 25, 2009 | Canon PowerShot SD1000 Digital Camera
Whenever I attempt to download pictures off my Canon Power Shot SD1000 onto my HP Pavilian dv6135nr laptop, the computer apparently is not picking up signal from the camera EVEN THOUGH after plugging in my...
does the laptop recognized you canon power shot? if not try installing the software of the canon power shot to your laptop, these camera comes with installation when you purchased it, try to install it, sometimes win xp does not recognized such devices
regards
michae
Nov 19, 2009 | Computers & Internet
Cannonpower shot A590
Use a separate card reader to download your pictures.
Aug 30, 2009 | Canon PowerShot SD1000 Digital Camera
My Canon Powershot SD1000 will not focus
You must need to reset all function of auto- focus setting.. its called as master reset. then see its works...
Jun 29, 2017 | Canon PowerShot SD1000 Digital Camera
Camera Frozen - Canon Powershot SD1000
Have you tried using a different set of batteries ?
Mar 05, 2009 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
97 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
